evgen.v Posted March 26, 2015 Posted March 26, 2015 Добрый день! Есть машина с созданным в биосе зеркальным рэйдом, с другого диска загружается CentOS 7. В /etc/fstab указан массив и точка монтирования: /dev/md176p1 /mnt/Storage1 ext4 defaults 1 0 Информация о массиве: # mdadm --detail /dev/md126p1 /dev/md126p1: Container : /dev/md/imsm0, member 0 Raid Level : raid1 Array Size : 976758784 (931.51 GiB 1000.20 GB) Used Dev Size : 976759940 (931.51 GiB 1000.20 GB) Raid Devices : 2 Total Devices : 2 State : clean Active Devices : 2 Working Devices : 2 Failed Devices : 0 Spare Devices : 0 UUID : 484dded0:00aae369:90e701d4:57bd62a0 Number Major Minor RaidDevice State 1 8 0 0 active sync /dev/sda 0 8 16 1 active sync /dev/sdb При загрузке система переходит в emergency mode, journalctl -xb выдает вот что (кусок с ошибками монтирования): -- Unit sys-fs-fuse-connections.mount has finished starting up. -- -- The start-up result is done. мар 26 15:49:38 kvm systemd[1]: Mounting /mnt/Storage1... -- Subject: Unit mnt-Storage1.mount has begun with start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit mnt-Storage1.mount has begun starting up. мар 26 15:49:38 kvm mount[823]: mount: /dev/md126p1 is already mounted or /mnt/Storage1 busy мар 26 15:49:38 kvm systemd[1]: mnt-Storage1.mount mount process exited, code=exited status=32 мар 26 15:49:38 kvm systemd[1]: Failed to mount /mnt/Storage1. -- Subject: Unit mnt-Storage1.mount has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit mnt-Storage1.mount has failed. -- -- The result is failed. мар 26 15:49:38 kvm systemd[1]: Dependency failed for Local File Systems. -- Subject: Unit local-fs.target has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit local-fs.target has failed. -- -- The result is dependency. мар 26 15:49:38 kvm systemd[1]: Dependency failed for Relabel all filesystems, if necessary. -- Subject: Unit rhel-autorelabel.service has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit rhel-autorelabel.service has failed. -- -- The result is dependency. мар 26 15:49:38 kvm systemd[1]: Dependency failed for Mark the need to relabel after reboot. -- Subject: Unit rhel-autorelabel-mark.service has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit rhel-autorelabel-mark.service has failed. -- -- The result is dependency. мар 26 15:49:38 kvm systemd[1]: Triggering OnFailure= dependencies of local-fs.target. мар 26 15:49:38 kvm systemd[1]: Unit mnt-Storage1.mount entered failed state. мар 26 15:49:38 kvm systemd[1]: Stopped Daily Cleanup of Temporary Directories. -- Subject: Unit systemd-tmpfiles-clean.timer has finished shutting down -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel Вручную с помощью "mount -a" этот раздел монтируется без проблем. Помогите решить эту проблему :) Вставить ник Quote
FATHER_FBI Posted March 26, 2015 Posted March 26, 2015 Бросьте вы эту затею с raid в bios. Если нужен нормальный RAID лучше купите что нибудь хардварное, если маленький бюджет. Барахолки никто не запрещал. Вставить ник Quote
Abram Posted March 26, 2015 Posted March 26, 2015 Intel Matrix Storage и иже с ними? Выбросьте и используйте mdadm. Один хрен и то, и другое софтовое. Вставить ник Quote
DVM-Avgoor Posted March 27, 2015 Posted March 27, 2015 Если нужен нормальный RAID лучше купите что нибудь хардварное В корне не согласен, hw raid ничем не лучше софтового кроме 2-5% выигрыша в цпу. Зато минусов целая пачка. Вставить ник Quote
DVM-Avgoor Posted March 27, 2015 Posted March 27, 2015 /mnt/Storage1 существует персистентно на диске? Рутфс успевает смонтироваться до этого? добавьте в опции фс nofail Вставить ник Quote
evgen.v Posted March 27, 2015 Author Posted March 27, 2015 (edited) /mnt/Storage1 существует персистентно на диске? Рутфс успевает смонтироваться до этого? добавьте в опции фс nofail Да, директория существует, рут монтируется до него. Еще в /mnt/Storage2 монтируется другой жесткий диск, отдельный от массива, c ним никаких проблем нет /dev/sdc1 /mnt/Storage2 ext4 defaults 1 2 Добавил nofail, система грузится, в emergency mode не падает, но массив не подключается. #cat /etc/fstab /dev/mapper/centos-root / xfs defaults 1 1 UUID=6d129378-9346-4cb5-8afc-de9aef2979db /boot xfs defaults 1 2 /dev/mapper/centos-swap swap swap defaults 0 0 /dev/md126p1 /mnt/Storage1 ext4 defaults,nofail 1 0 /dev/sdc1 /mnt/Storage2 ext4 defaults 1 2 #journalctl -xb | grep -C 5 Storage1 -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit sys-fs-fuse-connections.mount has finished starting up. -- -- The start-up result is done. мар 27 11:12:00 kvm systemd[1]: Mounting /mnt/Storage1... -- Subject: Unit mnt-Storage1.mount has begun with start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit mnt-Storage1.mount has begun starting up. мар 27 11:12:00 kvm systemd[1]: Started File System Check on /dev/sdc1. -- Subject: Unit systemd-fsck@dev-sdc1.service has finished start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- -- Subject: Unit mnt-Storage2.mount has begun with start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit mnt-Storage2.mount has begun starting up. мар 27 11:12:00 kvm mount[796]: mount: /dev/md126p1 is already mounted or /mnt/Storage1 busy мар 27 11:12:00 kvm systemd[1]: mnt-Storage1.mount mount process exited, code=exited status=32 мар 27 11:12:00 kvm systemd[1]: Failed to mount /mnt/Storage1. -- Subject: Unit mnt-Storage1.mount has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit mnt-Storage1.mount has failed. -- -- The result is failed. мар 27 11:12:00 kvm systemd[1]: Unit mnt-Storage1.mount entered failed state. мар 27 11:12:00 kvm systemd[1]: Mounted /mnt/Storage2. -- Subject: Unit mnt-Storage2.mount has finished start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- Edited March 27, 2015 by evgen.v Вставить ник Quote
FATHER_FBI Posted March 27, 2015 Posted March 27, 2015 Если нужен нормальный RAID лучше купите что нибудь хардварное В корне не согласен, hw raid ничем не лучше софтового кроме 2-5% выигрыша в цпу. Зато минусов целая пачка. Был у меня опыт с такими soft-raid на обычных мамах. Если один винт начинает тупить. Весь массив начинает загибаться, такое впечатление что запросы на диски становились в очередь. Читал спецификацию хардварных контроллеров, там явно указывается если какой нибудь из винтов не ответил N милисекунд, контроллер помечает его как degraded. А на софте это лечилось вычислением через SMART какой винт умер. Вставить ник Quote
Abram Posted March 27, 2015 Posted March 27, 2015 FATHER_FBI, Для этого нужно использовать серверные HDD (как WD RE). Они сами в случае деградации не тупят, а сразу выдают ошибку. Тогда RAID-контроллер (или ОС) сразу же делает его degraded. И именно по этой же причине серверные HDD нельзя использовать на десктопе. Кстати, вот: http://geektimes.ru/post/92701/ . Вставить ник Quote
FATHER_FBI Posted March 27, 2015 Posted March 27, 2015 (edited) FATHER_FBI, Для этого нужно использовать серверные HDD (как WD RE). Они сами в случае деградации не тупят, а сразу выдают ошибку. Тогда RAID-контроллер (или ОС) сразу же делает его degraded. И именно по этой же причине серверные HDD нельзя использовать на десктопе. Кстати, вот: http://geektimes.ru/post/92701/ . Использовались WD VelociRaptor, тестовый стенд проработал неделю под нагрузкой и успешно умер. Спасибо за статью) Edited March 27, 2015 by FATHER_FBI Вставить ник Quote
DVM-Avgoor Posted March 27, 2015 Posted March 27, 2015 Если нужен нормальный RAID лучше купите что нибудь хардварное В корне не согласен, hw raid ничем не лучше софтового кроме 2-5% выигрыша в цпу. Зато минусов целая пачка. Был у меня опыт с такими soft-raid на обычных мамах. Если один винт начинает тупить. Весь массив начинает загибаться, такое впечатление что запросы на диски становились в очередь. Читал спецификацию хардварных контроллеров, там явно указывается если какой нибудь из винтов не ответил N милисекунд, контроллер помечает его как degraded. А на софте это лечилось вычислением через SMART какой винт умер. Я не говорил про всякий intel-matrix. Речь про обычный mdadm, например. Вставить ник Quote
taf_321 Posted March 30, 2015 Posted March 30, 2015 Number Major Minor RaidDevice State 1 8 0 0 active sync /dev/sda 0 8 16 1 active sync /dev/sdb Говорил в другой ветке, повторю тут: при создании массивов в mdadm, использовать "сырые" устройства без создания на них разделов - это подложить себе мину на будущее. Ну хреново работает с не размеченными устройствами mdadm, о чем честно пришет при попытке создания. Вставить ник Quote
