sunsun Posted March 26, 2015 Posted March 26, 2015 Добрый день. Прошу Вашей помощи в настройки ISG ASR 1002X. Необходимо настроить accounting subscribers session и отослать их на RADIUS server с идентификатором пользователя. Может был у кого опыт в настройке подобной конфигурации... Заранее Благодарю за помощь. version 15.4 service timestamps debug datetime msec service timestamps log datetime msec no platform punt-keepalive disable-kernel-core ! hostname WAG_ASR1002X ! boot-start-marker boot-end-marker ! aqm-register-fnf ! ! aaa new-model ! ! aaa group server radius SERVER_GROUP1 server name RAD1 ! aaa authentication login IP_AUTHEN_LIST group SERVER_GROUP1 aaa authorization network default group SERVER_GROUP1 local aaa authorization network AUTHOR_LIST group SERVER_GROUP1 local aaa authorization subscriber-service default local group SERVER_GROUP1 aaa accounting include auth-profile framed-ip-address aaa accounting network IP_SESSION start-stop group SERVER_GROUP1 aaa accounting system default start-stop group radius ! aaa nas port extended aaa server radius sesm client 10.245.1.6 key message-authenticator ignore ! ! ! ! aaa session-id common clock calendar-valid ! ! no ip dhcp use vrf connected ip dhcp excluded-address 172.28.0.254 ! ip dhcp pool WIFI_users network 172.28.0.0 255.255.255.0 default-router 172.28.0.254 dns-server 8.8.8.8 ! ! ! subscriber feature prepaid IP_SESSION threshold time 0 seconds threshold volume 0 bytes method-list author default method-list accounting IP_SESSION ! subscriber service session-accounting subscriber templating subscriber authorization enable subscriber accounting ssg ! multilink bundle-name authenticated ! ! ! ! ! redundancy mode none redirect server-group ISG_GROUP server ip 10.245.1.6 port 80 ! ! ! ! ip tftp source-interface GigabitEthernet0 class-map type traffic match-any ISG_OPENGARDEN match access-group output name ACL_OUT_OPENGARDEN match access-group input name ACL_IN_OPENGARDEN ! class-map type traffic match-any L4REDIRECT match access-group input name ACL_IN_L4REDIRECT ! class-map type control match-all IP_UNAUTH_COND match timer IP_UNAUTH_TIMER match authen-status unauthenticated ! policy-map type service L4REDIRECT_SERVICE 10 class type traffic L4REDIRECT redirect to group ISG_GROUP ! class type traffic default input drop ! ! policy-map type service OPENGARDEN_SERVICE 20 class type traffic ISG_OPENGARDEN ! ! policy-map type service PBHK_SERVICE ip portbundle ! policy-map type control TAL class type control IP_UNAUTH_COND event timed-policy-expiry 10 service disconnect ! class type control always event session-start 20 service-policy type service name L4REDIRECT_SERVICE 25 service-policy type service name OPENGARDEN_SERVICE 30 set-timer IP_UNAUTH_TIMER 10 ! class type control always event account-logon 10 authenticate aaa list IP_AUTHEN_LIST 20 service-policy type service unapply name L4REDIRECT_SERVICE 30 service-policy type service unapply name L4REDIRECT_SERVICE ! ! ! ! ! ! interface GigabitEthernet0/0/1.3901 encapsulation dot1Q 3901 ip address 172.28.0.254 255.255.255.0 service-policy type control TAL ip subscriber routed initiator unclassified ip-address ! ! ip access-list extended ACL_1_ACCESS_TO_WIX_IN permit ip any host 10.245.4.6 permit ip any host 8.8.8.8 permit ip any host 10.245.1.6 deny icmp any any echo permit icmp any any deny ip any any ip access-list extended ACL_1_ACCESS_TO_WIX_OUT permit ip any any ip access-list extended ACL_1_REDIRECT_PORTAL_IN permit tcp any any eq www permit tcp any any eq 3128 permit tcp any any eq 443 deny icmp any any echo permit icmp any any ip access-list extended ACL_1_REDIRECT_PORTAL_OUT permit ip any any ip access-list extended ACL_IN_L4REDIRECT permit tcp any any eq www permit tcp any any eq 443 ip access-list extended ACL_IN_OPENGARDEN permit ip any host 8.8.8.8 permit ip host 8.8.8.8 any ip access-list extended ACL_IN_SERVICE_INTERNET permit ip any any ip access-list extended ACL_OUT_OPENGARDEN permit ip host 8.8.8.8 any permit ip any host 8.8.8.8 ip access-list extended ACL_OUT_SERVICE_INTERNET permit ip any any ip access-list extended test permit ip any any log-input ! ip radius source-interface GigabitEthernet0/0/1.3721 ! ! ! radius-server attribute 44 include-in-access-req all radius-server attribute 188 format non-standard radius-server attribute 6 on-for-login-auth radius-server attribute 8 include-in-access-req radius-server attribute 32 include-in-access-req radius-server attribute 32 include-in-accounting-req radius-server attribute 55 include-in-acct-req radius-server attribute 55 access-request include radius-server attribute 25 access-request include radius-server attribute nas-port format d radius-server attribute 61 extended radius-server attribute 31 mac format ietf radius-server attribute 31 send nas-port-detail mac-only radius-server dead-criteria tries 3 radius-server host 10.245.1.6 auth-port 1812 acct-port 1813 key radius-server retransmit 5 radius-server timeout 10 radius-server deadtime 15 radius-server directed-request radius-server domain-stripping radius-server key ! radius server RAD1 address ipv4 10.245.0.10 auth-port 1822 acct-port 1823 Вставить ник Quote
skinner Posted April 1, 2015 Posted April 1, 2015 в профиле ответа радиус надо добавить чегото такое.. subscriber:accounting-list = "IP_SESSION" за синтаксис верный не скажу по разному может писаться потом увидеть что оно повешалось на сессию с абоннентом sh subscriber session identifier source-ip-address 1.1.1.1 255.255.255.255 и появились строчки Accounting: Class-id Dir Packets Bytes Source 0 In 24937 2692239 Peruser 1 Out 31274 34787648 Peruser ну и ловить аккаунтинг на радиусе куда он потом полетит. Вставить ник Quote
ShyLion Posted April 1, 2015 Posted April 1, 2015 Cisco-AVPair subscriber:accounting-list=xxxxx Вставить ник Quote
gadrus42 Posted February 14, 2020 Posted February 14, 2020 Добрый день! Коллеги, помогите пожалуйста, вторую неделю не могу разобраться, что делаю не так. Перепробовал настройки с разных статей. Клиент по DHCP получает ip, но ASR не отправляется никаких запросов в Lanbilling. Оборудование cisco ASR1001 Version 15.3(3)S4 + LAnBilling (он же Radius он же DHCP) Вот мой конфиг: aaa authentication login default local aaa authentication login CONS none aaa authentication login ISG-AUTH-1 group ISG-RADIUS aaa authentication enable default enable aaa authorization network default group ISG-RADIUS aaa authorization network ISG-AUTH-1 group ISG-RADIUS aaa authorization subscriber-service default local aaa authorization subscriber-service ISG-AUTH-1 group ISG-RADIUS aaa authorization console aaa accounting network ISG-AUTH-1 start-stop group ISG-RADIUS aaa accounting delay-start aaa accounting jitter maximum 0 aaa accounting update periodic 1 ! ! ! aaa server radius dynamic-author client 91.109.224.23 server-key client 91.109.224.25 server-key port 1777 auth-type any ignore session-key ignore server-key ! ! radius-server attribute 44 extend-with-addr radius-server attribute 6 on-for-login-auth radius-server attribute 8 include-in-access-req radius-server attribute 32 include-in-access-req radius-server attribute nas-port format d radius-server attribute 31 mac format ietf radius-server dead-criteria time 120 tries 3 radius-server host 91.109.224.23 auth-port 1852 acct-port 1853 radius-server retry method reorder radius-server retransmit 5 radius-server deadtime 3 radius-server key 7 XXXXXXXXXXXXXXXXX radius-server vsa send cisco-nas-port ! aaa group server radius ISG-RADIUS server 91.109.224.23 auth-port 1852 acct-port 1853 server 91.109.224.25 auth-port 1852 acct-port 1853 ip radius source-interface Port-channel10.10 access-list 197 permit tcp any any eq www access-list 197 permit tcp any eq www any access-list 197 deny ip any any access-list 198 permit udp any any eq domain access-list 198 permit udp any eq domain any access-list 198 permit tcp any host 91.109.224.25 eq www access-list 198 permit tcp any host 91.109.224.25 eq 443 access-list 198 permit tcp any host 91.109.224.7 eq www access-list 198 permit tcp any host 91.109.224.7 eq 443 access-list 198 permit tcp any host 192.168.77.20 eq www access-list 198 permit icmp any any access-list 198 deny ip any any interface Port-channel10.97 description IPoE_ISG_FIXA encapsulation dot1Q 97 vrf forwarding ipoe ip address 10.97.1.1 255.255.255.252 no ip redirects no ip unreachables no ip proxy-arp service-policy type control ISG-CUSTOMERS-POLICY ip subscriber routed initiator unclassified ip-address policy-map type control ISG-CUSTOMERS-POLICY class type control ISG-IP-UNAUTH event timed-policy-expiry 1 service disconnect ! class type control always event session-start 10 authorize aaa list ISG-AUTH-1 identifier source-ip-address 20 set-timer UNAUTH-TIMER 3 30 service-policy type service name SERVICE-TRUSTED 40 service-policy type service name LOCAL_L4R ! class type control always event radius-timeout 1 service-policy type service name SERVICE-TRUSTED 2 service-policy type service name LOCAL_L4R ! class type control always event session-restart 10 authorize aaa list ISG-AUTH-1 identifier source-ip-address 20 set-timer UNAUTH-TIMER 3 30 service-policy type service name SERVICE-TRUSTED 40 service-policy type service name LOCAL-L4R ! class type control always event account-logoff 1 service disconnect delay 5 Благодарю за помощь! Вставить ник Quote
