paiik Posted March 20, 2015 Posted March 20, 2015 (edited) Подскажите что я делаю не так. мучаюсь уже 3 день настройки провайдера 192.168.137.78 255.255.255.0 шлюз 192.168.137.1 dns 195.88.112.2 vpn 195.88.112.22 vpn соединение устанавливается и пишет connent но интернета нет в сети и на wifi [admin@MikroTik] > export compact # jan/02/1970 00:19:27 by RouterOS 5.25 # software id = U5XF-JAKA # /interface bridge add arp=proxy-arp l2mtu=1598 name=bridge1 /interface wireless set 0 band=2ghz-b/g/n disabled=no distance=indoors ht-rxchains=0,1 ht-txchains=0,1 hw-protection-mode=rts-cts l2mtu=2290 mode=ap-bridge periodic-calibration=enabled ssid=\ Tik tx-power=18 tx-power-mode=all-rates-fixed wds-default-bridge=bridge1 wds-mode=dynamic wireless-protocol=802.11 /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=passthrough group-ciphers=tkip,aes-ccm mode=dynamic-keys unicast-ciphers=tkip,aes-ccm \ wpa-pre-shared-key=1234567890 wpa2-pre-shared-key=1234567890 /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m /ip pool add name=dhcp_pool1 ranges=192.168.0.2-192.168.0.254 /ip dhcp-server add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1 /interface pptp-client add add-default-route=yes allow=chap connect-to=195.88.112.22 disabled=no name=pptp-out1-ard password=******* profile=default user=******** /interface bridge port add bridge=bridge1 interface=ether2 add bridge=bridge1 interface=ether3 add bridge=bridge1 interface=ether4 add bridge=bridge1 interface=ether5 add bridge=bridge1 interface=wlan1 /ip address add address=192.168.0.1/24 interface=bridge1 add address=192.168.137.78/24 interface=ether1 /ip dhcp-server network add address=192.168.0.0/24 dns-server=195.88.112.2,192.168.0.1,195.88.112.3,8.8.8.8 gateway=192.168.0.1 /ip dns set allow-remote-requests=yes servers=195.88.112.2,195.88.112.3,8.8.8.8 /ip firewall nat add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.0.0/24 /ip neighbor discovery set wlan1 disabled=yes /ip route add check-gateway=ping distance=1 gateway=192.168.137.1 /ip service set telnet disabled=yes set ftp disabled=yes /ip upnp set enabled=yes /ip upnp interfaces add interface=bridge1 type=internal add interface=ether1 type=external add interface=pptp-out1-ard type=external /system leds set 0 interface=wlan1 [admin@MikroTik] > Edited March 22, 2015 by paiik Вставить ник Quote
EShirokiy Posted March 21, 2015 Posted March 21, 2015 Шлюз провайдера не проставлен Вставить ник Quote
paiik Posted March 21, 2015 Author Posted March 21, 2015 А на микротике интернет есть? да на микромире пишет что вон connected пинг яндекса идет Мту не великоват? что это тако и где мяту выставлять? Шлюз провайдера не проставлен где его нужно проставить подскажите плиз Вставить ник Quote
EShirokiy Posted March 21, 2015 Posted March 21, 2015 ip - routes, добавьте новый маршрут где dst.source: 0.0.0.0/0 gateway: 192.168.137.1 и все, нажимайте ОК Вставить ник Quote
divxl Posted March 22, 2015 Posted March 22, 2015 (edited) Стоит у него шлюз. /ip route add check-gateway=ping distance=1 gateway=192.168.137.1 Мту меняется в настройках бриджа. Попробуйте указать 1500. Edited March 22, 2015 by divxl Вставить ник Quote
paiik Posted March 22, 2015 Author Posted March 22, 2015 (edited) Стоит у него шлюз. /ip route add check-gateway=ping distance=1 gateway=192.168.137.1 Мту меняется в настройках бриджа. Попробуйте указать 1500. По мту, у меня стоит 1500 а L2 MTU 1598 А интернет я запустил. Всем спасибо кто помогал. Решил проблемму отключив маршрут dst 0.0.0.0/0 get 192.168.137.1 dist 1 # jan/02/1970 00:43:30 by RouterOS 5.25 # software id = U5XF-JAKA # /interface bridge add arp=proxy-arp l2mtu=1598 name=bridge1 /interface wireless set 0 band=2ghz-b/g/n disabled=no distance=indoors ht-rxchains=0,1 ht-txchains=0,1 hw-protection-mode=rts-cts l2mtu=2290 mode=ap-bridge periodic-calibration=enabled ssid=\ Tik tx-power=18 tx-power-mode=all-rates-fixed wds-default-bridge=bridge1 wds-mode=dynamic wireless-protocol=802.11 /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=passthrough group-ciphers=tkip,aes-ccm mode=dynamic-keys unicast-ciphers=tkip,aes-ccm \ wpa-pre-shared-key=tksc6fdk wpa2-pre-shared-key=tksc6fdk /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m /ip pool add name=dhcp_pool1 ranges=192.168.0.2-192.168.0.254 /ip dhcp-server add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1 /interface pptp-client add add-default-route=yes allow=chap connect-to=195.88.112.22 disabled=no name=pptp-out1-ard password=!!!!!!! profile=default user=!!!!!!! /interface bridge port add bridge=bridge1 interface=ether2 add bridge=bridge1 interface=ether3 add bridge=bridge1 interface=ether4 add bridge=bridge1 interface=ether5 add bridge=bridge1 interface=wlan1 /ip address add address=192.168.0.1/24 interface=bridge1 add address=192.168.137.78/24 interface=ether1 /ip dhcp-server network add address=192.168.0.0/24 dns-server=195.88.112.2,192.168.0.1,195.88.112.3,8.8.8.8 gateway=192.168.0.1 /ip dns set allow-remote-requests=yes servers=195.88.112.2,195.88.112.3,8.8.8.8 /ip firewall nat add action=masquerade chain=srcnat out-interface=pptp-out1-ard src-address=192.168.0.0/24 add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.0.0/24 /ip neighbor discovery set wlan1 disabled=yes /ip route add disabled=yes distance=1 gateway=192.168.137.1 add distance=1 dst-address=192.168.137.1/32 gateway=ether1 add distance=1 dst-address=195.88.112.22/32 gateway=192.168.137.1 /ip service set telnet disabled=yes set ftp disabled=yes /ip upnp set enabled=yes /ip upnp interfaces add interface=bridge1 type=internal add interface=ether1 type=external add interface=pptp-out1-ard type=external /system leds set 0 interface=wlan1 Edited March 22, 2015 by paiik Вставить ник Quote
