Коллеги, нужнен свитч на замну 6500 (ядро и агрегация). Необходима высокая плотность 1/10 gbit портов на 2 юнита (приблизительно 90 портов), резервирование плат, супервизоров, блоков питания, фичи BGP, OSPF, VRF, MPLS, Selective QinQ, PIM. И чтобы порты были без переподиски. Что подскажете? Может Juniper или Extreme, желательно дешевле циски nexus 7000.
С такими требованиями не на форуме спрашать, а встречаться с представителями.
EX4550 или EX4600.
GPL
EX4550-32F-AFI, 32-port  1/10G SFP+, Converged switch, 650W AC PS, PSU side to  Built in Port Side air flow (optics sold separately)	$19 000
EX4550-32F-AFO, 32-port  1/10G SFP+, Converged switch, 650W AC PS, Built in Port Side to PSU side air flow  (optics sold separately)	$19 000
EX4550-32F-DC-AFI, 32-port  1/10G SFP+, Converged switch, 650W DC PS, PSU side to Built in Port Side air flow (optics sold separately)	$21 500
EX4550-32F-DC-AFO, 32-port  1/10G SFP+, Converged switch, 650W DC PS, Built in Port Side to PSU side air flow  (optics sold separately)	$21 500
EX4550-32T-AFI, 32-port  100M/1G/10G BaseT, Converged switch, 650W AC PS, PSU side to  Built in Port Side air flow 		        $20 500
EX4550-32T-AFO, 32-port  100M/1G/10G BaseT, Converged switch, 650W AC PS, Built in Port Side to PSU side air flow  	                $20 500
EX4550-32T-DC-AFI, 32-port  100M/1G/10G BaseT, Converged switch, 650W DC PS, PSU side to Built in Port Side air flow 	                $23 000
EX4550-32T-DC-AFO, 32-port  100M/1G/10G BaseT, Converged switch, 650W DC PS, Built in Port Side to PSU side air flow  		        $23 000
EX4600-40F-AFI, 24 SFP+/SFP ports, 4 QSFP+ ports, 2 expansion slots, redundant fans, 2 AC power supplies, back to front airflow	        $23 000
EX4600-40F-AFO, 24 SFP+/SFP ports, 4 QSFP+ ports, 2 expansion slots, redundant fans, 2 AC power supplies, front to back airflow	EX4600	$23 000
EX4600-40F-DC-AFI, 24 SFP+/SFP ports, 4 QSFP+ ports, 2 expansion slots, redundant fans, 2 DC power supplies, back to front  airflow	$24 500
EX4600-40F-DC-AFO, 24 SFP+/SFP ports, 4 QSFP+ ports, 2 expansion slots, redundant fans, 2 DC power supplies, front to back airflow	$24 500
Edited by fomka31ru
вообще слишком много хотелок для свитча. такого не бывает же. :)
но если хочется всё и сразу, то специально для вас сделали икстрим X670 V2 - 72 десятки в одном юните ! :)
EX4550 или EX4600.
4550 не умеют мплс де-факто. ex4600 = qfx5100, тогда уж 5100 советовать с его 96 10ками в 2RU. оно и мплс пытается уметь и вообще. но цена порта кусается.
Коллеги, кто не понял, естественно 2 юнита - это только платы портов, супервизоры отдельно. Juniper - интересно, но дешевле-ли циски?
Тут основная суть в том, что 6500 не может обеспечить высокую плотность 10 gbit без переподписки и не умеет selective qinq.
Edited by Merridius
можно собрать на huawei s93, одну плату 40x10GE и одну 48x1GE. но таблицы l3/l2 там не очень большие, как asbr или жирный PE не получится/лучше не использовать, как P или для vll вполне можно
по фичам есть всё
Ex4600 != qfx хотя ооочень похожи. И я написал ех4550, не 4500. И мплс там в норм...был :)
EX4600 и QFX5100 - это одна и та же платформа: потроха, софт, - всё одно. разница - это распиленная коробка 4600 на модули. обычный маркетинг. т.е. 4600 дешевле, но только из-за меньшего количества портов, цена порта та же.
45ые же кроме кросс-коннектов ничего не умеют, кому оно надо ? посмотри в фиченавигатор: 4500 = 4550. это вобщем-то тоже почти одно и тоже.
Huawei стремно, наслышан много плохого. Таблицы нужны 256К на v4 или выше.
современный маркетинг делит железки на свичи и маршрутизаторы, всё что 512К и больше - маршрутизаторы. всё что 256К и меньше - свитчи. ну и все вытекающие с ценой порта и их плотностью.
я пытаюсь сказать что вам надо подумать над требованиями которые вы предъявляете. иначе можно выбрать звездолет, который всё равно не будет удовлетворять всем требованиям, не говоря уж о цене. :)
Edited by pfexec
я понимаю если б требование было 1М или выше, но откуда берётся требование 256К v4-префиксов?
хотите железку под fv с таким количеством портов и без переподписки? готовьтесь покупать самолёт
1. чтобы не хуже чем у старушки 65ой ^)
2. берем, фильтруем все что длинее /16 и вуаля, глобалвью влез \@/
3. просто чтобы было больше чем 12к как во всех свищах, ведь он новый ^__^
4. чтобы потратить больше денег на железку и откатить кусочек ;)
используем в ядре extreme x670-48x две штуки. соединены по LACP 4х10G. еще каждый по 2x10G на бордер. используем почти все: VPLS, L3VPN MPLS, BGP, OSPF, PIM/MSDP, PBR, mirroring. к ним еще примерно 30 Extreme по городу подключены. Софт стабильный 15.3.1.4
Схема выдерживает полное отключение одного из коммутаторов с некоторой деградацией по полосе в ЧНН. Если надо много маршрутов, то есть новая версия X670-G2-48x-4q с более толстым TCAM
Layer 2 / MAC Addresses: 288K
IPv4 Host Addresses: 136K
IPv4 LPM Entries: 16K
IPv6 Host Addresses: 48K
IPv6 LPM Entries: 8K
+1
У нас точно также. Только у нас на пул брасов 8x10G то есть с каждого x670 по 4-е линка через MLAG.
Схема переживает отключение одного из двух x670 с небольшой деградацией в ЧНН.
Если 6500 не устраивает только плотностью портов, то тогда для этого есть 6880-X. 80 10G портов в 4.85RU.
А, кстати, раз уж речь о этом девайсе зашла, то, может, подскажите как у него дела с узкими местами и переподписками?
При таком количестве хотелок, посоветовать можно только губозакаточную машинку. Если весь упомянутый функционал хочется задействовать в рамках одной железки - забудьте про "2 юнита" и "дешевле циски nexus 7000", и морально готовьтесь к asr 9006 с картами 36x10 и rp не ниже 440. В противном случае, поумерьте аппетиты - у "пицца-бокс" всегда есть определенные ограничения. С такими хотелками решение на базе x670 не подойдет, в том числе и на базе X670-G2. Расписывать почему да как - не буду, просто поверьте на слово, железка предназначена несколько для других задач. Можно в принципе сделать комби-схему: 2X asr9k1 + 2x x670, тогда вы получите все и сразу и с приличным запасом прочности, но цена решения уже не очень красивая и смысл теряется, если можно планировать сразу 9k6/rp440.
48 1/10GbE SFP+ + 4 40GbE QSFP+ Quanta T3048-LY2R 10/40G BM switch preloaded with ONIE - $4,090.00
ставим 2 штуки... все влезает в 2U :)
оно bgp не умеет :D
хотя, странно, что при такой цене, оно вообще что-то умеет.
плюсуюсь к вопросу. Ни разу сам не щупал 6880-x, да и упоминаний их не видно ни в мейллистах, ни на форумах, ни во всяких вебинарах
