в процессе. потом выложу результат после поднятия)
Physical interface: xe-0/0/2
   Laser bias current                        :  24.215 mA
   Laser output power                        :  0.8640 mW / -0.63 dBm
   Module temperature                        :  33 degrees C / 92 degrees F
   Laser rx power                            :  0.3646 mW / -4.38 dBm
   Laser bias current high alarm             :  Off
   Laser bias current low alarm              :  Off
   Laser bias current high warning           :  Off
   Laser bias current low warning            :  Off
   Laser output power high alarm             :  Off
   Laser output power low alarm              :  Off
   Laser output power high warning           :  Off
   Laser output power low warning            :  Off
   Module temperature high alarm             :  Off
   Module temperature low alarm              :  Off
   Module temperature high warning           :  Off
   Module temperature low warning            :  Off
   Laser rx power high alarm                 :  Off
   Laser rx power low alarm                  :  Off
   Laser rx power high warning               :  Off
   Laser rx power low warning                :  Off
   Module not ready alarm                    :  Off
   Module power down alarm                   :  Off
   Tx data not ready alarm                   :  Off
   Tx not ready alarm                        :  Off
   Tx laser fault alarm                      :  Off
   Tx CDR loss of lock alarm                 :  Off
   Rx not ready alarm                        :  Off
   Rx loss of signal alarm                   :  Off
   Rx CDR loss of lock alarm                 :  Off
   Laser bias current high alarm threshold   :  115.000 mA
   Laser bias current low alarm threshold    :  2.000 mA
   Laser bias current high warning threshold :  110.000 mA
   Laser bias current low warning threshold  :  5.000 mA
   Laser output power high alarm threshold   :  2.5100 mW / 4.00 dBm
   Laser output power low alarm threshold    :  0.3980 mW / -4.00 dBm
   Laser output power high warning threshold :  2.2380 mW / 3.50 dBm
   Laser output power low warning threshold  :  0.4460 mW / -3.51 dBm
   Module temperature high alarm threshold   :  100 degrees C / 212 degrees F
   Module temperature low alarm threshold    :  -25 degrees C / -13 degrees F
   Module temperature high warning threshold :  95 degrees C / 203 degrees F
   Module temperature low warning threshold  :  -20 degrees C / -4 degrees F
   Laser rx power high alarm threshold       :  1.7783 mW / 2.50 dBm
   Laser rx power low alarm threshold        :  0.0141 mW / -18.51 dBm
   Laser rx power high warning threshold     :  1.5849 mW / 2.00 dBm
   Laser rx power low warning threshold      :  0.0158 mW / -18.01 dBm
Поделиться сообщением
Ссылка на сообщение
Поделиться на других сайтах
в 3-ей версии прошивки на 3612/3627 уровень мощности может показываться как в милливаттах, так и в децибелах
как ?
Ссылка на сообщение
как ?
config ddm power_unit [mw | dbm]
Ссылка на сообщение
Ссылка на сообщение
нифига не понял как палятся- сам варил все и вся под излучением и никаких прблем. сигнала на трансивер хоть как больше чем было не прилетит.
мне рассказывали такую легенду что SFP сама подстраивается под сигнал, мол если затухание норм то бъет не на полную, а если линк лежит то долбит на всю...
видимо во время восстановления как раз тот момент когда максимум мощности
хз правда или нет))
Так в теории можно и на глазу трансивером зрение поправить, особенно 10G))))
Ссылка на сообщение
it-service, главное, использовать двухволоконный модуль и светить сразу в оба глаза) еще надо модули на 80км использовать, для лучшего эффекта
Ссылка на сообщение
Коллеги, всем доброго времени суток. Подниму тему.
Несколько дней назад в логах на EX4200 посыпалось:
LACPD_TIMEOUT: xe-4/1/0: lacp current while timer expired current Receive State: CURRENT
KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-4/1/0 - CD state - ready to carry traffic
KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-4/1/0 - ATTACHED state - acting as standby link
Но ae не рассыпался, все работало. Сегодня ночью ситуация изменилась в худшую сторону, линк стал up/down и очень часто:
SNMP_TRAP_LINK_DOWN: ifIndex 786, ifAdminStatus up(1), ifOperStatus down(2), ifName xe-4/1/0
: port status changed
KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-4/1/0 - DETACHED state - will not carry traffic
Посмотрел show interfaces diagnostics optics xe-4/1/0
Physical interface: xe-4/1/0
   Laser bias current                        :  [b]77.790 mA[/b]
   Laser output power                        :  [b]0.2370 mW / -6.25 dBm[/b]
   Module temperature                        :  39 degrees C / 102 degrees F
   Laser rx power                            :  0.4963 mW / -3.04 dBm
   [b]Laser bias current high alarm             :  On[/b]
   [b]Laser bias current high warning           :  On[/b]
   [b]Laser bias current high alarm threshold   :  70.000 mA[/b]
   Laser bias current low alarm threshold    :  20.000 mA
   Laser bias current high warning threshold :  65.000 mA
   Laser bias current low warning threshold  :  25.000 mA
   Laser output power high alarm threshold   :  1.4120 mW / 1.50 dBm
   Laser output power low alarm threshold    :  0.1990 mW / -7.01 dBm
   Laser output power high warning threshold :  1.2580 mW / 1.00 dBm
   Laser output power low warning threshold  :  0.2230 mW / -6.52 dBm
   Module temperature high alarm threshold   :  78 degrees C / 172 degrees F
   Module temperature low alarm threshold    :  13 degrees C / 55 degrees F
   Module temperature high warning threshold :  75 degrees C / 167 degrees F
   Module temperature low warning threshold  :  10 degrees C / 50 degrees F
   Laser rx power low alarm threshold        :  0.0100 mW / -20.00 dBm
Итого, похоже пушной зверек пришел лазеру на модуле. На другом интерфейсе с этого же ae:
Physical interface: xe-3/1/0
   Laser bias current                        :  [b]34.257 mA[/b]
   Laser output power                        :  [b]0.6300 mW / -2.01 dBm[/b]
   Module temperature                        :  39 degrees C / 101 degrees F
   Laser rx power                            :  0.0996 mW / -10.02 dBm
Интерфейс пока в disabled, но вывод верный - модуль под замену?
Ссылка на сообщение
А что за модули то стоят?
Какие у них характиристики заявленные по доке смотрели?
Ссылка на сообщение
Оба модуля 740-014279 XFP-10G-LR Juniper Networks SXP310NV-J3 OC192-SR1/10G-L
При этом на "больном" модуле при токе лазера 77.790 mA выходная мощность 0.2370 mW / -6.25 dBm, а на "здоровом" модуле при токе лазера 34.257 mA выходная мощность 0.6300 mW / -2.01 dBm.
Оба трансивера смотрят на сервак, патч 10 метров.
Ссылка на сообщение
скорее да, чем нет. датчик яркости встроен по идее в сам лазер - т.е. никакие посторонние явления типа пыли на него повлиять не могут.
Ссылка на сообщение
Port    Temperature   Voltage    Bias Current   TX Power     RX Power
       (in Celsius)     (V)         (mA)         (mW)         (mW)
 1       55.9453      3.305        23.348       0.2674       0.2604
.1.3.6.1.4.1.171.12.72.2.1.1.1.2.(№_порта) - This object indicates the real time value of the temperature. As the value is a floating point data type, the DisplayString type is used to define this parameter.
.1.3.6.1.4.1.171.12.72.2.1.1.1.3.(№_порта) - This object indicates the real time value of the supply voltage. As the is a floating point data type, the DisplayString type is used to define this parameter.
.1.3.6.1.4.1.171.12.72.2.1.1.1.4.(№_порта) - This object indicates the real time value of the tx bias.
.1.3.6.1.4.1.171.12.72.2.1.1.1.5.(№_порта) - This object indicates the real time value of the tx power. As the value is a floating point data type, the DisplayString type is used to define this parameter.
.1.3.6.1.4.1.171.12.72.2.1.1.1.6.(№_порта) - This object indicates the real time value of the rx power. As the value is a floating data type, the DisplayString type is used to define this parameter.
А какие OID что бы добавить в мониторинг The Dude эти параметры?
Изменено пользователем planhima
Ссылка на сообщение
Гость
Ответить в тему...
