У кого-то получилось заставить работать?
Имеется следующий тестовый конфиг:
service password-encryption
username admin privilege 15 password 7 *****
authentication line console login local
clock timezone MSK add 3 0
snmp-server enable
snmp-server community ro 7 *****
service dhcp
ip forward-protocol udp bootps
ip dhcp relay information option
ip dhcp snooping enable
ip dhcp snooping vlan 19-21
ip dhcp snooping binding enable
ip dhcp snooping binding arp
ip dhcp snooping information enable
ip dhcp snooping information option allow-untrusted
ip dhcp snooping information option subscriber-id format hex
spanning-tree
dns-server 192.168.50.249 priority 1
dns-server 192.168.50.250
vlan 1
vlan 10
name Management
vlan 19
name Users1
vlan 20
name Users2
vlan 21
name Users3
vlan 36
name SNR-S3750-uplink
vlan 2
name Users
supervlan
subvlan 19-21
Interface Ethernet1/0/1
Interface Ethernet1/0/2
Interface Ethernet1/0/3
Interface Ethernet1/0/4
Interface Ethernet1/0/5
Interface Ethernet1/0/6
Interface Ethernet1/0/7
Interface Ethernet1/0/8
Interface Ethernet1/0/9
Interface Ethernet1/0/10
Interface Ethernet1/0/11
Interface Ethernet1/0/12
Interface Ethernet1/0/13
Interface Ethernet1/0/14
Interface Ethernet1/0/15
Interface Ethernet1/0/16
Interface Ethernet1/0/17
Interface Ethernet1/0/18
Interface Ethernet1/0/19
media-type copper
switchport mode trunk
switchport trunk allowed vlan 19
switchport trunk native vlan 19
ip dhcp snooping binding user-control
ip dhcp snooping binding user-control max-user 30
ip dhcp snooping action blackhole recovery 30
Interface Ethernet1/0/20
media-type copper
switchport trunk allowed vlan 20
switchport trunk native vlan 20
Interface Ethernet1/0/21
media-type copper
switchport trunk allowed vlan 21
switchport trunk native vlan 21
Interface Ethernet1/0/22
media-type copper
description UpLink
switchport trunk allowed vlan 10;36
ip dhcp snooping trust
Interface Ethernet1/0/23
Interface Ethernet1/0/24
Interface Ethernet1/0/25
Interface Ethernet1/0/26
Interface Ethernet1/0/27
Interface Ethernet1/0/28
interface Vlan2
ip pim sparse-mode
ip local proxy-arp
ip address 192.168.254.1 255.255.255.0
 !forward protocol udp 67(active)!
ip helper-address 192.168.50.250
ip helper-address 192.168.50.249
interface Vlan10
ip address 10.244.11.1 255.255.0.0
interface Vlan36
ip ospf mtu-ignore
ip pim sparse-mode
ip address 192.168.2.194 255.255.255.252
ip pim multicast-routing
router ospf 100
ospf router-id 10.244.11.1
log-adjacency-changes detail
network 192.168.2.0 0.0.0.255 area 100
redistribute connected
redistribute static
summary-address 192.168.254.0/24
ntp enable
ntp server 192.168.50.249
no login
end
Версия прошивки последняя доступная на data.nag.ru 7.0.3.5(B207.0008).
av151-snr-3750G-24s#sh ver
 SNR-S3750G-24S-E Device, Compiled on May 19 09:16:44 2014
 sysLocation Test location
 CPU Mac f8:f0:82:10:1a:ed
 Vlan MAC f8:f0:82:10:1a:ec
 SoftWare Version 7.0.3.5(B0207.0008)
 BootRom Version 7.1.4
 HardWare Version 1.0.2
 CPLD Version N/A
 Serial No.:SW032710D608000027
 Copyright (C) 2014 NAG LLC
 All rights reserved
 Last reboot is warm reset.
 Uptime is 0 weeks, 0 days, 0 hours, 13 minutes
Проблемы такие:
1. После получения адреса по DHCP шлюз не пингуется по причине того, что он не отвечает на APR запросы. Иногда отвечает и после этого пинг идет и все начинает работать.
# arping -I eth1 192.168.254.1
ARPING 192.168.254.1 from 192.168.254.128 eth1
^CSent 16 probes (16 broadcast(s))
Received 0 response(s)
#sh mac-address-table | inc 00-14-d1-16-8c-c6
21   00-14-d1-16-8c-c6           STATIC  App      Ethernet1/0/21
av151-snr-3750G-24s#sh arp | inc 00-14-d1-16-8c-c6
192.168.254.128  00-14-d1-16-8c-c6  Vlan2         Ethernet1/0/21  Dynamic   298                 21
2. После релиза адреса полученного по DHCP, запись из биндингов иногда пропадает, а иногда так и остается висеть и никакой последующий релиз это уже не изменит.
# dhclient eth1
# ifconfig eth1
eth1      Link encap:Ethernet  HWaddr 00:14:d1:16:8c:c6
         inet addr:192.168.254.128  Bcast:192.168.254.255  Mask:255.255.255.0
         inet6 addr: fe80::214:d1ff:fe16:8cc6/64 Scope:Link
         UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
         RX packets:150609 errors:0 dropped:0 overruns:0 frame:0
         TX packets:87703 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:63035649 (63.0 MB)  TX bytes:40125910 (40.1 MB)
         Interrupt:16 Base address:0xb000
# dhclient -r eth1
# ifconfig eth1
         TX packets:87704 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:63035649 (63.0 MB)  TX bytes:40125970 (40.1 MB)
av151-snr-3750G-24s#sh ip dhcp snooping binding all
ip dhcp snooping static binding count:0, dynamic binding count:1
MAC                 IP address          Interface           Vlan ID   Flag
00-14-d1-16-8c-c6   192.168.254.128     Ethernet1/0/21      21        DL
3. Команда ip dhcp snooping binding arp не играет никакой роли. Запись в FDB таблице всегда создается статическая, а в ARP таблице динамическая.
av151-snr-3750G-24s#sh mac-address-table | inc 00-14-d1-16-8c-c6
192.168.254.128  00-14-d1-16-8c-c6  Vlan2         Ethernet1/0/21  Dynamic   885                 21
Edited by SokolovS
