Angell5 Posted January 25, 2003 Posted January 25, 2003 Есть FreeBSD 4.5- RELEASE. Там стоят сервер CS VAC-эмулятор HLmaster apache ssh и ftpd. Поставил mpd-netgraph порт настроил так: mpd.conf default: load pptp # PPTP Server pptp: set debug 3 set log +pptp +pptp2 +pptp3 +lcp +auth +ccp new -i ng0 pptp pptp set bundle disable multilink set bundle enable compression set bundle enable encryption set bundle yes crypt-reqd set iface disable on-demand set iface disable proxy-arp set iface idle 1800 # set ipcp ranges 192.168.1.1/30 192.168.1.2/30 set ipcp ranges 193.220.131.62/26 193.220.131.1/26 set ipcp dns 193.220.131.62 # set ipcp nbns 193.220.131.62 set ipcp enable vjcomp set link yes acfcomp protocomp set link no pap chap set link enable chap set link keep-alive 10 60 # If remote machine is NT you need this.. # set link enable no-orig-auth set ccp enable mppc set ccp enable mpp-compress set ccp enable mpp-e40 set ccp enable mpp-e128 set ccp enable mpp-stateless mpd.links pptp: set link type pptp set pptp self 193.220.131.62 set pptp enable incoming set pptp disable originate Все как живое но неработает попробовал посканить порт закрыт рядом w2000 пускает конектится пробовал 98 ... Интерфейс ng0 создается но неконфигуренный, тоесть без ip. bw_man на этой машине работал без проблем а он тоже через netgraph. В логи сыпятся : Jan 25 12:00:00 cserver newsyslog[315]: logfile turned over Jan 25 12:00:02 cserver mpd: mpd: pid 323, version 3.6 (root@cserver.concord.net.ua 09:21 21-Jan-2003) Jan 25 12:00:02 cserver mpd: mpd: already running as process 210 Jan 25 12:00:07 cserver mpd: mpd: pid 324, version 3.6 (root@cserver.concord.net.ua 09:21 21-Jan-2003) Jan 25 12:00:07 cserver mpd: mpd: caught fatal signal term Jan 25 12:00:07 cserver mpd: mpd: waiting for process 210 to die... Jan 25 12:00:07 cserver mpd: [pptp] IPCP: Down event Jan 25 12:00:07 cserver mpd: [pptp] IFACE: Close event Jan 25 12:00:08 cserver mpd: mpd: waiting for process 210 to die... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=7 addr="ng0:" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 26 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd shutdown (1) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=14 addr="bypass.inet" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 28 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 29 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: mpd: process 210 terminated Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=4 addr="." } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: RECEIVED RESPONSE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=4 addr="." } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 40 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (40 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0010: 73 6f 63 6b 65 74 00 00 00 00 00 00 00 00 00 00 socket.......... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0020: 14 00 00 00 00 00 00 00 ........ Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=7 addr="ng0:" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: [error decoding message: No such file or directory] Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: sendto(ng0:): No such file or directory Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=7 addr="ng0:" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 4 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: [error decoding message: No such file or directory] Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: sendto(ng0:): No such file or directory Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=4 addr="." } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 48 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (48 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 69 66 61 63 65 00 08 28 30 d5 09 28 50 a4 09 28 iface..(0..(P..( Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0010: 74 65 6d 70 68 6f 6f 6b 00 f0 bf bf e4 79 07 28 temphook.....y.( Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0020: 69 6e 65 74 00 b2 08 28 18 f0 bf bf 17 7a 07 28 inet...(.....z.( Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=11 addr="temphook" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 7 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: RECEIVED RESPONSE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=11 addr="temphook" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 40 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 7 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (40 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 6e 67 30 00 00 00 00 00 00 00 00 00 00 00 00 00 ng0............. Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0010: 69 66 61 63 65 00 00 00 00 00 00 00 00 00 00 00 iface........... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0020: 17 00 00 00 01 00 00 00 ........ Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=4 addr="." } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 16 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 8 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 5 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (16 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 74 65 6d 70 68 6f 6f 6b 00 f0 bf bf b3 79 07 28 temphook.....y.( Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=7 addr="ng0:" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 9 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd nodeinfo (6) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args Jan 25 12:00:09 cserver mpd: [pptp] netgraph: RECEIVED RESPONSE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=7 addr="ng0:" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 40 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 9 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd nodeinfo (6) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args { name="ng0" type="iface" id=0x17 } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=4 addr="." } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 48 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 12 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (48 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 70 70 70 00 a0 b2 07 08 63 b2 07 08 b4 07 00 00 ppp.....c....... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0010: 62 79 70 61 73 73 00 08 64 86 1d 28 0f 00 00 00 bypass..d..(.... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0020: 62 79 70 61 73 73 00 08 13 00 00 00 b4 07 00 00 bypass.......... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 16 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 13 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 4 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (16 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 6d 70 64 33 32 34 2d 70 70 74 70 00 dc f5 bf bf mpd324-pptp..... Jan 25 12:00:09 cserver mpd: [pptp] ppp node is "mpd324-pptp" Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 14 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: RECEIVED RESPONSE: Jan 25 12:00:09 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:09 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:09 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: arglen 40 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: flags 1 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: token 14 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: cmd 6 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: args (40 bytes) Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0000: 6d 70 64 33 32 34 2d 70 70 74 70 00 00 00 00 00 mpd324-pptp..... Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0010: 70 70 70 00 00 00 00 00 00 00 00 00 00 00 00 00 ppp............. Jan 25 12:00:09 cserver mpd: [pptp] netgraph: 0020: 1a 00 00 00 01 00 00 00 ........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 48 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 15 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (48 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 62 70 66 00 a0 b2 07 08 63 b2 07 08 b4 07 00 00 bpf.....c....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 69 6e 65 74 00 73 00 08 64 86 1d 28 0f 00 00 00 inet.s..d..(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 70 70 70 00 73 73 00 08 13 00 00 00 b4 07 00 00 ppp.ss.......... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=14 addr="bypass.inet" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 544 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 16 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 3 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (544 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 6e 67 30 3a 00 00 00 00 04 00 00 00 00 00 00 00 ng0:............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 28 f5 bf bf 02 d6 06 08 00 00 00 00 02 d6 06 08 (............... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 00 00 00 00 00 00 00 00 c8 f5 bf bf 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0030: 00 00 00 00 00 00 00 00 15 00 00 00 15 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0040: 00 00 00 00 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0050: 00 00 00 00 00 b4 08 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0060: ff ff ff ff 00 00 00 00 15 00 00 00 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0070: 88 f5 bf bf 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0080: d0 90 00 08 19 e4 15 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0090: 00 00 00 00 80 d0 08 28 00 00 00 00 8b 99 07 28 .......(.......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00a0: 48 8f 04 08 80 d0 08 01 58 f4 bf bf 8b 99 07 28 H.......X......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00b0: d0 90 04 08 a6 05 79 07 00 b4 08 28 01 00 00 00 ......y....(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00c0: ac 77 08 28 00 b0 08 28 00 b0 08 28 de 99 07 28 .w.(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00d0: 00 b4 08 28 60 d0 08 01 c8 f4 bf bf e9 97 07 28 ...(`..........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00e0: 00 b4 08 28 f2 89 ab 01 d8 f4 bf bf e9 97 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00f0: d0 90 04 08 a6 05 79 07 08 67 08 28 c8 f4 bf bf ......y..g.(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0100: 01 00 00 00 cc f4 bf bf 00 b2 08 28 00 b3 08 28 ...........(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0110: 00 b0 08 28 00 b1 08 28 00 b2 08 28 00 b3 08 28 ...(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0120: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0130: ac 77 08 28 00 b0 08 28 d0 90 04 08 a0 00 00 00 .w.(...(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0140: e0 d9 15 28 0c f5 bf 01 00 b4 08 28 00 b4 08 28 ...(.......(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0150: 80 81 15 28 05 00 00 01 05 00 00 00 fc f4 bf bf ...(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0160: 31 bf 1c 28 14 00 00 00 d4 07 00 00 d4 07 00 00 1..(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0170: f6 be 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0180: 01 00 00 00 00 00 00 00 00 c0 07 08 4c f5 bf bf ............L... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0190: 1f bd 1c 28 14 00 00 00 c8 f4 bf bf 1a 81 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01a0: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 d4 07 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01b0: d8 f5 bf bf 14 00 00 00 e0 b2 07 08 04 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01c0: ac 77 08 01 00 b4 08 28 b0 90 07 08 02 00 00 00 .w.....(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01d0: 14 00 00 00 00 c0 07 08 0b 00 00 00 7c f5 bf bf ............|... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01e0: 31 bf 1c 28 d4 07 00 00 64 86 1d 28 29 00 00 00 1..(....d..()... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01f0: f6 be 1c 28 64 86 1d 28 28 f5 bf bf 00 00 00 00 ...(d..((....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0200: 69 66 61 63 65 00 07 08 43 ed 06 08 fc f5 bf bf iface...C....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0210: 69 6e 65 74 00 f5 bf bf 00 d6 06 08 14 f6 bf bf inet............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=4 addr="." } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 544 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 17 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 3 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (544 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 62 79 70 61 73 73 2e 69 6e 65 74 00 00 00 00 00 bypass.inet..... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 28 f5 bf bf 02 d6 06 08 00 00 00 00 02 d6 06 08 (............... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 00 00 00 00 00 00 00 00 c8 f5 bf bf 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0030: 00 00 00 00 00 00 00 00 15 00 00 00 15 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0040: 00 00 00 00 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0050: 00 00 00 00 00 b4 08 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0060: ff ff ff ff 00 00 00 00 15 00 00 00 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0070: 88 f5 bf bf 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0080: d0 90 00 08 19 e4 15 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0090: 00 00 00 00 80 d0 08 28 00 00 00 00 8b 99 07 28 .......(.......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00a0: 48 8f 04 08 80 d0 08 01 58 f4 bf bf 8b 99 07 28 H.......X......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00b0: d0 90 04 08 a6 05 79 07 00 b4 08 28 01 00 00 00 ......y....(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00c0: ac 77 08 28 00 b0 08 28 00 b0 08 28 de 99 07 28 .w.(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00d0: 00 b4 08 28 60 d0 08 01 c8 f4 bf bf e9 97 07 28 ...(`..........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00e0: 00 b4 08 28 f2 89 ab 01 d8 f4 bf bf e9 97 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00f0: d0 90 04 08 a6 05 79 07 08 67 08 28 c8 f4 bf bf ......y..g.(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0100: 01 00 00 00 cc f4 bf bf 00 b2 08 28 00 b3 08 28 ...........(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0110: 00 b0 08 28 00 b1 08 28 00 b2 08 28 00 b3 08 28 ...(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0120: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0130: ac 77 08 28 00 b0 08 28 d0 90 04 08 a0 00 00 00 .w.(...(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0140: e0 d9 15 28 0c f5 bf 01 00 b4 08 28 00 b4 08 28 ...(.......(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0150: 80 81 15 28 05 00 00 01 05 00 00 00 fc f4 bf bf ...(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0160: 31 bf 1c 28 14 00 00 00 d4 07 00 00 d4 07 00 00 1..(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0170: f6 be 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0180: 01 00 00 00 00 00 00 00 00 c0 07 08 4c f5 bf bf ............L... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0190: 1f bd 1c 28 14 00 00 00 c8 f4 bf bf 1a 81 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01a0: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 d4 07 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01b0: d8 f5 bf bf 14 00 00 00 e0 b2 07 08 04 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01c0: ac 77 08 01 00 b4 08 28 b0 90 07 08 02 00 00 00 .w.....(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01d0: 14 00 00 00 00 c0 07 08 0b 00 00 00 7c f5 bf bf ............|... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01e0: 31 bf 1c 28 d4 07 00 00 64 86 1d 28 29 00 00 00 1..(....d..()... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01f0: f6 be 1c 28 64 86 1d 28 28 f5 bf bf 00 00 00 00 ...(d..((....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0200: 64 65 6d 61 6e 64 00 08 43 ed 06 08 fc f5 bf bf demand..C....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0210: 6d 70 64 00 00 f5 bf bf 00 d6 06 08 14 f6 bf bf mpd............. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=11 addr="ng0:inet" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 268 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 18 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie BPF (944100792) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd setprogram (1) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args { thisHook="iface" bpf_prog_len=27 bpf_prog=[ { code=0x30 k=9 } { code=0xb1 } { code=0x15 jt=4 k=2 } { code=0x15 jt=4 k=1 } { code=0x15 jt=11 k=17 } { code=0x15 jt=16 k=6 } { code=0x6 k=4294967295 } { code=0x6 } { code=0x50 } { code=0x15 jf=1 } { code=0x6 } { code=0x15 jf=1 k=3 } { code=0x6 } { code=0x15 jf=1 k=5 } { code=0x6 } { code=0x6 k=4294967295 } { code=0x48 k=2 } { code=0x15 jf=1 k=123 } { code=0x6 } { code=0x15 jf=1 k=24 } { code=0x6 } { code=0x6 k=4294967295 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=11 addr="ng0:inet" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 60 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 20 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie BPF (944100792) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd setprogram (1) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args { thisHook="ppp" bpf_prog_len=1 bpf_prog=[ { code=0x6 } ] } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 48 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 22 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (48 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 76 6a 63 00 a0 b2 07 08 63 b2 07 08 b4 07 00 00 vjc.....c....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 76 6a 63 5f 69 70 00 08 64 86 1d 28 0f 00 00 00 vjc_ip..d..(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 69 70 00 00 73 73 00 08 13 00 00 00 b4 07 00 00 ip..ss.......... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 544 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 23 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 3 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (544 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 76 6a 63 5f 69 70 00 69 6e 65 74 00 00 00 00 00 vjc_ip.inet..... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 28 f5 bf bf 02 d6 06 08 00 00 00 00 02 d6 06 08 (............... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 00 00 00 00 00 00 00 00 c8 f5 bf bf 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0030: 00 00 00 00 00 00 00 00 15 00 00 00 15 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0040: 00 00 00 00 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0050: 00 00 00 00 00 b4 08 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0060: ff ff ff ff 00 00 00 00 15 00 00 00 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0070: 88 f5 bf bf 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0080: d0 90 00 08 19 e4 15 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0090: 00 00 00 00 80 d0 08 28 00 00 00 00 8b 99 07 28 .......(.......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00a0: 48 8f 04 08 80 d0 08 01 58 f4 bf bf 8b 99 07 28 H.......X......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00b0: d0 90 04 08 a6 05 79 07 00 b4 08 28 01 00 00 00 ......y....(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00c0: ac 77 08 28 00 b0 08 28 00 b0 08 28 de 99 07 28 .w.(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00d0: 00 b4 08 28 60 d0 08 01 c8 f4 bf bf e9 97 07 28 ...(`..........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00e0: 00 b4 08 28 f2 89 ab 01 d8 f4 bf bf e9 97 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00f0: d0 90 04 08 a6 05 79 07 08 67 08 28 c8 f4 bf bf ......y..g.(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0100: 01 00 00 00 cc f4 bf bf 00 b2 08 28 00 b3 08 28 ...........(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0110: 00 b0 08 28 00 b1 08 28 00 b2 08 28 00 b3 08 28 ...(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0120: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0130: ac 77 08 28 00 b0 08 28 d0 90 04 08 a0 00 00 00 .w.(...(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0140: e0 d9 15 28 0c f5 bf 01 00 b4 08 28 00 b4 08 28 ...(.......(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0150: 80 81 15 28 05 00 00 01 05 00 00 00 fc f4 bf bf ...(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0160: 31 bf 1c 28 14 00 00 00 d4 07 00 00 d4 07 00 00 1..(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0170: f6 be 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0180: 01 00 00 00 00 00 00 00 00 c0 07 08 4c f5 bf bf ............L... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0190: 1f bd 1c 28 14 00 00 00 c8 f4 bf bf 1a 81 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01a0: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 d4 07 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01b0: d8 f5 bf bf 14 00 00 00 e0 b2 07 08 04 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01c0: ac 77 08 01 00 b4 08 28 b0 90 07 08 02 00 00 00 .w.....(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01d0: 14 00 00 00 00 c0 07 08 0b 00 00 00 7c f5 bf bf ............|... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01e0: 31 bf 1c 28 d4 07 00 00 64 86 1d 28 29 00 00 00 1..(....d..()... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01f0: f6 be 1c 28 64 86 1d 28 28 f5 bf bf 00 00 00 00 ...(d..((....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0200: 76 6a 63 5f 76 6a 63 6f 6d 70 00 08 fc f5 bf bf vjc_vjcomp...... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0210: 76 6a 63 6f 6d 70 00 bf 00 d6 06 08 14 f6 bf bf vjcomp.......... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 544 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 24 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 3 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (544 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 76 6a 63 5f 69 70 00 69 6e 65 74 00 00 00 00 00 vjc_ip.inet..... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 28 f5 bf bf 02 d6 06 08 00 00 00 00 02 d6 06 08 (............... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 00 00 00 00 00 00 00 00 c8 f5 bf bf 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0030: 00 00 00 00 00 00 00 00 15 00 00 00 15 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0040: 00 00 00 00 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0050: 00 00 00 00 00 b4 08 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0060: ff ff ff ff 00 00 00 00 15 00 00 00 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0070: 88 f5 bf bf 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0080: d0 90 00 08 19 e4 15 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0090: 00 00 00 00 80 d0 08 28 00 00 00 00 8b 99 07 28 .......(.......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00a0: 48 8f 04 08 80 d0 08 01 58 f4 bf bf 8b 99 07 28 H.......X......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00b0: d0 90 04 08 a6 05 79 07 00 b4 08 28 01 00 00 00 ......y....(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00c0: ac 77 08 28 00 b0 08 28 00 b0 08 28 de 99 07 28 .w.(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00d0: 00 b4 08 28 60 d0 08 01 c8 f4 bf bf e9 97 07 28 ...(`..........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00e0: 00 b4 08 28 f2 89 ab 01 d8 f4 bf bf e9 97 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00f0: d0 90 04 08 a6 05 79 07 08 67 08 28 c8 f4 bf bf ......y..g.(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0100: 01 00 00 00 cc f4 bf bf 00 b2 08 28 00 b3 08 28 ...........(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0110: 00 b0 08 28 00 b1 08 28 00 b2 08 28 00 b3 08 28 ...(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0120: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0130: ac 77 08 28 00 b0 08 28 d0 90 04 08 a0 00 00 00 .w.(...(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0140: e0 d9 15 28 0c f5 bf 01 00 b4 08 28 00 b4 08 28 ...(.......(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0150: 80 81 15 28 05 00 00 01 05 00 00 00 fc f4 bf bf ...(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0160: 31 bf 1c 28 14 00 00 00 d4 07 00 00 d4 07 00 00 1..(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0170: f6 be 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0180: 01 00 00 00 00 00 00 00 00 c0 07 08 4c f5 bf bf ............L... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0190: 1f bd 1c 28 14 00 00 00 c8 f4 bf bf 1a 81 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01a0: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 d4 07 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01b0: d8 f5 bf bf 14 00 00 00 e0 b2 07 08 04 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01c0: ac 77 08 01 00 b4 08 28 b0 90 07 08 02 00 00 00 .w.....(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01d0: 14 00 00 00 00 c0 07 08 0b 00 00 00 7c f5 bf bf ............|... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01e0: 31 bf 1c 28 d4 07 00 00 64 86 1d 28 29 00 00 00 1..(....d..()... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01f0: f6 be 1c 28 64 86 1d 28 28 f5 bf bf 00 00 00 00 ...(d..((....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0200: 76 6a 63 5f 76 6a 75 6e 63 6f 6d 70 00 f5 bf bf vjc_vjuncomp.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0210: 76 6a 75 6e 63 6f 6d 70 00 d6 06 08 14 f6 bf bf vjuncomp........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:10 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:10 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:10 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: arglen 544 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: token 25 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: cmd 3 Jan 25 12:00:10 cserver mpd: [pptp] netgraph: args (544 bytes) Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0000: 76 6a 63 5f 69 70 00 69 6e 65 74 00 00 00 00 00 vjc_ip.inet..... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0010: 28 f5 bf bf 02 d6 06 08 00 00 00 00 02 d6 06 08 (............... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0020: 00 00 00 00 00 00 00 00 c8 f5 bf bf 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0030: 00 00 00 00 00 00 00 00 15 00 00 00 15 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0040: 00 00 00 00 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0050: 00 00 00 00 00 b4 08 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0060: ff ff ff ff 00 00 00 00 15 00 00 00 00 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0070: 88 f5 bf bf 81 37 07 08 00 00 00 00 81 37 07 08 .....7.......7.. Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0080: d0 90 00 08 19 e4 15 28 00 00 00 00 00 00 00 00 .......(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0090: 00 00 00 00 80 d0 08 28 00 00 00 00 8b 99 07 28 .......(.......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00a0: 48 8f 04 08 80 d0 08 01 58 f4 bf bf 8b 99 07 28 H.......X......( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00b0: d0 90 04 08 a6 05 79 07 00 b4 08 28 01 00 00 00 ......y....(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00c0: ac 77 08 28 00 b0 08 28 00 b0 08 28 de 99 07 28 .w.(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00d0: 00 b4 08 28 60 d0 08 01 c8 f4 bf bf e9 97 07 28 ...(`..........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00e0: 00 b4 08 28 f2 89 ab 01 d8 f4 bf bf e9 97 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 00f0: d0 90 04 08 a6 05 79 07 08 67 08 28 c8 f4 bf bf ......y..g.(.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0100: 01 00 00 00 cc f4 bf bf 00 b2 08 28 00 b3 08 28 ...........(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0110: 00 b0 08 28 00 b1 08 28 00 b2 08 28 00 b3 08 28 ...(...(...(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0120: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0130: ac 77 08 28 00 b0 08 28 d0 90 04 08 a0 00 00 00 .w.(...(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0140: e0 d9 15 28 0c f5 bf 01 00 b4 08 28 00 b4 08 28 ...(.......(...( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0150: 80 81 15 28 05 00 00 01 05 00 00 00 fc f4 bf bf ...(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0160: 31 bf 1c 28 14 00 00 00 d4 07 00 00 d4 07 00 00 1..(............ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0170: f6 be 1c 28 64 86 1d 28 d4 07 00 00 14 00 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0180: 01 00 00 00 00 00 00 00 00 c0 07 08 4c f5 bf bf ............L... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0190: 1f bd 1c 28 14 00 00 00 c8 f4 bf bf 1a 81 07 28 ...(...........( Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01a0: 96 bc 1c 28 64 86 1d 28 d4 07 00 00 d4 07 00 00 ...(d..(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01b0: d8 f5 bf bf 14 00 00 00 e0 b2 07 08 04 00 00 00 ................ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01c0: ac 77 08 01 00 b4 08 28 b0 90 07 08 02 00 00 00 .w.....(........ Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01d0: 14 00 00 00 00 c0 07 08 0b 00 00 00 7c f5 bf bf ............|... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01e0: 31 bf 1c 28 d4 07 00 00 64 86 1d 28 29 00 00 00 1..(....d..()... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 01f0: f6 be 1c 28 64 86 1d 28 28 f5 bf bf 00 00 00 00 ...(d..((....... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0200: 76 6a 63 5f 76 6a 69 70 00 6f 6d 70 00 f5 bf bf vjc_vjip.omp.... Jan 25 12:00:10 cserver mpd: [pptp] netgraph: 0210: 76 6a 69 70 00 6f 6d 70 00 d6 06 08 14 f6 bf bf vjip.omp........ Jan 25 12:00:10 cserver mpd: [pptp] using interface ng0 Jan 25 12:00:16 cserver mpd: [pptp] IPCP: Down event Jan 25 12:00:16 cserver mpd: [pptp] IFACE: Close event Jan 25 12:00:16 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:16 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=7 addr="ng0:" } Jan 25 12:00:16 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:16 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: token 26 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:16 cserver mpd: [pptp] netgraph: cmd shutdown (1) Jan 25 12:00:16 cserver mpd: [pptp] netgraph: args Jan 25 12:00:16 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:16 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=14 addr="bypass.inet" } Jan 25 12:00:16 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:16 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: token 28 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:16 cserver mpd: [pptp] netgraph: cmd 1 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:16 cserver mpd: [pptp] netgraph: SENDING MESSAGE: Jan 25 12:00:16 cserver mpd: [pptp] netgraph: SOCKADDR: { fam=32 len=9 addr="bypass" } Jan 25 12:00:16 cserver mpd: [pptp] netgraph: NG_MESG : Jan 25 12:00:16 cserver mpd: [pptp] netgraph: vers 2 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: arglen 0 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: flags 0 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: token 29 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: cookie GENERIC (851672668) Jan 25 12:00:16 cserver mpd: [pptp] netgraph: cmd 1 Jan 25 12:00:16 cserver mpd: [pptp] netgraph: args (0 bytes) Jan 25 12:00:16 cserver mpd: mpd: process 324 terminated Вставить ник Quote
Inco Posted January 25, 2003 Posted January 25, 2003 Jan 25 12:00:09 cserver mpd: [pptp] netgraph: sendto(ng0:): No such file or directory А это тут интересно при чем. Вставить ник Quote
terapeut Posted January 26, 2003 Posted January 26, 2003 Не являюсь экспертом по настройке VPN, но имею работающую конфигурацию (: настраивал как здесь: http://www.artmagic.ru/labs/mpd.shtml set ipcp ranges 193.220.131.62/26 193.220.131.1/26 Если я правильно понимаю, то каждый линк настраивается отдельно и маска должна быть 32 , а не 26. И почему адрес привязки накладывается на адреса виртуального канала? set pptp self 193.220.131.62 Видимо либо одно, либо другое - ошибочно, а что - не могу сказать так как не знаю адресов интерфейсов машины. И есть ли у тебя файл mpd.secret со всем положенным содержимым? Может как раз на него он и ругается? И как-то не очень внятно на счёт того, что работает, а что нет.. Винтукей работает? А вин98 - нет? Одновременно или порознь? Ещё стоит иметь ввиду, что при убивании и повторном запуске mpd не убиваются автоматически интерфейсы ng которые он создал - у меня в своё время в связи с эти были проблемы, хотя я об этом предварительно читал (8 Так вот, он в этом случае видимо как-то путается в старых интерфейсах и число подключений хитрым образом становится ограниченным. Надо либо ребутиться, либо прибивать их вручную, ну или автоматизировать это дело. в приведённой ссылке это описано. Вставить ник Quote
Angell5 Posted January 27, 2003 Author Posted January 27, 2003 Какие только настройки я не пробовал и в ядро поддержку ng добавил и в фаерволе разрешил... Дело не в настройках. После запуска mpd появляется ng0 но если в ngctl сделать show ng0 то ругается : ngctl: send msg: No such file or directory И при запуске mpd тоже ругается [pptp] netgraph: sendto(ng0:): No such file or dir... тоесть он неможет работать с ng Если дать ngctl команду list то ноду ng0 видно: There are 8 total nodes: Name: ngctl4193 Type: socket ID: 0000002e Num hooks: 0 Name: <unnamed> Type: vjc ID: 0000002c Num hooks: 4 Name: <unnamed> Type: bpf ID: 0000002b Num hooks: 3 Name: mpd4176-pptp Type: ppp ID: 0000002a Num hooks: 6 Name: ng0 Type: iface ID: 00000029 Num hooks: 1 Name: <unnamed> Type: socket ID: 00000028 Num hooks: 2 Name: xl0 Type: ether ID: 00000002 Num hooks: 0 Name: rl0 Type: ether ID: 00000001 Num hooks: 0 в чем может быть проблема ? Вставить ник Quote
tim777 Posted January 28, 2003 Posted January 28, 2003 Какие только настройки я не пробовал и в ядро поддержку ng добавил и в фаерволе разрешил...Дело не в настройках. После запуска mpd появляется ng0 но если в ngctl сделать show ng0 то ругается : ngctl: send msg: No such file or directory И при запуске mpd тоже ругается [pptp] netgraph: sendto(ng0:): No such file or dir... тоесть он неможет работать с ng Если дать ngctl команду list то ноду ng0 видно: в чем может быть проблема ? Конфиг ядра в студию. Вставить ник Quote
terapeut Posted January 28, 2003 Posted January 28, 2003 С ядром GENERIC, если мне не изменяет мой склероз, всё работает. Вставить ник Quote
Angell5 Posted January 28, 2003 Author Posted January 28, 2003 Конфиг ядра: machine i386 cpu I486_CPU cpu I586_CPU cpu I686_CPU ident CS maxusers 512 options NMBCLUSTERS=16384 options NBUF=2048 ##options CHILD_MAX=512 ##options OPEN_MAX=512 options MAXDSIZ=(512*1024*1024) options DFLDSIZ=(128*1024*1024) options CPU_ENABLE_SSE options CPU_FASTER_5X86_FPU options CPU_PPRO2CELERON options CPU_SUSP_HLT #options HZ=100 options UFS_DIRHASH options CPU_UPGRADE_HW_CACHE options SYSVSHM #options SHMMAXPGS=4096 #options SHMMAX="(SHMMAXPGS*PAGE_SIZE+1)" #options SHMMIN=2 #options SHMMNI=256 #options SHMSEG=256 options SYSVSEM #options SEMMAP=512 #options SEMMNI=512 #options SEMMNS=1024 #options SEMMNU=512 #options SEMMSL=256 #options SEMOPM=256 #options SEMUME=64 options SYSVMSG #options MSGMNB=8192 #options MSGMNI=256 #options MSGSEG=8192 #options MSGSSZ=16 #options MSGTQL=128 #makeoptions DEBUG=-g #Build kernel with gdb(1) debug symbols options INET #InterNETworking options INET6 options FFS #Berkeley Fast Filesystem options FFS_ROOT #FFS usable as root device [keep this!] options SOFTUPDATES options MFS options UFS_DIRHASH #options UCONSOLE options PROCFS #Process filesystem options COMPAT_43 #Compatible with BSD 4.3 [KEEP THIS!] options CD9660 #options USERCONFIG #boot -c editor #options VISUAL_USERCONFIG #visual boot -c editor options KTRACE #options SYSVSHM #SYSV-style shared memory #options SYSVMSG #SYSV-style message queues #options SYSVSEM #SYSV-style semaphores options P1003_1B #Posix P1003_1B real-time extensions options _KPOSIX_PRIORITY_SCHEDULING #options ICMP_BANDLIM #Rate limit bad replies options KBD_INSTALL_CDEV # To make an SMP kernel, the next two are needed #options SMP # Symmetric MultiProcessor Kernel #options APIC_IO # Symmetric (APIC) I/O device isa device pci # Floppy drives #device fdc0 at isa? port IO_FD1 irq 6 drq 2 #device fd0 at fdc0 drive 0 # # ATA and ATAPI devices device ata0 at isa? port IO_WD1 irq 14 device ata device atadisk # ATA disk drives options ATA_STATIC_ID #Static device numbering # atkbdc0 controls both the keyboard and the PS/2 mouse device atkbdc0 at isa? port IO_KBD device atkbd0 at atkbdc? irq 1 flags 0x1 device vga0 at isa? # splash screen/screen saver pseudo-device splash # Serial (COM) ports #device sio0 at isa? port IO_COM1 flags 0x20000 irq 3 #device sio1 at isa? port IO_COM2 flags 0x20000 irq 4 #device sio2 at isa? disable port IO_COM3 irq 5 #device sio3 at isa? disable port IO_COM4 irq 9 # Parallel port #device ppc0 at isa? irq 7 #device ppbus # Parallel port bus (required) #device lpt # Printer #device plip # TCP/IP over parallel #device ppi # Parallel port interface device #device vpo # Requires scbus and da # syscons is the default console driver, resembling an SCO console device sc0 at isa? flags 0x100 # Floating point support - do not disable. device npx0 at nexus? port IO_NPX irq 13 # Power management support (see LINT for more options) device apm0 at nexus? disable flags 0x20 # Advanced Power Management # PCCARD (PCMCIA) support device card device pcic #0 at isa? irq 0 port 0x3e0 iomem 0xd0000 #device pcic1 at isa? irq 0 port 0x3e2 iomem 0xd4000 disable # PCI Ethernet NICs that use the common MII bus controller code. # NOTE: Be sure to keep the 'device miibus' line in order to use these NICs! device miibus # MII bus support device rl # RealTek 8129/8139 device wi device xl #device ng options NETGRAPH #netgraph(4) system options NETGRAPH_ASYNC options NETGRAPH_BPF options NETGRAPH_CISCO options NETGRAPH_ECHO options NETGRAPH_ETHER options NETGRAPH_FRAME_RELAY options NETGRAPH_HOLE options NETGRAPH_IFACE options NETGRAPH_KSOCKET options NETGRAPH_LMI # MPPC compression requires proprietary files (not included) #options NETGRAPH_MPPC_COMPRESSION options NETGRAPH_MPPC_ENCRYPTION options NETGRAPH_ONE2MANY options NETGRAPH_PPP options NETGRAPH_PPPOE options NETGRAPH_PPTPGRE options NETGRAPH_RFC1490 options NETGRAPH_SOCKET options NETGRAPH_TEE options NETGRAPH_TTY options NETGRAPH_UI options NETGRAPH_VJC # Pseudo devices - the number indicates how many units to allocate. pseudo-device ppp 20 options PPP_BSDCOMP options PPP_DEFLATE options PPP_FILTER pseudo-device loop # Network loopback pseudo-device ether # Ethernet support pseudo-device tun # Packet tunnel. pseudo-device pty # Pseudo-ttys (telnet etc) pseudo-device bpf #Berkeley packet filter #options MROUTING # Multicast routing options IPFIREWALL #firewall #options DUMMYNET options IPFIREWALL_VERBOSE #print information about options IPFIREWALL_VERBOSE_LIMIT=100 #limit verbosity #options IPFIREWALL_DEFAULT_TO_ACCEPT #allow everything by default #options IPDIVERT #divert sockets #options TCP_DROP_SYNFIN options IPFIREWALL_FORWARD #enable transparent proxy support #options IPFILTER #ipfilter support #options IPFILTER_LOG #ipfilter logging #options IPFILTER_DEFAULT_BLOCK #block all packets by default #options IPSTEALTH #support for stealth forwarding #options TCPDEBUG Вставить ник Quote
tim777 Posted January 28, 2003 Posted January 28, 2003 Посмотри сслылку которую кинул, terapeut - он прав set pptp self 193.220.131.62 и set ipcp ranges 193.220.131.62/26 193.220.131.1/26 не должны совпадать. Выдай на тунели, что нибудь из 192.168.x.x Попробуй выкинуть авторизацию и сделать так set pptp self 193.220.131.62 set pptp peer 193.220.131.1 set ipcp range 192.168.1.1/32 192.168.1.2/32 ??? Вставить ник Quote
Angell5 Posted January 28, 2003 Author Posted January 28, 2003 Я по этой статье делал. Настройки пробовал всякие ... Он после запуска: /usr/local/etc/mpd > mpd Multi-link PPP for FreeBSD, by Archie L. Cobbs. Based on iij-ppp, by Toshiharu OHNO. mpd: pid 2401, version 3.10 (root@gohan15.freebsd.org 09:40 10-Jan-2003) Usage: set login [authname] [pptp] netgraph: sendto(ng0:): No such file or directory [pptp] netgraph: sendto(ng0:): No such file or directory [pptp] ppp node is "mpd2401-pptp" [pptp] using interface ng0 [pptp:pptp] Тоесть или это ошибка работы с netgraph или я незнаю ... И такая же проблема почемуто возникла у меня на FreeBSD 4.5-RELEASE ... Что может в ядре мешать ? Вставить ник Quote
tim777 Posted January 28, 2003 Posted January 28, 2003 Я по этой статье делал. Настройки пробовал всякие ... Он после запуска: /usr/local/etc/mpd > mpd Multi-link PPP for FreeBSD, by Archie L. Cobbs. Based on iij-ppp, by Toshiharu OHNO. mpd: pid 2401, version 3.10 (root@gohan15.freebsd.org 09:40 10-Jan-2003) Usage: set login [authname] [pptp] netgraph: sendto(ng0:): No such file or directory [pptp] netgraph: sendto(ng0:): No such file or directory [pptp] ppp node is "mpd2401-pptp" [pptp] using interface ng0 [pptp:pptp] Тоесть или это ошибка работы с netgraph или я незнаю ... И такая же проблема почемуто возникла у меня на FreeBSD 4.5-RELEASE ... Что может в ядре мешать ? 4.3 4.6 работает Значит мины кучно легли ;( На www.dejanews.com нашел что-то похожее http://groups.google.com/groups?hl=en&lr=&...b.no%26rnum%3D1 Вставить ник Quote
tim777 Posted January 29, 2003 Posted January 29, 2003 Попыти воспроизвести данную проблему на 4.7 + mpd 3.9 4.4 + mpd 3.2 4.3 + mpd 3.2 успехом не увенчались - все работает. Вставить ник Quote
Angell5 Posted January 29, 2003 Author Posted January 29, 2003 Возможно я просто чтото не то делаю. Взял папку netgraph из дистрибутива 4.7 перекомпилил ядро. Все работает но сообщения теже. Запустил bw_man - все ок но ngctl ругается аналогично. Может эти сообщения бессмысленны, а все дело в настройках mpd ? set ipcp ranges 193.220.131.62/26 193.220.131.1/26 Если я правильно понимаю, то каждый линк настраивается отдельно и маска должна быть 32 , а не 26. И почему адрес привязки накладывается на адреса виртуального канала? set pptp self 193.220.131.62 Видимо либо одно, либо другое - ошибочно, а что - не могу сказать так как не знаю адресов интерфейсов машины. Адрес машины в сети 131.62 алиас 10.70.0.1 Переделал конфиги: default: load pptp # PPTP Server pptp: set debug 1 set log +pptp +pptp1 +pptp2 +pptp3 +lcp +auth +ccp+bund +link +chat new -i ng0 pptp pptp set bundle disable multilink set bundle enable compression set bundle enable encryption set bundle yes crypt-reqd set iface disable on-demand set iface enable proxy-arp set iface idle 1800 set ipcp dns 193.220.131.1 # set ipcp nbns 193.220.131.62 set ipcp enable vjcomp set link yes acfcomp protocomp set link no pap chap set link enable chap set link keep-alive 10 60 set ipcp ranges 193.220.131.62/32 193.220.131.57/32 set link enable no-orig-auth set ccp enable mppc set ccp enable mpp-compress set ccp enable mpp-e40 set ccp enable mpp-e128 set ccp enable mpp-stateless атак же : set link type pptp set pptp self 10.70.0.2 set pptp enable incoming set pptp disable originate #set pptp peer 193.220.131.57 Пробую конектится со 131.57 но mpd молчит как неживой ... Вот что мне ответил Archie Cobbs: You may need to upgrade to a newer version of FreeBSD.Also, your log shows that you tried to run two version of mpd at the same time: Jan 25 12:00:02 cserver mpd: mpd: already running as process 210 -Archie Хотя у людей на 4.4 все работает ... Может на 4.5 и волноваться нестоит ? Все равно небудет работать ?http://docs.freebsd.org/cgi/getmsg.cgi?fet...112.freebsd-net Вставить ник Quote
tim777 Posted January 30, 2003 Posted January 30, 2003 Попобуй выкинуть компресию, криптование и добиться, хотя бы что бы линк поднялся. И в последнем конфиге proxy arp лишний? C 4.3 у меня работает с mpd 3.2 Вставить ник Quote
Angell5 Posted January 30, 2003 Author Posted January 30, 2003 Сделал ... пробую конектится с y2k в trafshow наблюдаю: From Address To Address Prot Bytes CPS ============================================================================= 193.220.131.57..4928 193.220.131.62..1723 tcp 144 28 193.220.131.62..1723 193.220.131.57..4928 tcp 120 24 193.220.131.57..4930 193.220.131.62..1723 tcp 144 9 193.220.131.62..1723 193.220.131.57..4930 tcp 120 Дальше больше tcpdump -i xl0 -n -X host 193.220.131.57 12:01:49.440432 193.220.131.57.1092 > 193.220.131.62.1723: S 2687616659:2687616659(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d014 4000 8006 a082 c1dc 8339 E..0..@........9 0x0010 c1dc 833e 0444 06bb a031 c693 0000 0000 ...>.D...1...... 0x0020 7002 4000 472a 0000 0204 05b4 0101 0402 p.@.G*.......... 12:01:49.440469 193.220.131.62.1723 > 193.220.131.57.1092: R 0:0(0) ack 2687616660 win 0 (DF) 0x0000 4500 0028 66b2 4000 4006 0000 c1dc 833e E..(f.@.@......> 0x0010 c1dc 8339 06bb 0444 0000 0000 a031 c694 ...9...D.....1.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:49.902207 193.220.131.57.1092 > 193.220.131.62.1723: S 2687616659:2687616659(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d044 4000 8006 a052 c1dc 8339 E..0.D@....R...9 0x0010 c1dc 833e 0444 06bb a031 c693 0000 0000 ...>.D...1...... 0x0020 7002 4000 472a 0000 0204 05b4 0101 0402 p.@.G*.......... 12:01:49.902242 193.220.131.62.1723 > 193.220.131.57.1092: R 0:0(0) ack 1 win 0 (DF) 0x0000 4500 0028 6716 4000 4006 0000 c1dc 833e E..(g.@.@......> 0x0010 c1dc 8339 06bb 0444 0000 0000 a031 c694 ...9...D.....1.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:50.402993 193.220.131.57.1092 > 193.220.131.62.1723: S 2687616659:2687616659(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d072 4000 8006 a024 c1dc 8339 E..0.r@....$...9 0x0010 c1dc 833e 0444 06bb a031 c693 0000 0000 ...>.D...1...... 0x0020 7002 4000 472a 0000 0204 05b4 0101 0402 p.@.G*.......... 12:01:50.403030 193.220.131.62.1723 > 193.220.131.57.1092: R 0:0(0) ack 1 win 0 (DF) 0x0000 4500 0028 67b2 4000 4006 0000 c1dc 833e E..(g.@.@......> 0x0010 c1dc 8339 06bb 0444 0000 0000 a031 c694 ...9...D.....1.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:51.396395 193.220.131.57.1094 > 193.220.131.62.1723: S 2688130177:2688130177(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d0b5 4000 8006 9fe1 c1dc 8339 E..0..@........9 0x0010 c1dc 833e 0446 06bb a039 9c81 0000 0000 ...>.F...9...... 0x0020 7002 4000 7132 0000 0204 05b4 0101 0402 p.@.q2.......... 12:01:51.396439 193.220.131.62.1723 > 193.220.131.57.1094: R 0:0(0) ack 2688130178 win 0 (DF) 0x0000 4500 0028 68dd 4000 4006 0000 c1dc 833e E..(h.@.@......> 0x0010 c1dc 8339 06bb 0446 0000 0000 a039 9c82 ...9...F.....9.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:51.805223 193.220.131.57.1094 > 193.220.131.62.1723: S 2688130177:2688130177(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d0d4 4000 8006 9fc2 c1dc 8339 E..0..@........9 0x0010 c1dc 833e 0446 06bb a039 9c81 0000 0000 ...>.F...9...... 0x0020 7002 4000 7132 0000 0204 05b4 0101 0402 p.@.q2.......... 12:01:51.805269 193.220.131.62.1723 > 193.220.131.57.1094: R 0:0(0) ack 1 win 0 (DF) 0x0000 4500 0028 6967 4000 4006 0000 c1dc 833e E..(ig@.@......> 0x0010 c1dc 8339 06bb 0446 0000 0000 a039 9c82 ...9...F.....9.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:52.305986 193.220.131.57.1094 > 193.220.131.62.1723: S 2688130177:2688130177(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d0ff 4000 8006 9f97 c1dc 8339 E..0..@........9 0x0010 c1dc 833e 0446 06bb a039 9c81 0000 0000 ...>.F...9...... 0x0020 7002 4000 7132 0000 0204 05b4 0101 0402 p.@.q2.......... 12:01:52.306024 193.220.131.62.1723 > 193.220.131.57.1094: R 0:0(0) ack 1 win 0 (DF) 0x0000 4500 0028 6a03 4000 4006 0000 c1dc 833e E..(j.@.@......> 0x0010 c1dc 8339 06bb 0446 0000 0000 a039 9c82 ...9...F.....9.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:53.224631 193.220.131.57.1096 > 193.220.131.62.1723: S 2688656573:2688656573(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d141 4000 8006 9f55 c1dc 8339 E..0.A@....U...9 0x0010 c1dc 833e 0448 06bb a041 a4bd 0000 0000 ...>.H...A...... 0x0020 7002 4000 68ec 0000 0204 05b4 0101 0402 p.@.h........... 12:01:53.224663 193.220.131.62.1723 > 193.220.131.57.1096: R 0:0(0) ack 2688656574 win 0 (DF) 0x0000 4500 0028 6b2d 4000 4006 0000 c1dc 833e E..(k-@.@......> 0x0010 c1dc 8339 06bb 0448 0000 0000 a041 a4be ...9...H.....A.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:53.708217 193.220.131.57.1096 > 193.220.131.62.1723: S 2688656573:2688656573(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d16c 4000 8006 9f2a c1dc 8339 E..0.l@....*...9 0x0010 c1dc 833e 0448 06bb a041 a4bd 0000 0000 ...>.H...A...... 0x0020 7002 4000 68ec 0000 0204 05b4 0101 0402 p.@.h........... 12:01:53.708283 193.220.131.62.1723 > 193.220.131.57.1096: R 0:0(0) ack 1 win 0 (DF) 0x0000 4500 0028 6bbf 4000 4006 0000 c1dc 833e E..(k.@.@......> 0x0010 c1dc 8339 06bb 0448 0000 0000 a041 a4be ...9...H.....A.. 0x0020 5014 0000 8a4b 0000 P....K.. 12:01:54.209017 193.220.131.57.1096 > 193.220.131.62.1723: S 2688656573:2688656573(0) win 16384 <mss 1460,nop,nop,sackOK> (DF) 0x0000 4500 0030 d194 4000 8006 9f02 c1dc 8339 E..0..@........9 0x0010 c1dc 833e 0448 06bb a041 a4bd 0000 0000 ...>.H...A...... 0x0020 7002 4000 68ec 0000 0204 05b4 0101 0402 p.@.h........... 12:01:54.209051 193.220.131.62.1723 > 193.220.131.57.1096: R 0:0(0) ack 1 win 0 (DF) 0x0000 4500 0028 6c54 4000 4006 0000 c1dc 833e E..(lT@.@......> 0x0010 c1dc 8339 06bb 0448 0000 0000 a041 a4be ...9...H.....A.. 0x0020 5014 0000 8a4b 0000 P....K.. Но дело не в этом, в логи все мои попытки подключиться непишутся. Может я клиента не того пользую ? Хотя я еще и из 98 пробовал ... Днем раньше обновил ядро до RELENG_4 STABILE и перепробовал все версии mpd вплоть до 3.10 - результат всегда один. Пришли пример своих логов что он должен в них писать ели кто то конектится или если пароль неверный plz... Вставить ник Quote
tim777 Posted January 31, 2003 Posted January 31, 2003 Есть вторая машинка с фришкой ??? mpd на mpd повязать не пробовал? Логи с двух сторон смотреть удобней. Конфиги вот. win2k win98 влет цепляются, c NT4.0 работать не захотело. А логи сегодня снять попробую. mpd.conf default: load Pptp1 load Pptp2 Pptp1: new -i ng0 Pptp1 Pptp1 set iface disable on-demand set iface addrs 192.168.a.1 192.168.a.2 set iface route 192.168.x1.0/24 set iface idle 1800 set bundle disable multilink set link no pap chap set pptp self a.b.c.1 set pptp peer b.c.a.2 set link enable chap set link keep-alive 10 75 set ipcp ranges 192.168.x.1/32 192.168.x.2/32 set bundle disable compression set ccp yes mppc set ccp yes mpp-e40 set ccp yes mpp-stateless Pptp2: new -i ng1 Pptp2 Pptp2 set iface addrs 192.168.x.1 192.168.x.3 set iface disable on-demand set iface route 192.168.x2.0/24 set iface idle 1800 set pptp self a.b.c.1 set pptp peer b.c.a.3 set bundle disable multilink set link no pap chap set link enable chap set link keep-alive 10 75 set ipcp ranges 192.168.x.1/32 192.168.x.3/32 set ccp yes mppc set ccp yes mpp-e40 set ccp yes mpp-stateless mpd.link Pptp1: set link type pptp set pptp enable incoming set pptp disable originate Pptp2: set link type pptp set pptp enable incoming set pptp disable originate mpd.secrets Pptp2 "ppppp1" * Pptp1 "ppppp2" * Вставить ник Quote
tim777 Posted February 6, 2003 Posted February 6, 2003 Извини, c логами пока облом. Вставить ник Quote
Angell5 Posted February 22, 2003 Author Posted February 22, 2003 Выличил установкой FreeBSD 5.0-RELEASE http://www.madeagle.ru/vbb/showthread.php?...s=&postid=22553 и MPD 3.12 Еще вопрос что лучше pptp или ppoe ? скорость, компрессия, шафрование ... И еще сервер ругается: ng_mppc_decompress: insane jump 326 ng_mppc_decompress: insane jump 586 Чем лечить ? Вставить ник Quote
