Добрый день! Последнее время в логах стали появляться трэйсбэки, в чём может быть проблема?
[syslog@9 s_sn=4199" s_tc="4418]: *Feb 6 23:09:32.051: %CPPOSLIB-3-ERROR_NOTIFY: F1: cpp_cp: cpp_cp encountered an error -Traceback= 1#c76d898069fc41bcbcf9daec6a525925 errmsg:D1B1000+2160 cpp_common_os:D800000+BB40 cpp_common_os:D800000+B950 cpp_common_os:D800000+18E9C cpp_qos_ea_lib:F4C2000+1A378 cpp_qos_ea_lib:F4C2000+E7E0 cpp_qos_smc_lib:F545000+2810 cpp_qos_ea_lib:F4C2000+47F08 binos:D452000+B60C cpp_qos_ea_lib:F4C2000+47DDC cpp_qos_smc_lib:F545000+26DC cpp_common_os:D800000+10A74 cpp_common_os:D800000+110AC evlib:D57A000+D8A4 evlib:D5
[syslog@9 s_sn=4200" s_tc="4419]: *Feb 6 23:09:32.051: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image: Batch type 1 ID 2882382797 download to CPP failed
[syslog@9 s_sn=4201" s_tc="4420]: *Feb 6 23:09:32.058: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F1: fman_fp_image: Batch type 1 ID 2882382797 download to CPP failed
[syslog@9 s_sn=4202" s_tc="4421]: *Feb 6 23:34:11.497: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_cp: cpp_cp encountered an error -Traceback= 1#c76d898069fc41bcbcf9daec6a525925 errmsg:D1B1000+2160 cpp_common_os:D800000+BB40 cpp_common_os:D800000+B950 cpp_common_os:D800000+18E9C cpp_qos_ea_lib:F4C2000+1A378 cpp_qos_ea_lib:F4C2000+E7E0 cpp_qos_smc_lib:F545000+2810 cpp_qos_ea_lib:F4C2000+47F08 binos:D452000+B60C cpp_qos_ea_lib:F4C2000+47DDC cpp_qos_smc_lib:F545000+26DC cpp_common_os:D800000+10A74 cpp_common_os:D800000+110AC evlib:D57A000+D8A4 evlib:D
[syslog@9 s_sn=4203" s_tc="4422]: *Feb 6 23:34:11.505: %CPPOSLIB-3-ERROR_NOTIFY: F1: cpp_cp: cpp_cp encountered an error -Traceback= 1#c76d898069fc41bcbcf9daec6a525925 errmsg:D1B1000+2160 cpp_common_os:D800000+BB40 cpp_common_os:D800000+B950 cpp_common_os:D800000+18E9C cpp_qos_ea_lib:F4C2000+1A378 cpp_qos_ea_lib:F4C2000+E7E0 cpp_qos_smc_lib:F545000+2810 cpp_qos_ea_lib:F4C2000+47F08 binos:D452000+B60C cpp_qos_ea_lib:F4C2000+47DDC cpp_qos_smc_lib:F545000+26DC cpp_common_os:D800000+10A74 cpp_common_os:D800000+110AC evlib:D57A000+D8A4 evlib:D
[syslog@9 s_sn=4204" s_tc="4423]: *Feb 6 23:34:11.504: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image: Batch type 1 ID 2882382797 download to CPP failed
[syslog@9 s_sn=4205" s_tc="4424]: *Feb 6 23:34:11.512: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F1: fman_fp_image: Batch type 1 ID 2882382797 download to CPP failed
[syslog@9 s_sn=4206" s_tc="4425]: *Feb 7 01:21:31.807: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_cp: cpp_cp encountered an error -Traceback= 1#c76d898069fc41bcbcf9daec6a525925 errmsg:D1B1000+2160 cpp_common_os:D800000+BB40 cpp_common_os:D800000+B950 cpp_common_os:D800000+18E9C cpp_qos_ea_lib:F4C2000+1A378 cpp_qos_ea_lib:F4C2000+E7E0 cpp_qos_smc_lib:F545000+2810 cpp_qos_ea_lib:F4C2000+47F08 binos:D452000+B60C cpp_qos_ea_lib:F4C2000+47DDC cpp_qos_smc_lib:F545000+26DC cpp_common_os:D800000+10A74 cpp_common_os:D800000+110AC evlib:D57A000+D8A4 evlib:D
[syslog@9 s_sn=4207" s_tc="4426]: *Feb 7 01:21:31.813: %CPPOSLIB-3-ERROR_NOTIFY: F1: cpp_cp: cpp_cp encountered an error -Traceback= 1#c76d898069fc41bcbcf9daec6a525925 errmsg:D1B1000+2160 cpp_common_os:D800000+BB40 cpp_common_os:D800000+B950 cpp_common_os:D800000+18E9C cpp_qos_ea_lib:F4C2000+1A378 cpp_qos_ea_lib:F4C2000+E7E0 cpp_qos_smc_lib:F545000+2810 cpp_qos_ea_lib:F4C2000+47F08 binos:D452000+B60C cpp_qos_ea_lib:F4C2000+47DDC cpp_qos_smc_lib:F545000+26DC cpp_common_os:D800000+10A74 cpp_common_os:D800000+110AC evlib:D57A000+D8A4 evlib:D
[syslog@9 s_sn=4208" s_tc="4427]: *Feb 7 01:21:31.815: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image: Batch type 1 ID 2882382797 download to CPP failed
[syslog@9 s_sn=4209" s_tc="4428]: *Feb 7 01:21:31.819: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F1: fman_fp_image: Batch type 1 ID 2882382797 download to CPP failed
Edited by swat11
ну с трейсбеками особо ничего не поделаешь сам (если нет явных указаний что их вызвало), поэтому:
1. в саппорт
2. если саппорта нет, то пробовать последний софт или последние релизы нескольких последних веток
3. если 2 не помогло, то угадывать что это вызывает, выключая фичи, вспоминая что менялось, что изменилось во внешних факторах и т.д., внимательно следить за потреблением cpu, памяти и т.п., проверить лимиты по сессиям, нату и прочему (один релиз asr1k может крешится из-за превышения глобального лимита по трансляциям)
У нас тоже было что-то подобное. Перепробовали несколько IOS'ов, остановились на версии 15.2(4)S5.
ну тут судя по сообщениям чота в области коса.. это брас или что?
Там брас, шейпер и бордер с BGP и фул листом
Понял, попробую.
