C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950T-24 starting...
Base ethernet MAC Address: 00:1b:2a:f2:80:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 2 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 3133952
flashfs[0]: Bytes available: 4607488
flashfs[0]: flashfs fsck took 6 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c2950-i6k2l2q4-mz.121-22.EA6.bin"...flash:c2950-i6k2l2q4-mz.121-22.EA6.bin: no such file or directory
Error loading "flash:c2950-i6k2l2q4-mz.121-22.EA6.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2950-i6q4l2-mz.121-22.EA13"...#############################################################################################
File "flash:/c2950-i6q4l2-mz.121-22.EA13" uncompressed and installed, entry point: 0x80010000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA13, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 27-Feb-09 22:20 by amvarma
Image text-base: 0x80010000, data-base: 0x80570000
Initializing flashfs...
flashfs[1]: 2 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 3133952
flashfs[1]: Bytes available: 4607488
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
POST Failure: Ethernet Controller Test: Failed
cisco WS-C2950T-24 (RC32300) processor (revision R0) with 20957K bytes of memory.
Processor board ID FOC1109Z30T
Last reset from system-reset
Running Enhanced Image
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1B:2A:F2:80:00
Motherboard assembly number: 73-6114-11
Power supply part number: 34-0965-01
Motherboard serial number: FOC110725DB
Power supply serial number: PHI1028CKMY
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950T-24
System serial number: FOC1109Z30T
Press RETURN to get started!
00:00:08: %PLATFORM_HW-3-PCI_FIND_FAILURE:
The number of asics expected were 1, PCI bus scan found -1
00:00:09: %SYS-5-RESTART: System restarted --
00:00:09: %SNMP-5-COLDSTART: SNMP agent on host Switch is undergoing a cold start
00:00:09: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file = / code = 21 (Is a1
-Traceback= 8038E670 8038B300
Switch>
