Хочу получить данные в формате:
ifMIB.ifMIBObjects.ifXTable.ifXEntry.ifName.246 = STRING: ge-0/0/0
под который я уже настроил мониторинг в Zabbix'e.
Пожалуйста поподробнее.
На оф. сайте есть есть архив с MIB файлами. Архив скачал. Внутри текстовые файлы с названиями типа:
mib-jnx-hostresources.txt
и содержанием:
-- Juniper Enterprise Specific MIB: Host Resources MIB
-- Copyright © 2004, Juniper Networks, Inc.
-- All rights reserved.
-- The contents of this document are subject to change without notice.
JUNIPER-HOSTRESOURCES-MIB DEFINITIONS ::= BEGIN
IMPORTS
MODULE-IDENTITY, OBJECT-TYPE, Gauge32
FROM SNMPv2-SMI
hrStorageEntry
FROM HOST-RESOURCES-MIB
jnxMibs
FROM JUNIPER-SMI;
jnxHostResourcesMIB MODULE-IDENTITY
LAST-UPDATED "200408180000Z" -- Aug 18, 2004
ORGANIZATION "Juniper Networks, Inc."
CONTACT-INFO
" Juniper Technical Assistance Center
1194 N. Mathilda Avenue
Sunnyvale, CA 94089
E-mail: support@juniper.net"
DESCRIPTION
"Extends the HOST-RESOURCES-MIB (rfc2790)."
-- revision history
REVISION "200408180000Z"
DESCRIPTION
"Fixed typo in description clauses."
REVISION "200405050000Z"
DESCRIPTION
"Initial revision."
::= { jnxMibs 31 }
-- The Host Resources Storage Group
jnxHrStorage OBJECT IDENTIFIER ::= { jnxHostResourcesMIB 1 }
jnxHrStorageTable OBJECT-TYPE
SYNTAX SEQUENCE OF JnxHrStorageEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
"Augments the hrStorageTable with additional data."
::= { jnxHrStorage 1 }
jnxHrStorageEntry OBJECT-TYPE
SYNTAX JnxHrStorageEntry
STATUS current
DESCRIPTION
"Each entry provides additional file system data beyond that
available in the hrStorageTable."
AUGMENTS { hrStorageEntry }
::= { jnxHrStorageTable 1 }
JnxHrStorageEntry ::=
SEQUENCE {
jnxHrStoragePercentUsed Gauge32
jnxHrStoragePercentUsed OBJECT-TYPE
SYNTAX Gauge32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The amount of the storage represented by this entry
that is allocated, as a percentage of the total amount
available."
::= { jnxHrStorageEntry 1 }
END
Мне эти файлы нужно как-то залить на свич?
Спасибо за ответы.
