Пока очень мало, 1 – 2 тестовых потока.
#show etherchannel load-balance
EtherChannel Load-Balancing Configuration:
src-dst-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
L3
#show interface po2
Port-channel2 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 000f.34cb.8e80 (bia 000f.34cb.8e80)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 35/255, rxload 104/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Members in this channel: Gi6/1 Gi6/3
ARP type: ARPA, ARP Timeout 04:00:00
Last input 13w1d, output never, output hang never
Last clearing of "show interface" counters 00:00:55
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Packet Drop strategy: random early detection (DWRED)
Output queue: 0/40 (size/max)
5 minute input rate 821834000 bits/sec, 93541 packets/sec
5 minute output rate 277109000 bits/sec, 68126 packets/sec
4338653 packets input, 4685140856 bytes, 0 no buffer
Received 399284 broadcasts (398652 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
3234125 packets output, 1666126942 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
# show queueing interface po2
Interface Port-channel2 queueing strategy: fifo
Packet drop strategy: random early detection (DWRED)
Exp-weight-constant: 10 (1/1024)
Mean queue depth: 0
Queue size: 0 Maximum available buffers: 500000
Output packets: 0 WRED drops: 0 No buffer: 0
Class Random Tail Minimum Maximum Mark Output
drop drop threshold threshold probability Packets
0 0 0 32 256 1/100 0
1 0 0 64 256 1/100 0
2 0 0 96 256 1/100 0
3 0 0 120 256 1/100 0
4 0 0 140 256 1/100 0
5 0 0 170 256 1/100 0
6 0 0 290 256 1/100 0
7 0 0 210 256 1/100 0
Провёл несколько дополнительных тестов под нагрузкой и без таковой. Артефакты наблюдаются, что так, что так, субъективно кажется что под нагрузкой чуть больше.
Но самое странное, что попробовал завещать со стороны клиентов и принять через port-channel на техплощадке, и принял поток идеально даже при значительной нагрузке. Выходит что port-channel глючит только при приёме мультикаста, а когда отдаёт то всё ок.
Т.е. работает как угодно, но только не так как надо :(
