На данный момент вот так, меньше чем максимум в почти 8, но больше 10 в сумме:
sh int te 0/1/0
TenGigabitEthernet0/1/0 is up, line protocol is up
Hardware is SPA-1X10GE-L-V2, address is 8843.e199.c510 (bia 8843.e199.c510)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 134/255, rxload 133/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-ER
output flow-control is on, input flow-control is on
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:04:07, output hang never
Last clearing of "show interface" counters never
Input queue: 0/4096/14181064/0 (size/max/drops/flushes); Total output drops: 4138078390
Queueing strategy: fifo
Output queue: 0/4096 (size/max)
5 minute input rate 5249694000 bits/sec, 886296 packets/sec
5 minute output rate 5261294000 bits/sec, 886797 packets/sec
28586403689562 packets input, 18931497255828721 bytes, 120410 no buffer
Received 1610185 broadcasts (0 IP multicasts)
0 runts, 22 giants, 0 throttles
22 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 311082736 multicast, 0 pause input
28740520928387 packets output, 19311134638253784 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
0 unknown protocol drops
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
sh platform hardware qfp active datapath utilization
CPP 0 5 secs 1 min 5 min 60 min
Input: Priority (pps) 116 176 186 216
(bps) 15101 22231 23823 29015
Non-Priority (pps) 918966 914764 902859 841252
(bps) 691108288 687025017 674356177 627456214
Total (pps) 919082 914940 903045 841468
(bps) 691123389 687047248 674380000 627485229
Output: Priority (pps) 7 6 6 6
(bps) 1289 1160 1216 1332
Non-Priority (pps) 919283 915123 903220 841613
(bps) 692052769 687984965 675331763 628390326
Total (pps) 919290 915129 903226 841619
(bps) 692054058 687986125 675332979 628391658
Processing: Load (pct) 13 13 13 12
