На сервере стоит ubuntu-server 10.04
Последняя erlyvideo (устанавливал из репов, версию не помню)
Поток не конвертирую, забираю по RTSP в h264
Вот мой erlyvideo.conf
% Bing ports where to listen for RTMP, RTSP and HTTP traffic
{rtmp_port, 1935}.
{rtsp_port, 8081}.
{http_port, 8082}.
% Useful for those, who want to intercept RTSP traffic and for example rewrite RTSP requests
{rtsp_callback, ems_rtsp}.
% iPhone streaming splits media stream in segments of this size. Size given in milliseconds
{iphone_segment_size, 10000}.
% RTCP is a synchronization messaging for RTSP/RTP protocols. Tell how often to send it in milliseconds
{rtcp_interval, 5000}.
% This is a very thin configuration option. If you ask a web-server for a nonexistent file, it replies you 404
% This behaviour is good and clean. But if you ask a default RTMP server for a nonexistent file, it will block you
% and tell: ok, I've started a new live stream for you, let's wait untill publisher comes.
% This option tunes this behaviour. When false, it will behave as RTMP server. When true, it will return you 404.
{rtmp_default_wait, false}.
% List of additional applications to start. Erlyvideo will take this list and call Module:start() one by one.
{modules,[]}.
% Additional load paths. Better follow OTP conventions than use this option
{paths, ["/var/lib/erlyvideo/plugins", "/usr/local/lib/erlyvideo/plugins"]}.
% List of file formats. Add your own if you wish more
{file_formats,[mp4_reader,flv_reader,mp3_reader]}.
{vhosts, [
% default virtual host is a fallback vhost, if no other hosts matched
{default, [
% This may be changed to mmap, if you are brave
{file_access, file},
% When new stream is asked by any client, erlyvideo goes through this list of detectors and try them
{detectors, [rewrite, http, rtsp, ts_file, file, livestream]},
{hostname, ["localhost"]},
{rtmp_handlers, [{auth_users_limit, 200}, trusted_login, remove_useless_prefix, apps_streaming, apps_recording]},
{event_handlers, [
% {stream_stopped, {ems_hook_http, "http://localhost:8082/stopped"}},
% {user_connected, {ems_hook_http, "http://localhost:3000/"}}
{secret_key, "123"},
{file_dir, "movies"},
{wwwroot, "wwwroot"},
{www_handlers, [
ems_http_rtmpt, % RTMPT should be first handler, because it is called REALLY often
% ems_http_hls, % uncomment this line if you have purchased commercial license
% {ems_http_admin_protect, "erlyvideo", "password"}, % uncomment this line to enable password protection for admin panel
ems_http_mpegts, % This handler can response with endless MPEG-TS streams
ems_http_flv, % replies with endless FLV files for your streams
ems_http_erlyvideo_api, % this one replies with stream status and can modify your server.
{ems_http_file,"wwwroot"} % just plain static files
{rewrite, [
{"camera0", rtsp, "rtsp://адрес RTSP потока"}
