Если на подключаться по web то работает неограниченно долго, как только начинаешь что-то настраивать буквально пару действий и отрубается, поэтому а настраиваешь по частям ;-( сначала сеть потом точку, т.к. за раз это все не удается.
в логах... до пропадания:
Jun 25 22:11:02 syslogd started: BusyBox v1.16.2
Jun 25 22:11:02 kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jun 25 22:11:02 kernel: Mount-cache hash table entries: 512
Jun 25 22:11:02 kernel: softirq RT prio: 24.
Jun 25 22:11:02 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 25 22:11:02 kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jun 25 22:11:02 kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jun 25 22:11:02 kernel: Load RT2880 Timer Module(Wdg/Soft)
Jun 25 22:11:02 kernel: squashfs: LZMA suppport for slax.org by jro
Jun 25 22:11:02 kernel: FLASH_API: MAN_ID=1 DEV_ID=7E1A00 SIZE=4MB
Jun 25 22:11:02 kernel: Ralink gpio driver initialized
Jun 25 22:11:02 kernel: ralink flash device: 0x400000 at 0x1f000000
Jun 25 22:11:02 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jun 25 22:11:02 kernel: number of CFI chips: 1
Jun 25 22:11:02 kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Jun 25 22:11:02 kernel: Creating 6 MTD partitions on "Ralink SoC physically mapped flash":
Jun 25 22:11:02 kernel: 0x00000000-0x00030000 : "Bootloader"
Jun 25 22:11:02 kernel: 0x00030000-0x00040000 : "Config"
Jun 25 22:11:02 kernel: 0x00040000-0x00050000 : "Factory"
Jun 25 22:11:02 kernel: 0x00050000-0x00120000 : "Kernel"
Jun 25 22:11:02 kernel: 0x00120000-0x003e0000 : "RootFS"
Jun 25 22:11:02 kernel: 0x003e0000-0x00400000 : "RW-FS"
Jun 25 22:11:02 kernel: GACT probability on
Jun 25 22:11:02 kernel: Mirror/redirect action on
Jun 25 22:11:02 kernel: u32 classifier
Jun 25 22:11:02 kernel: input device check on
Jun 25 22:11:02 kernel: Actions configured
Jun 25 22:11:02 kernel: nf_conntrack version 0.5.0 (16384 buckets, 8192 max)
Jun 25 22:11:02 kernel: ipt_time loading
Jun 25 22:11:02 kernel: ip_tables: © 2000-2006 Netfilter Core Team, Type=Restricted Cone
Jun 25 22:11:02 kernel: arp_tables: © 2002 David S. Miller
Jun 25 22:11:02 kernel: ip6_tables: © 2000-2006 Netfilter Core Team
Jun 25 22:11:02 kernel: GDMA1_MAC_ADRH -- : 0x00000000
Jun 25 22:11:02 kernel: GDMA1_MAC_ADRL -- : 0x00000000
Jun 25 22:11:02 kernel: Ralink APSoC Ethernet Driver Initilization. v2.00 64 rx/tx descriptors allocated, mtu = 1500!
Jun 25 22:11:02 kernel: NAPI enable, weight = 0, Tx Ring = 64, Rx Ring = 64
Jun 25 22:11:02 kernel: GDMA1_MAC_ADRH -- : 0x00000013
Jun 25 22:11:02 kernel: GDMA1_MAC_ADRL -- : 0x1300101e
Jun 25 22:11:02 kernel: PROC INIT OK!
Jun 25 22:11:02 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jun 25 22:11:02 kernel: mount /proc file system ok!
Jun 25 22:11:02 kernel: mount /sys file system ok!
Jun 25 22:11:02 kernel: mount /dev file system ok!
Jun 25 22:11:02 kernel: mount /var file system ok!
Jun 25 22:11:02 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jun 25 22:11:03 kernel: phy_tx_ring = 0x01e04000, tx_ring = 0xa1e04000
Jun 25 22:11:03 kernel: phy_rx_ring = 0x00000000, rx_ring = 0x00000000
Jun 25 22:11:03 kernel: RT305x_ESW: Link Status Changed
Jun 25 22:11:03 kernel: CDMA_CSG_CFG = 81000007
Jun 25 22:11:03 kernel: GDMA1_FWD_CFG = 710000
Jun 25 22:11:03 kernel: eth2.2: Setting MAC address to 00 0b 2b 9d 9a 02.
Jun 25 22:11:03 kernel: VLAN (eth2.2): Setting underlying device (eth2) to promiscious mode.
Jun 25 22:11:06 kernel: eth2.2: Setting MAC address to 00 0b 2b 9d 9a 02.
Jun 25 22:11:11 kernel: AP Driver version-2.3.0.0
Jun 25 22:11:15 kernel: 0x1300 = 00064380
а что там во время после кто его знает, физической консоли нет.
И ещё с родной прошивкой, не зависает
скорость в бридже без шифрования 60-70Мбит, с шифрованием 30Мбит.
с 18 прошивкой в бридже без шифрования 30мбит, с шифрованием 10мбит :-(
Интересно..., проверяю на двух одинаковых точках, но с разными прошивками.
а несколько служб PPPoE это может фича или необходимость, первоначально пров сам при подключении настойчиво советовал устанавливать всем RASPPPoE и там выбирать нужную службу, просто все ОС позволяют указывать к какому PPPoE ломится, и роутеры тоже, так что это не лишнее было бы, он конечно и так соединяется минут через 5-10, но мог бы и быстрее.
И я не прошу исправить что-то, т.к. у меня не Acorp(а раньше был обычный модем IRV2 и PIM2 и ещё тогда старался отписываться по всем результатам бета версий драйверов) , просто сообщаю к сведению какие результаты.
