Скачал, залил прошивкув Dlink DAP-1160.
Перегружаю ее, и........ долго жду. Светодиоды моргают но на ИП точка не отвечает.
Подключаю точку HyperTerminal-oм к СОМ порту и вижу следующее
UART1 output test ok
Uart init
mfid=000000c2 devid=000022a8
Found 1 x 4M flash memory
---RealTek(RTL8186)at 2007.07.05-16:20+0800 version 1.4a , CAMEO version v1.00.r
06 [16bit](180MHz)
Jump to image start=0x80300000...
early printk enabled
Determined physical RAM map:
memory: 01000000 @ 00000000 (usable)
Initial ramdisk at: 0x801fa000 (31424 bytes)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram console=0 ramdisk_start=0
178.99 BogoMIPS
Memory: 13856k/16384k available (1834k kernel code, 2528k reserved, 144k data, 6
0k init, 0k highmem)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
check_wait... unavailable.
POSIX conformance testing by UNIFIX
bogomips: Initialized.
user_watchdog: Initialized.
led0: Initialized.
led1: Initialized.
sysmem: Initialized.
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
pty: 256 Unix98 ptys configured
Serial driver version 6.02 (2003-03-12) with no serial options enabled
ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
state->flags=00000000
block: 64 slots per queue, batch=16
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
PPP generic driver version 2.4.1
PPP MPPE Compression module registered
RealTek E-Flash System Driver. © 2002 RealTek Corp.
Found 1 x 4M Byte MXIC MX29LV320AB at 0xbe000000
=> Scan for ROOT signature in flash from pos=0x000000
Founded at pos=0x0CFFF4
Checksumm ok for 0x10C000 bytes calced=0xF48B, stored=0xF48B) Checksumm OK
. Use as ROOT partition (/dev/mtd1)
Reallocate partition for root size=0x10C000 bytes
Creating 4 MTD partitions on "DiskOnChip Millennium":
0x00000000-0x000d0000 : "boot+cfg+linux"
0x000d0000-0x001e0000 : "root fs"
0x003e0000-0x00400000 : "TGZfs"
0x00000000-0x00200000 : "all_flash"
8186NIC Ethernet driver v0.1.0-NG (15.10.2008)
eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
Check MII:phy 2, reg 31
0x0000ffff
Check MII:phy 2, reg 26
0x0000ffff
Asic.revision=0x00000007
RTL8185 driver version 1.14 (2008-02-15)
Realtek FastPath v1.04
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
Linux IP multicast router 0.06 plus PIM-SM
ip_conntrack version 2.1 (128 buckets, 1024 max) - 312 bytes per conntrack
PPTP netfilter connection tracking: registered
ip_tables: © 2000-2002 Netfilter core team
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 30k freed
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 60k +ihуhуhуиp3уhуяhуhу(ъуqу
C завидным постоянством загрузка зависает именно на Freeing unused kernel memory.
p.s. Перед заливкой прошивки, память обнулил.
