Khuman
Пользователи
  • Публикации
    8
  • Зарегистрирован
  • Посещение
О Khuman
  • Звание
    Абитуриент
  1. Mikrotik + firewall + ssh access
    Что и никто не может помочь...
  2. Mikrotik + firewall + ssh access
    Добрый день. Есть железка RB1100AHx2 с таким конфигом: # nov/21/2014 09:58:55 by RouterOS 6.7 # software id = UPCL-YIQ0 # /interface ethernet set [ find default-name=ether2 ] master-port=ether1 set [ find default-name=ether3 ] master-port=ether1 set [ find default-name=ether4 ] master-port=ether1 set [ find default-name=ether5 ] master-port=ether1 set [ find default-name=ether7 ] master-port=ether6 set [ find default-name=ether8 ] master-port=ether6 set [ find default-name=ether9 ] master-port=ether6 set [ find default-name=ether10 ] master-port=ether6 /interface vrrp add interface=ether1 name=vrrp0 priority=254 /interface ethernet switch set 0 name=OfficeSwitch set 1 name=DMZSwitch /interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d /ip pool add name=DHCP-Pool ranges=192.168.0.100-192.168.0.200 /ip dhcp-server add add-arp=yes address-pool=DHCP-Pool disabled=no interface=vrrp0 lease-time=1h name=router /port set 0 name=serial0 set 1 name=serial1 /interface ethernet switch vlan add independent-learning=no ports=ether9,ether10 switch=DMZSwitch vlan-id=30 /ip address add address=192.168.0.2/24 comment=OfficeLAN interface=ether1 network=192.168.0.0 add address=192.168.0.1/32 interface=vrrp0 network=192.168.0.1 add address=1.1.1.2/29 interface=ether6 network=1.1.1.0 /ip dhcp-server lease add address=192.168.0.180 client-id=VD mac-address=60:A4:4C:A9:CC:C1 server=router /ip dhcp-server network add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1 /ip dns set allow-remote-requests=yes cache-max-ttl=1h servers=8.8.4.4 /ip dns static add address=192.168.88.1 name=router /ip firewall filter add chain=input comment="Allow Ping" protocol=icmp add chain=forward protocol=icmp add chain=input comment="Accept established connections" connection-state=established add chain=forward connection-state=established add chain=input comment="Accept related connections" connection-state=related add chain=forward connection-state=related add action=drop chain=input comment="Drop invalid connections" connection-state=invalid add action=drop chain=forward connection-state=invalid add chain=input comment="Allow UDP" protocol=udp add chain=forward protocol=udp add chain=forward comment="Access to Internet from local network" in-interface=vrrp0 src-address=192.168.0.0/24 add chain=input comment="Access to Mikrotik only from our local network" src-address=192.168.0.0/24 add chain=forward dst-address=192.168.0.180 dst-port=3389 protocol=tcp src-port="" add chain=input src-address=2.2.2.2 add chain=forward src-address=2.2.2.2 add action=drop chain=input comment="All other drop" add action=drop chain=forward /ip firewall nat add action=src-nat chain=srcnat out-interface=ether6 to-addresses=1.1.1.2 add action=dst-nat chain=dstnat dst-address=1.1.1.2 protocol=tcp to-addresses=192.168.0.180 to-ports=3389 /ip firewall service-port set pptp ports=1723 /ip route add distance=1 gateway=1.1.1.1 /ip service set telnet disabled=yes set ftp disabled=yes set ssh port=50022 set www-ssl disabled=no /system clock set time-zone-name=Europe/Kiev /system identity set name=router /system logging add topics=telephony,debug /system ntp client set enabled=yes mode=unicast primary-ntp=62.149.0.30 secondary-ntp=209.87.233.51 SSH висит на порту 50022. Из внутренней сети я на него попадаю, а вот с адреса 2.2.2.2 - никак. Может кто-то сможет подсказать, как решить эту элементарную задачку. Вроде бы все правильно делаю.
  3. Что и требовалось доказать. Я поднял тему, дабы уточнить, может я что-то недопонимаю. В работе на L3 при подобной схеме я был полностью уверен.Спасибо всем откликнувшимся.
  4. И он будет работать через коммутирующее оборудование различных провайдеров?
  5. А без L3. Нужно исключительно на L2.
  6. Здравствуйте! Есть две площадки в разных городах. Между ними два различных провайдера предоставляют L2 каналы связи различной пропускной способности. Мне на втором уровне надо настроить отказоустойчивость. Как я понимаю STP мне не поможет. Подскажите, в какую сторону смотреть.
  7. С чего бы это вдруг ? Переход на маршрутизацию реальных IP и уход от NAT
  8. Здравствуйте, коллеги. Хочу проконсультироваться. Есть маршрутизатор на FreeBSD 7.2 (amd64). К нему прикручено ~20 vlan'ов. Задача - шейпинг трафика пользователей и роутинг на пограничное оборудование или внутрисеть. Есть необходимость уйти от маршрутизации vlan и перейти к прозрачному назначению IP адресов пользователям. Подсетей планируется использовать несколько с маской /24 Взгляд обратили на if_bridge. В связи с этим появилось несколько вопросов: 1) как будет работать подобная модель под реальной нагрузкой ~300-500 Мбит/с и общее количество MAC адресов на bridge интерфейсе будет составлять около 2000; 2) имеет ли значение разрядность системы (i386 или amd64); 3) какие подводные камни при этом могут возникнуть. Данная модель у меня создана на столе и протестирована. Все работает без проблем. Но без нагрузки. Какие сюрпризы может она мне выкинуть при переносе на сеть?
