Лог прилагаю
CFE version 1.0.37-8.7 for BCM96338 (32bit,SP,BE)
Build Date: Wed Nov 28 18:21:10 CST 2007 (andy@BS5)(Revision: 44)
Copyright © 2000-2006 Broadcom Corporation.
Boot Address 0xbfc00000
Initializing Arena.
Initializing Devices.
Parallel flash device: name AM29LV160B, id 0x2249, size 2048KB
error on Ethernet Switch setup
Failed initializing enet hardware
CPU type 0x29010: 240MHz
Total memory: 8388608 bytes (8MB)
Total memory used by CFE: 0x80401000 - 0x80527660 (1205856)
Initialized Data: 0x8041CE80 - 0x8041EE90 (8208)
BSS Area: 0x8041EE90 - 0x80425660 (26576)
Local Heap: 0x80425660 - 0x80525660 (1048576)
Stack Area: 0x80525660 - 0x80527660 (8192)
Text (code) segment: 0x80401000 - 0x8041CE80 (114304)
Boot area (physical): 0x00528000 - 0x00568000
Relocation Factor: I:00000000 - D:00000000
Board IP address : 192.168.1.1:ffffff00
Host IP address : 192.168.1.100
Gateway IP address :
Run from flash/host (f/h) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 1
Board Id (0-10) : DSL-2540U
Number of MAC Addresses (1-32) : 10
Base MAC Address : **:**:**:**:**:**
PSI Size (1-64) KBytes : 24
Could not activate network interface 'eth0': CFE error -1
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 0
Code Address: 0x80010000, Entry Address: 0x801ad018
Decompression OK!
Entry at 0x801ad018
Starting program at 0x801ad018
Linux version 2.6.8.1 (jenny@BS5) (gcc version 3.4.2) #1 Fri Jan 11 11:23:01 CST 2008
DSL-2540U prom init
CPU revision is: 00029010
Determined physical RAM map:
memory: 007a0000 @ 00000000 (usable)
On node 0 totalpages: 1952
DMA zone: 1952 pages, LIFO batch:1
Normal zone: 0 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
brcm mips: enabling icache and dcache...
Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Primary data cache 8kB 2-way, linesize 16 bytes.
PID hash table entries: 32 (order 5: 256 bytes)
Using 120.000 MHz high precision timer.
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 5808k/7808k available (1437k kernel code, 1980k reserved, 210k data, 68k init, 0k highmem)
Calibrating delay loop... 239.20 BogoMIPS
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Checking for 'wait' instruction... unavailable.
NET: Registered protocol family 16
Total Flash size: 2048K with 35 sectors
File system address: 0xbfc10100
Can't analyze prologue code at 80175dd4
Initializing Cryptographic API
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
NET: Registered protocol family 24
Using noop io scheduler
bcm963xx_mtd driver v1.0
brcmboard: brcm_board_init entry
======= GPIO CONFIG_BCM96338 inited ========
Serial: BCM63XX driver $Revision: 3.00 $
ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 1024)
Initializing IPsec netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
Ebtables v2.0 registered
NET: Registered protocol family 8
NET: Registered protocol family 20
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 68k freed
init started: BusyBox v1.00 (2008.01.11-03:24+0000) multi-call binary
Algorithmics/MIPS FPU Emulator v1.5
BusyBox v1.00 (2008.01.11-03:24+0000) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
Loading drivers and kernel modules...
atmapi: module license 'Proprietary' taints kernel.
adsl: adsl_init entry
blaadd: blaa_detect entry
Broadcom BCMPROCFS v1.0 initialized
Broadcom BCM6338A2 Ethernet Network Device v0.3 Jan 11 2008 11:21:58
Config Ethernet Switch Through MDIO Pseudo PHY Interface
dgasp: kerSysRegisterDyingGaspHandler: eth0 registered
eth0: MAC Address: **:**:**:**:**:**
is not default cfg.
is not default cfg.
BcmAdsl_Initialize=0xC00673F8, g_pFnNotifyCallback=0xC007FC64
AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000
pSdramPHY=0xA07FFFF8, 0x0 0x80000
AdslCoreHwReset: AdslOemDataAddr = 0xA07FD3D4
dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
ATM proc init !!!
ip_tables: © 2000-2002 Netfilter core team
ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack
ip_conntrack_pptp version 2.1 loaded
ip_nat_pptp version 2.0 loaded
insmod: cannot open module `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_conntrack_h323.ko': No such file or directory
insmod: cannot open module `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_nat_h323.ko': No such file or directory
ip_nat_ftp: Unknown symbol needs_ip_conntrack_ftp
insmod: cannot insert `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_nat_ftp.ko': Success (2): Success
ip_nat_sip: Unknown symbol sip_getpkt_type
ip_nat_sip: Unknown symbol ct_sip_hdrs
ip_nat_sip: Unknown symbol ct_sip_data
ip_nat_sip: Unknown symbol ct_sip_get_info
ip_nat_sip: Unknown symbol set_expected_rtp
insmod: cannot insert `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_nat_sip.ko': Success (2): Success
==> Bcm963xx Software Version: RU_DSL-2540U_1.00_01112008 <==
logread: not found
device eth0 entered promiscuous mode
br0: port 1(eth0) entering learning state
br0: topology change detected, propagating
br0: port 1(eth0) entering forwarding state
BcmRfc2684_init interface is not up nas_0_1_32!
pvc2684ctl -a -v 0.1.32 -f &
pvc2684d: Interface "nas_0_1_32" created sucessfully
pvc2684d: Communicating over ATM 0.1.32, encapsulation: LLC
device eth0 left promiscuous mode
br0: port 1(eth0) entering disabled state
sntp: host not found
ioctl, p_name=diapd
*** diap wait system init 1 sec start
##############status LED blink now##################
no config file /etc/resolv.conf
*** diap wait system init 1 sec end
dft, wanIpAddress = , wanSubnetMask =
vpi = 1, vci = 32, conId = 1, portId = 0
nat = 1, firewall = 1
Plugin pppoe loaded.
RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Plugin pppoe called.
