Дмитрий К
Пользователи
  • Публикации
    2
  • Зарегистрирован
  • Посещение
О Дмитрий К
  • Звание
    Абитуриент
    Абитуриент
Контакты
  • ICQ
    Array
  1. Лог прилагаю CFE version 1.0.37-8.7 for BCM96338 (32bit,SP,BE) Build Date: Wed Nov 28 18:21:10 CST 2007 (andy@BS5)(Revision: 44) Copyright © 2000-2006 Broadcom Corporation. Boot Address 0xbfc00000 Initializing Arena. Initializing Devices. Parallel flash device: name AM29LV160B, id 0x2249, size 2048KB error on Ethernet Switch setup Failed initializing enet hardware CPU type 0x29010: 240MHz Total memory: 8388608 bytes (8MB) Total memory used by CFE: 0x80401000 - 0x80527660 (1205856) Initialized Data: 0x8041CE80 - 0x8041EE90 (8208) BSS Area: 0x8041EE90 - 0x80425660 (26576) Local Heap: 0x80425660 - 0x80525660 (1048576) Stack Area: 0x80525660 - 0x80527660 (8192) Text (code) segment: 0x80401000 - 0x8041CE80 (114304) Boot area (physical): 0x00528000 - 0x00568000 Relocation Factor: I:00000000 - D:00000000 Board IP address : 192.168.1.1:ffffff00 Host IP address : 192.168.1.100 Gateway IP address : Run from flash/host (f/h) : f Default host run file name : vmlinux Default host flash file name : bcm963xx_fs_kernel Boot delay (0-9 seconds) : 1 Board Id (0-10) : DSL-2540U Number of MAC Addresses (1-32) : 10 Base MAC Address : **:**:**:**:**:** PSI Size (1-64) KBytes : 24 Could not activate network interface 'eth0': CFE error -1 *** Press any key to stop auto run (1 seconds) *** Auto run second count down: 0 Code Address: 0x80010000, Entry Address: 0x801ad018 Decompression OK! Entry at 0x801ad018 Starting program at 0x801ad018 Linux version 2.6.8.1 (jenny@BS5) (gcc version 3.4.2) #1 Fri Jan 11 11:23:01 CST 2008 Parallel flash device: name AM29LV160B, id 0x2249, size 2048KB DSL-2540U prom init CPU revision is: 00029010 Determined physical RAM map: memory: 007a0000 @ 00000000 (usable) On node 0 totalpages: 1952 DMA zone: 1952 pages, LIFO batch:1 Normal zone: 0 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200 brcm mips: enabling icache and dcache... Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes. Primary data cache 8kB 2-way, linesize 16 bytes. PID hash table entries: 32 (order 5: 256 bytes) Using 120.000 MHz high precision timer. Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory: 5808k/7808k available (1437k kernel code, 1980k reserved, 210k data, 68k init, 0k highmem) Calibrating delay loop... 239.20 BogoMIPS Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Checking for 'wait' instruction... unavailable. NET: Registered protocol family 16 Total Flash size: 2048K with 35 sectors File system address: 0xbfc10100 Can't analyze prologue code at 80175dd4 Initializing Cryptographic API PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered MPPE/MPPC encryption/compression module registered NET: Registered protocol family 24 Using noop io scheduler bcm963xx_mtd driver v1.0 brcmboard: brcm_board_init entry ======= GPIO CONFIG_BCM96338 inited ======== Serial: BCM63XX driver $Revision: 3.00 $ ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 512 bind 1024) Initializing IPsec netlink socket NET: Registered protocol family 1 NET: Registered protocol family 17 NET: Registered protocol family 15 Ebtables v2.0 registered NET: Registered protocol family 8 NET: Registered protocol family 20 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com> All bugs added by David S. Miller <davem@redhat.com> VFS: Mounted root (squashfs filesystem) readonly. Freeing unused kernel memory: 68k freed init started: BusyBox v1.00 (2008.01.11-03:24+0000) multi-call binary Algorithmics/MIPS FPU Emulator v1.5 BusyBox v1.00 (2008.01.11-03:24+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. Loading drivers and kernel modules... atmapi: module license 'Proprietary' taints kernel. adsl: adsl_init entry blaadd: blaa_detect entry Broadcom BCMPROCFS v1.0 initialized Broadcom BCM6338A2 Ethernet Network Device v0.3 Jan 11 2008 11:21:58 Config Ethernet Switch Through MDIO Pseudo PHY Interface dgasp: kerSysRegisterDyingGaspHandler: eth0 registered eth0: MAC Address: **:**:**:**:**:** is not default cfg. is not default cfg. BcmAdsl_Initialize=0xC00673F8, g_pFnNotifyCallback=0xC007FC64 AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000 pSdramPHY=0xA07FFFF8, 0x0 0x80000 AdslCoreHwReset: AdslOemDataAddr = 0xA07FD3D4 AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000 dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered ATM proc init !!! ip_tables: © 2000-2002 Netfilter core team ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack ip_conntrack_pptp version 2.1 loaded ip_nat_pptp version 2.0 loaded insmod: cannot open module `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_conntrack_h323.ko': No such file or directory insmod: cannot open module `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_nat_h323.ko': No such file or directory ip_nat_ftp: Unknown symbol needs_ip_conntrack_ftp insmod: cannot insert `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_nat_ftp.ko': Success (2): Success ip_nat_sip: Unknown symbol sip_getpkt_type ip_nat_sip: Unknown symbol ct_sip_hdrs ip_nat_sip: Unknown symbol ct_sip_data ip_nat_sip: Unknown symbol ct_sip_get_info ip_nat_sip: Unknown symbol set_expected_rtp insmod: cannot insert `/lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_nat_sip.ko': Success (2): Success ==> Bcm963xx Software Version: RU_DSL-2540U_1.00_01112008 <== logread: not found device eth0 entered promiscuous mode br0: port 1(eth0) entering learning state br0: topology change detected, propagating br0: port 1(eth0) entering forwarding state BcmRfc2684_init interface is not up nas_0_1_32! pvc2684ctl -a -v 0.1.32 -f & pvc2684d: Interface "nas_0_1_32" created sucessfully pvc2684d: Communicating over ATM 0.1.32, encapsulation: LLC device eth0 left promiscuous mode br0: port 1(eth0) entering disabled state device eth0 entered promiscuous mode br0: port 1(eth0) entering learning state br0: topology change detected, propagating br0: port 1(eth0) entering forwarding state sntp: host not found ioctl, p_name=diapd *** diap wait system init 1 sec start ##############status LED blink now################## no config file /etc/resolv.conf *** diap wait system init 1 sec end dft, wanIpAddress = , wanSubnetMask = vpi = 1, vci = 32, conId = 1, portId = 0 nat = 1, firewall = 1 br0: port 1(eth0) entering disabled state Plugin pppoe loaded. RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3 Plugin pppoe called.
  2. Возникла проблема с данным модемом вышла из строя микросхема BCM5325EKQMG которая отвечает как я понял за 5 портовый свич. Не мог бы кто-то подсказать распиновку этой микросхемы, думаю попробовать пробросить напрямик 1 порт Ethernet , например на первый 1 порт.Возможно ли такое.Микросхема свича уже удалена. Роутер благополочно поднимает сессию суда по индикации и работает.статусные диоды работают.интересуют ноги микросхемы по которым сигнал идёт от процессора. Заранее благодарен за ответ.
