Есть роутер Dir 320 (прошивка OpenWrt Kamikaze - With X-Wrt Extensions 8.09). Установлен модуль chilispot (config файл настроен через dhotspot.com). Исходники файла chilli.conf (см. ниже)....
Проблема в следующем роутер не идет через страничку авторизации, а просто отправляет всех желающих в инет :(
Настройки котрые необходимо внести в файл (с сайта hotspot ):
Chillispot: enable
Seperate Wifi from the LAN Bridge: enable
Primary Radius Server IP/DNS: host.dhotspot.com
Backup Radius Server IP/DNS: backup.dhotspot.com
DNS IP: Your ISP DNS Address Details
Remote Network: 192.168.182.0/24
Redirect URL: http://www.dhotspot.com/member/index.php/DH75003/
Shared Key: testing123
DHCP Interface: WLAN
Radius NAS ID: DH75003
UAM Secret: DH75003
UAM Any DNS
UAM Allowed: dhotspot.com
MACAuth disable
Непосредственно сам файл:
# Sample ChilliSpot configuration file
# TAG: fg
# Include this flag if process is to run in the foreground
#fg
# TAG: debug
# Include this flag to include debug information.
#debug
# TAG: interval
# Re-read configuration file at this interval. Will also cause new domain
# name lookups to be performed. Value is given in seconds.
#interval 3600
# TAG: pidfile
# File to store information about the process id of the program.
# The program must have write access to this file/directory.
#pidfile /var/run/chilli.pid
# TAG: statedir
# Directory to use for nonvolatile storage.
# The program must have write access to this directory.
# This tag is currently ignored
#statedir ./
# TUN parameters
# TAG: net
# IP network address of external packet data network
# Used to allocate dynamic IP addresses and set up routing.
# Normally you do not need to uncomment this tag.
#net 192.168.182.0/24
# TAG: dynip
# Dynamic IP address pool
# Used to allocate dynamic IP addresses to clients.
# If not set it defaults to the net tag.
# Do not uncomment this tag unless you are an experienced user!
dynip 192.168.182.0/24
# TAG: statip
# Static IP address pool
# Used to allocate static IP addresses to clients.
#statip 192.168.182.0/24
# TAG: dns1
# Primary DNS server.
# Will be suggested to the client.
# If omitted the system default will be used.
#dns1 172.16.0.5
# TAG: dns2
# Secondary DNS server.
#dns2 172.16.0.6
# TAG: domain
# Domain name
#domain key.chillispot.org
# TAG: ipup
# Script executed after network interface has been brought up.
# Executed with the following parameters: <devicename> <ip address>
# <mask>
#ipup /etc/chilli.ipup
# TAG: ipdown
# Script executed after network interface has been taken down.
# <mask>
#ipdown /etc/chilli.ipdown
# TAG: conup
# Script executed after a user has been authenticated.
# <mask> <user ip address> <user mac address> <filter ID>
#conup /etc/chilli.conup
# TAG: conup
# Script executed after a user has disconnected.
#conup /etc/chilli.condown
# Radius parameters
# TAG: radiuslisten
# IP address to listen to
#radiuslisten 127.0.0.1
# TAG: radiusserver1
# IP address of radius server 1
# For most installations you need to modify this tag.
radiusserver1 host.dhotspot.com
# TAG: radiusserver2
# IP address of radius server 2
# If you have only one radius server you should set radiusserver2 to the
# same value as radiusserver1.
radiusserver2 backup.dhotspot.com
# TAG: radiusauthport
# Radius authentication port
# The UDP port number to use for radius authentication requests.
# The same port number is used for both radiusserver1 and radiusserver2.
#radiusauthport 1812
# TAG: radiusacctport
# Radius accounting port
# The UDP port number to use for radius accounting requests.
#radiusacctport 1813
# TAG: radiussecret
# Radius shared secret for both servers
# For all installations you should modify this tag.
radiussecret testing123
# TAG: radiusnasid
# Radius NAS-Identifier
#radiusnasid nas01
# TAG: radiusnasip
# Radius NAS-IP-Address
#radiusnasip 127.0.0.1
# TAG: radiuscalled
# Radius Called-Station-ID
#radiuscalled 00133300
# TAG: radiuslocationid
# WISPr Location ID. Should be in the format: isocc=<ISO_Country_Code>,
# cc=<E.164_Country_Code>,ac=<E.164_Area_Code>,network=<ssid/ZONE>
#radiuslocationid isocc=us,cc=1,ac=408,network=ACMEWISP_NewarkAirport
# TAG: radiuslocationname
# WISPr Location Name. Should be in the format:
# <HOTSPOT_OPERATOR_NAME>,<LOCATION>
#radiuslocationname ACMEWISP,Gate_14_Terminal_C_of_Newark_Airport
# Radius proxy parameters
# TAG: proxylisten
#proxylisten 10.0.0.1
# TAG: proxyport
# UDP port to listen to.
# If not specified a port will be selected by the system
#proxyport 1645
# TAG: proxyclient
# Client(s) from which we accept radius requests
#proxyclient 10.0.0.1/24
# TAG: proxysecret
# Radius proxy shared secret for all clients
# If not specified defaults to radiussecret
#proxysecret testing123
# Remote configuration management
# TAG: confusername
# If confusername is specified together with confpassword chillispot
# will at regular intervals specified by the interval option query the
# radius server for configuration information.
#confusername conf
# TAG: confpassword
#confpassword secret
# DHCP Parameters
# TAG: dhcpif
# Ethernet interface to listen to.
# This is the network interface which is connected to the access points.
# In a typical configuration this tag should be set to eth1.
dhcpif wl0
# TAG: dhcpmac
# Use specified MAC address.
# An address in the range 00:00:5E:00:02:00 - 00:00:5E:FF:FF:FF falls
# within the IANA range of addresses and is not allocated for other
# purposes.
#dhcpmac 00:00:5E:00:02:00
# TAG: lease
# Time before DHCP lease expires
#lease 600
# Universal access method (UAM) parameters
# TAG: uamserver
# URL of web server handling authentication.
uamserver dhotspot.com
# TAG: uamhomepage
# URL of welcome homepage.
# Unauthenticated users will be redirected to this URL. If not specified
# users will be redirected to the uamserver instead.
uamhomepage http://www.dhotspot.com/member/index.php/DH75003/
# TAG: uamsecret
# Shared between chilli and authentication web server
uamsecret DH75003
# TAG: uamlisten
# IP address to listen to for authentication requests
#uamlisten 192.168.182.1
# TAG: uamport
# TCP port to listen to for authentication requests
#uamport 3990
# TAG: uamallowed
# Comma separated list of domain names, IP addresses or network segments
# the client can access without first authenticating.
# It is possible to specify this tag multiple times.
uamallowed 192.168.182.0/24
# TAG: uamanydns
# If this flag is given unauthenticated users are allowed to use
# any DNS server.
#uamanydns
# MAC authentication
# TAG: macauth
# If this flag is given users will be authenticated only on their MAC
# address.
#macauth
# TAG: macallowed
# List of MAC addresses.
# The MAC addresses specified in this list will be authenticated only on
# their MAC address.
# This tag is ignored if the macauth tag is given.
#macallowed 00-0A-5E-AC-BE-51,00-30-1B-3C-32-E9
# TAG: macpasswd
# Password to use for MAC authentication.
#macpasswd password
# TAG: macsuffix
# Suffix to add to MAC address in order to form the username.
#macsuffix suffix
