cisco 7206 (NPE150) processor (revision B) with 114688K/16384K bytes of memory.
Processor board ID 6622994
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
6 slot midplane, Version 1.3
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Number of Fast PAs = 6
Number of Fast+Medium PAs = 6
Total number of PA bandwidth points consumed = 900
Please refer to the following document "Cisco 7200 Series Port
Adaptor Hardware Configuration Guidelines" on CCO <www.cisco.com>,
for c7200 bandwidth points oversubscription/usage guidelines.
WARNING: Number of Fast PAs Exceeds 3
WARNING: Number of Fast+Medium PAs Exceeds 5
WARNING: Total number of bandwidth points Exceeds 800
3 FastEthernet/IEEE 802.3 interface(s)
3 FDDI network interface(s)
2 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
1024K bytes of packet SRAM memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
добавлено
комутатор Dlink DES-3250TG (управляемый, 48 портов 2 порта 1Gb, 2gbic) - 14 000 р.
комутатор Dlink DGS-1016TL (16 портов неуправляемый стоечный) - 2 500 р.
