Здравствуйте.
Поставил себе NOC 0.2.2, при установке особых проблем не возникло, но при выполнении ./manage.py migrate возникла такая ошибка:
Running migrations for main:
- Migrating forwards to 0008_default_mime_types.
> main: 0005_init_languages
= INSERT INTO main_language(name,native_name,is_active) VALUES(%s,%s,%s) ['Afar', 'Afaraf', False]
= INSERT INTO main_language(name,native_name,is_active) VALUES(%s,%s,%s) ['Abkhazian', '\xd0\x90\xd2\xa7\xd1\x81\xd1\x83\xd0\xb0', False]
Traceback (most recent call last):
File "./manage.py", line 11, in <module>
execute_manager(settings)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/core/management/__init__.py", line 340, in execute_manager
utility.execute()
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/core/management/__init__.py", line 295, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/core/management/base.py", line 192, in run_from_argv
self.execute(*args, **options.__dict__)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/core/management/base.py", line 219, in execute
output = self.handle(*args, **options)
File "/usr/local/lib/python2.5/site-packages/South-0.5-py2.5.egg/south/management/commands/migrate.py", line 81, in handle
skip = skip,
File "/usr/local/lib/python2.5/site-packages/South-0.5-py2.5.egg/south/migration.py", line 526, in migrate_app
result = run_forwards(mapp, [mname], fake=fake, db_dry_run=db_dry_run, silent=silent)
File "/usr/local/lib/python2.5/site-packages/South-0.5-py2.5.egg/south/migration.py", line 320, in run_forwards
silent = silent,
File "/usr/local/lib/python2.5/site-packages/South-0.5-py2.5.egg/south/migration.py", line 264, in run_migrations
runfunc()
File "/opt/noc/main/migrations/0005_init_languages.py", line 203, in forwards
db.execute("INSERT INTO main_language(name,native_name,is_active) VALUES(%s,%s,%s)",[lang,native,lang=="English"])
File "/usr/local/lib/python2.5/site-packages/South-0.5-py2.5.egg/south/db/generic.py", line 70, in execute
cursor.execute(sql, params)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/backends/util.py", line 19, in execute
return self.cursor.execute(sql, params)
psycopg2.DataError: character 0xd090 of encoding "UTF8" has no equivalent in "LATIN1"
При запуске, в веб-интерфейсе, во всех таблицах кроме main происходит следующее:
Environment:
Request Method: GET
Request URL: http://10.1.1.7:8080/admin/sa/managedobject/
Django Version: 1.0.2 final
Python Version: 2.5.4
Installed Applications:
['django.contrib.auth',
'django.contrib.contenttypes',
'django.contrib.sessions',
'django.contrib.sites',
'django.contrib.admin',
'south',
'noc.main',
'noc.sa',
'noc.fm',
'noc.cm',
'noc.ip',
'noc.vc',
'noc.dns',
'noc.peer',
'noc.kb']
Installed Middleware:
('django.middleware.common.CommonMiddleware',
'django.contrib.sessions.middleware.SessionMiddleware',
'django.contrib.auth.middleware.AuthenticationMiddleware',
'django.middleware.doc.XViewMiddleware',
'django.middleware.transaction.TransactionMiddleware')
Traceback:
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/core/handlers/base.py" in get_response
86. response = callback(request, *callback_args, **callback_kwargs)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/contrib/admin/sites.py" in root
157. return self.model_page(request, *url.split('/', 2))
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/views/decorators/cache.py" in _wrapped_view_func
44. response = view_func(request, *args, **kwargs)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/contrib/admin/sites.py" in model_page
176. return admin_obj(request, rest_of_url)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/contrib/admin/options.py" in __call__
189. return self.changelist_view(request)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/contrib/admin/options.py" in changelist_view
630. self.date_hierarchy, self.search_fields, self.list_select_related, self.list_per_page, self)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/contrib/admin/views/main.py" in __init__
39. self.root_query_set = model_admin.queryset(request)
File "/opt/noc/sa/admin.py" in queryset
93. return ManagedObject.queryset(request.user)
File "/opt/noc/sa/models.py" in queryset
147. ids=[o.id for o in cls.objects.all() if o.has_access(user)]
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/models/query.py" in _result_iter
185. self._fill_cache()
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/models/query.py" in _fill_cache
618. self._result_cache.append(self._iter.next())
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/models/query.py" in iterator
275. for row in self.query.results_iter():
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/models/sql/query.py" in results_iter
206. for rows in self.execute_sql(MULTI):
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/models/sql/query.py" in execute_sql
1734. cursor.execute(sql, params)
File "/usr/local/lib/python2.5/site-packages/Django-1.0.2_final-py2.5.egg/django/db/backends/util.py" in execute
19. return self.cursor.execute(sql, params)
Exception Type: ProgrammingError at /admin/sa/managedobject/
Exception Value: relation "sa_managedobject" does not exist
Вопрос: связано-ли первое со вторым и как с этим бороться. Система Slackware 12.1, все пакеты ставил по мануалу.
Заранее спасибо.
