теперь другая проблема:
http://192.168.1.60/postfix-admin/setup.php
Checking for dependencies:
Warning: Magic Quotes: ON (internal workaround used)
Depends on: presence config.inc.php - OK
Warning: $CONF['configured'] is 'false'.
You must edit your config.inc.php and change this to true (this indicates you've created the database and user)
Depends on: MySQL 3.23, 4.0 - OK
Error: Can't connect to database
Please edit the $CONF['database_*'] parameters in config.inc.php.
DEBUG INFORMATION:
Connect: Access denied for user 'postfix'@'localhost' (using password: YES)
Depends on: session - OK
Depends on: pcre - OK
Error: Depends on: multibyte string - NOT FOUND
To install multibyte string support, install php5-mbstring
Warning: Depends on: IMAP functions - NOT FOUND
To install IMAP support, install php5-imap
Without IMAP support, you won't be able to create subfolders when creating mailboxes.
Please fix the errors listed above.
