megagrizly
Пользователи-
Публикации
12 -
Зарегистрирован
Посещение
О megagrizly
Звание
Абитуриент
Контакты
ICQ
Array
Rtl8186 Firmware
тему ответил в dgreen пользователя megagrizly в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
D-Link G700AP, wive-ng 0.3.18. Хочу настоить wpa2-psk. Подключаюсь телефоном, пароль не подходит. ЧЯДНТ? В конфигах поменял вот что: /etc/network/wifi/general AUTHTYPE=SHARED WPA=yes /etc/wpa.conf #0 – disable, 1 – WEP, 2 – WPA, 4 – WPA2 only, 6 – WPA2 mixed encryption = 4 #“string_value”, 1-32 char ssid = "SOME-WiFi" #0/1 – disable/enable 1x Radius authentication enable1x = 0 #0/1 – disable/enable MAC authentication enableMacAuth = 0 #0/1 – disable/enable none WPA client support when WPA is set supportNonWpaClient = 0 #1 – WEP64, 2 – WEP128 Refer when encryption is set 1 (wep) wepKey = 0 wepGroupKey = "" #1 – Radius, 2 – PSK (pre-shared key) authentication = 2 #1 – TKIP, 2 – AES unicastCipher = 1 wpa2UnicastCipher = 1 #0 – use psk value as key in raw data, 1 – use passphrase algorithm to convert psk value usePassphrase = 1 #“string_value”, if usePassphrase=0 (raw data), it should be 64 hex digits. #If usePassphrase=1, the string length should be >=8 and <=64. psk = "123456789" #Group key re-key time groupRekeyTime = 86400 #UDP Port number of radius server rsPort = 1812 #IP address of radius server (e.g., 192.168.1.1) rsIP = 0.0.0.0 #“string_value”, password of radius server with 31 char in max rsPassword = "" #Max retry number of request packet with radius server rsMaxReq = 3 #Timeout time (in second) of waiting rsp packet of radius rsAWhile = 5 #0/1 – disable/enable accounting radius server accountRsEnabled = 0 #UDP Port number of accounting radius server accountRsPort = 1813 #IP address of accounting radius server accountRsIP = 0.0.0.0 #“string_value”, password of accounting radius server with 31 char in max accountRsPassword = "" #0/1 – disable/enable the feature of statistic update with accounting server accountRsUpdateEnabled = 0 #Update time in seconds accountRsUpdateTime = 60 #Max retry number of request packet with accounting radius server accountRsMaxReq = 3 #Timeout time (in second)of waiting rsp packet of accounting radius server accountRsAWhile = 5 -
Rtl8186 Firmware
Прошил G700AP 0.3.18, после весьма безобидных настроек при включении перестал поднматься eth0. В логах чисто, в чем может быть проблема? Если сбросить настройки, то поднимается на ура... /etc/network/interfaces ETH0_ENABLED=yes ETH0_FORCEIP=no ETH0_IN_BR0=no ETH0_USE_DHCP=no ETH0_IPADDR=192.168.3.2/24 WLAN_ENABLED=yes WLAN_FORCEIP=no WLAN_IN_BR0=no WLAN_USE_DHCP=no WLAN_IPADDR=192.168.2.1/24 /etc/network/routes #!/bin/sh ip ro add default via 192.168.3.1 /etc/network/iptables #!/bin/sh iptables -A FORWARD -s 192.168.3.0/24 -j ACCEPT iptables -A FORWARD -d 192.168.3.0/24 -j ACCEPT iptables -t nat -A POSTROUTING -o eth0 -s 192.168.2.0/24 -j MASQUERADE /etc/udhcpd.conf interface wlan0 start 192.168.2.2 end 192.168.2.5 max_leases 30 opt dns 8.8.8.8 4.4.4.4 option subnet 255.255.255.0 opt router 192.168.2.1 option lease 86400 -
Rtl8186 Firmware
КАК узнать сколько пользователей подключено к точке и их маки? -
Rtl8186 Firmware
Подскажите как можно сделать мониторинг машин подключенных к точке (IP, MAC)? -
Rtl8186 Firmware
Народ покажите свою конфу /etc/network/wifi/general для wive-ng или расскажите/дайте описание всех параметров конфига на русском. Спасибо. -
Rtl8186 Firmware
Отключить eth1 ещё раз 50 внимательно прочитать все коментарии подумать чего хочется достигнуть ибо в конфигах небойми что. Прочитать ман на udhcpd исходя из полученных знаний настроить. eth1 - это на клиенте. Конфиги рабочие - проверял на wive-0.6.1 -
Rtl8186 Firmware
если у кого получилось завести dhcp на wive-ng выложите пожалуйста свою конфу -
Rtl8186 Firmware
Не работает dhcp, по wifi. D-Link DWL-G700AP с прошивкой Wive-NG 0.1.12. ifconfig eth0 Link encap:Ethernet HWaddr 00:01:02:03:04:05 inet addr:192.168.0.5 Bcast:192.168.0.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:132 errors:0 dropped:0 overruns:0 frame:0 TX packets:47 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:16148 (15.7 KiB) TX bytes:7638 (7.4 KiB) Interrupt:4 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) wlan0 Link encap:Ethernet HWaddr 00:E0:4C:81:86:86 inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:17 errors:0 dropped:0 overruns:0 frame:0 TX packets:31 errors:11 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:1921 (1.8 KiB) TX bytes:1000 (1000.0 B) Interrupt:2 /etc/network/interfaces #Ethernet port1 config ETH0_ENABLED=yes ETH0_FORCEIP=no ETH0_IN_BR0=no ETH0_USE_DHCP=no ETH0_IPADDR=192.168.0.5/24 #Wireliss port config WLAN_ENABLED=yes WLAN_FORCEIP=no WLAN_IN_BR0=no WLAN_USE_DHCP=no WLAN_IPADDR=192.168.2.1/24 /etc/network/routes #!/bin/sh ip ro add default via 192.168.0.1 /etc/network/iptables #!/bin/sh iptables -P INPUT ACCEPT iptables -P OUTPUT ACCEPT iptables -P FORWARD ACCEPT iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE /etc/udhcpd.conf interface wlan0 start 192.168.2.2 end 192.168.2.3 opt dns xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx option subnet 255.255.255.0 opt router 192.168.2.1 option lease 86400 /etc/network/wifi/general #---------------------------------GENERAL WIRELESS INTERFACE CONFIG-------------------------------------- #Set Mode: AP/CLIENT/ADHOC RMODE=AP #Set ESSID of wirelless Infrastructure Network ESSID=my-wifi #This is name BS to first probe connect (12 digits macaddress) #JOINBS=0019CB7515A2 #Deny the association SSID of вanyв including upper and lower cases. #DSSID=BAD_SSID #This is AP is hidden #HIDEAP=no #Set WiFi mode b/g/bg MODE=bg #If enabled in B+G mode, AP will deny the association from 11B STA. #DENYLEGACY=no #G protection is 802.11g mode prioriry (instead use G only mode) #GPROTECTION=no #Use cts to Self for protection mode (may be need by some old devices) #CTS2SELF=no #Set Channel here 1-14 (0 for auto) CHANNEL=0 #Set Initial Gain: in range 0-7 #GAIN=7 #AUTOGAIN=yes #Dynamic RF sensitivity adjustment #DRSA=yes #Set TransmitPower for CCK(802.11b) modulation (1-4b) #Attention! The parametre increase can cause failure RF of the module. #More 2A need fun. #CCKPOWER=8 #Set TransmitPower for OFDM(802.11g) modulation. Recomended 1A-25. #Attention! The parametre increase can cause failure RF of the module. #16(default indoor),20(default outdoor, need fun) #OFDMPOWER=16 #Enhanced Tx Power #ENHTX=yes #Show hidden BS #SHOWHIDDEN=yes #Preample type SHORT/LONG #SHORTPREAMBLE=yes #ACK timeout. Range 0-255. 255 is auto (self) configuration #ACK=255 #Roaming support (IEEE 802.11f server mode) on AP mode #ENABLE_ROAMING=no #Fast roaming (IEEE 802.11f client support) on client mode #FAST_ROAMING=no #----------------------------------SPEED MODE CONFIGS------------------------------------------------------ #FIXRATE=no #your don`t use fixrate, instead select basicrates and operates for need speed mode #BASICRATES=4095 #OPRATES=4095 #WLAN_BURST=no #----------------------------------ADVANCED PARAMETRS------------------------------------------------------ #Interval of service packets transmit #BCINIT=200 #Frame size for fragment #FRAGTHRES=2346 #RTS/CTS Threshold #RTSTHRES=2347 #Time of last recive frame when connection is closed (30 minutes of seconds) #EXPIRED_TIME=1800 #Count of short rertry send frames (Fast hand shake without the coordination of parameters) #SHORTRETRY=3 #Count of long rertry send frames or frame dead(Slow hand shake with the full coordination of parameters) #LONGRETRY=2 #Change AP mode wlan led type = 6(enable), CB mode = 2(link), 7 (Enable/tx/rx), CB mode = 5 (link/tx/rx) LED_TYPE=6 #Realtek turmo mode Auto/Always/Disable (actual only RTL based devices and fixrate disabled) #TURBO_MODE=Auto #Prioriry transmit maximum speed on realtek turbo mode #TXPRIO=yes #Enable Quality of Service #QOS=yes #For bridged mode set this parameters # Nat2.5 is technology to change the source MAC to MAC of Wlan-interface # be carefull it says disabled, so make inverse in your decision #NAT2_5=yes # Macclone says all about itself. It just takes MAC of ETHERNET device on other end of line # and take it for Wlan-interface. be carefull if this enabled it must be one device on a line. #MACCLONE=no # Disable/Enable dhcp relay from/to wireless interface #DHCPBCST=yes #Block packets between clients connected # 0 - disable; 1 - block relay;2 - block relay but passup #BLOCK_RELAY=0 #Use lowest basic rate to send multicast and broadcast #LOWMCS=yes #---------------------------------------ACCESS OPTIONS------------------------------------------------------- #802.11 Authentication type OPEN-open system, SHAREDвshared key, AUTO-auto #AUTHTYPE=AUTO #Enable/disable access list #ACL=no #Allowed macs of client (on one through a blank) #ALLOWMACS="0015AF8BD700 004F6A010719 003005DF2049 0019CB7515A2 00027267E56A" #Enable/disable wep #WEP=no #WepKey 26 digits for 128bit #WEPKEY=11223344556677889910111213 #Enable/disable wpa/wpa2 #WPA=no #--------------------------------------WDS Options---------------------------------------------------------- #Enable/disable wds #WDS=no #Set MAC/BSSID of WDS stations for driver and wds-interfaces (first station for WDS). #WDS0_MAC="0019CB7515A2 00006c000002" #Pure WDS enable, client not have connect to this AP #WDS_ONLY=no #Give WDS packets higher priority #WDS_PRIO=yes #WDS Encrypt 0 - disabled, 1 - WEP64, 5 - WEP128 #WDS_CRYPT=0 #Passphrase or hex key for WDS mode encryption #WepKey 26 digits for WEP 128bit #WDS_WEPKEY=11223344556677889910123456 #--------------------------------------REP Options---------------------------------------------------------- #Repeater mode #REPEATER=no #REPEATER Encrypt 0 - disabled, 1 - WEP64, 5 - WEP128 #REPCRYPT=0 #Extended connection loggin with syslog #RSSI_DUMP=no #TSSI_DUMP=no #CRC_LOG=no #Be carefull. There're many Hardware-specific mibs #WLAN_USE_UNCHECKED_MIBS=no #------------------------------WPS Options NOT SUPORT in this version--------------------------------------- #Support WiFi Protection Setup #WPS=no #PIN setting for WPS вstring_valueв with 8 characters in max #PIN=12345678 #---------------------------------------Other options------------------------------------------------------- При попытке получить ip по wifi dhcp wifi-radar'ом: eth1: dhcpcd 4.0.2 starting eth1: broadcasting for a lease eth1: carrier lost eth1: received SIGTERM, stopping Как победить? -
Rtl8186 Firmware
Уже говорил, что стремаюсь спалить точку, а точнее ее флешку: после каждого эксперимента она перестает пинговаться и приходится перешивать (уже перешил не меньше сотни раз). Если кто может - поделитесь опытом, настраивать за меня точку я не прошу. Выложить свой /etc/network/interfaces вроде бы не сложно. -
Rtl8186 Firmware
wive-ng-0.1.12 Хотелось бы примеров рабочих конфигов, которые надо изменить что бы получить желаемое. -
Rtl8186 Firmware
А можно точные указания по переводу на роутер, а то уже раз в тридцатый перешиваю (у меня почемуто ресетом не сбрасывается). Прошу не из-за лени эксперементировать, а из-за страха спалить флешку девайса. -
Rtl8186 Firmware
У меня точка D-Link DWL-G700AP. Раньше юзал оригинальную wive 0.6.1, но в связи с отсутствием WPA и как следствие ансекурности, решил переползать на wive-ng. Перешил на последню wive-ng и сразу же столкнулся с тем, что по дефолту там мост, а мне нужен роутер. После нескольких эксперементальных попыток перенастройки /etc/network/interfaces точка перестала пинговаться и пришлось перешивать заного. Расскажите как перенастроить с дефолтного моста на роутер???
