spesso
Новичок
  • Публикации
    4
  • Зарегистрирован
  • Посещение
О spesso
  • Звание
    Абитуриент
  1. SIP UA configuration commands: aaa sip-ua AAA related configuration calling-info Specify treatment of calling information default Set a command to its defaults disable-early-media Disable early-media cut through exit Exit from sip-ua configuration mode max-forwards Change number of max-forwards for SIP Methods nat Enable NAT(Network Address Traversal) settings for the SIP User Agent no Negate a command or set its defaults redirection Enable call redirection (3xx) handling remote-party-id Enable Remote-Party-ID support in SIP User Agent retry Change default retries for each SIP Method set Sets the PSTN cause to SIP status code (and vice versa) andSets the PSTN cause to SIP requests sip-server Configure a SIP Server Interface srv DNS SRV Query Type suspend-resume Enable support for ISDN SUSPEND/RESUME timers SIP Signaling Timers Configuration transport Enable SIP UA transport for TCP/UDP Чего-бы научно-популярного почитать на эту тему?
  2. 2621#show inventory NAME: "2621 chassis", DESCR: "2621 chassis, Hw Serial#: JAB041305S8 (3280254705), Hw Revision: 0x102" PID: , VID: 0x102, SN: JAB041305S8 (3280254705) PVDM в данном маршрутизаторе отсутствует по DSP вот 2621#show voice dsp DSP DSP DSPWARE CURR BOOT PAK TX/RX TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT ==== === == ======== ======= ===== ======= === == ========= == ===== ============ C542 001 01 None 4.1.46 IDLE idle 0 0 1/0/0 NA 0 643/649 C542 002 01 None 4.1.46 IDLE idle 0 0 1/0/1 NA 0 622/750 C542 003 01 None 4.1.46 IDLE idle 0 0 1/1/0 NA 0 608/626 C542 004 01 None 4.1.46 IDLE idle 0 0 1/1/1 NA 0 596/593 Не совсем понял куда эту строку добавить. з.ы. спасибо за помощь.
  3. Читал, это для 2811, ! Регистрация Cisco шлюза на Asterisk sip-ua authentication username ciscotestrouter password 7 password этого нет в 2621, 12.4 в нём нет, только (C2600-IS3X-M), Version 12.3(26) стоит NM-2V Voice Network Module а в нём VIC-2FXO и VIC-2FXO-M2.
  4. День добрый, достался по случаю Cisco 2611 и решил я поднять IP-АТС и подключить его к ней, мой выбор пал на Elastix 2.5.0, чтение мануалов к решению меня не приблизило, то ли я плохо ищю то ли больно древний аппарат, но по именно 2621 и Elastix решения в инете пока не нашёл. Тут на форуме специалистов много, буду рад любой помощи в поиске решения.
