Nooob
Пользователи
  • Публикации
    2
  • Зарегистрирован
  • Посещение
Все публикации пользователя Nooob
  1. Конфиг такой: Cisco7204#show run Building configuration... Current configuration : 2747 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Cisco7204 ! aaa new-model aaa authentication login default local aaa authentication ppp default group radius aaa authorization exec default local aaa authorization network default group radius aaa accounting delay-start aaa accounting network default start-stop group radius ! username ХХХХ privilege 15 password ХХХХ username НННН privilege 8 password НННН ip subnet-zero no ip rcmd domain-lookup ip rcmd rsh-enable ip rcmd remote-host НННН 10.10.0.2 НННН enable ip cef ! ! ip name-server ХХ.ХХ.ХХХ.Х ! vpdn enable vpdn aaa attribute nas-port vpdn-nas ! vpdn-group 1 accept-dialin protocol pppoe virtual-template 1 ! call rsvp-sync ! ! interface Loopback0 ip address 1.1.1.1 255.255.255.255 ip route-cache policy ip route-cache flow ! interface FastEthernet1/0 description PPPOE clienti no ip address ip route-cache flow duplex full pppoe enable ! interface FastEthernet2/0 ip address ХХ.ХХ.ХХ.ХХ 255.255.255.0 secondary ip address 10.10.0.4 255.255.255.0 ip nat outside ip route-cache flow ip policy route-map LOOPBACK_MAP duplex full ! interface Virtual-Template1 bandwidth 100000 ip address 10.5.0.1 255.255.255.0 ip access-group 105 in ip access-group 106 out ip mtu 1492 ip nat inside ip route-cache flow ip tcp header-compression no peer default ip address ppp authentication chap pap callin ! ip nat pool nat_pool ХХ.ХХ.ХХ.ХХ ХХ.ХХ.ХХ.ХХ netmask 255.255.255.0 ip nat inside source list 101 pool nat_pool overload ip classless ip route 0.0.0.0 0.0.0.0 ХХ.ХХ.ХХ.ХХ ip route 192.168.0.0 255.255.255.0 10.10.0.1 ip flow-export version 5 ip flow-export destination 10.10.0.2 9996 no ip http server ! ip radius source-interface FastEthernet2/0 logging trap debugging access-list 101 permit ip 10.5.0.0 0.0.255.255 any access-list 105 permit ip any host 10.10.0.2 access-list 105 dynamic test1 permit ip any any access-list 106 permit ip host 10.10.0.2 any access-list 106 dynamic test2 permit ip any any access-list 108 permit ip any 10.0.0.0 0.255.255.255 route-map LOOPBACK_MAP permit 10 match ip address 108 set interface Loopback0 Virtual-Template1 ! snmp-server community public RO snmp-server community rwuser RW snmp-server enable traps tty radius-server configure-nas radius-server host 10.10.0.2 auth-port 1812 acct-port 1813 radius-server timeout 30 radius-server key ХХХХХХХХХХХХХ ! dial-peer cor custom ! ! ! ! gatekeeper shutdown ! privilege exec level 8 access-template privilege exec level 8 clear access-template privilege exec level 8 clear ! line con 0 logging synchronous line aux 0 line vty 0 4 exec-timeout 0 0 password ХХХХХХХХ ! end
  2. Ситуация такая: При tcp скорость скачивания с сервера нормальная, как только меняем настройки на РРРоЕ скорость значительно падает и постоянные сбои. Подскажите, что это может быть? С чем связано? Заранее благодарен!
