Конфиг такой:
Cisco7204#show run
Building configuration...
Current configuration : 2747 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Cisco7204
aaa new-model
aaa authentication login default local
aaa authentication ppp default group radius
aaa authorization exec default local
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting network default start-stop group radius
username ХХХХ privilege 15 password ХХХХ
username НННН privilege 8 password НННН
ip subnet-zero
no ip rcmd domain-lookup
ip rcmd rsh-enable
ip rcmd remote-host НННН 10.10.0.2 НННН enable
ip cef
ip name-server ХХ.ХХ.ХХХ.Х
vpdn enable
vpdn aaa attribute nas-port vpdn-nas
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 1
call rsvp-sync
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip route-cache policy
ip route-cache flow
interface FastEthernet1/0
description PPPOE clienti
no ip address
ip route-cache flow
duplex full
pppoe enable
interface FastEthernet2/0
ip address ХХ.ХХ.ХХ.ХХ 255.255.255.0 secondary
ip address 10.10.0.4 255.255.255.0
ip nat outside
ip route-cache flow
ip policy route-map LOOPBACK_MAP
duplex full
interface Virtual-Template1
bandwidth 100000
ip address 10.5.0.1 255.255.255.0
ip access-group 105 in
ip access-group 106 out
ip mtu 1492
ip nat inside
ip route-cache flow
ip tcp header-compression
no peer default ip address
ppp authentication chap pap callin
ip nat pool nat_pool ХХ.ХХ.ХХ.ХХ ХХ.ХХ.ХХ.ХХ netmask 255.255.255.0
ip nat inside source list 101 pool nat_pool overload
ip classless
ip route 0.0.0.0 0.0.0.0 ХХ.ХХ.ХХ.ХХ
ip route 192.168.0.0 255.255.255.0 10.10.0.1
ip flow-export version 5
ip flow-export destination 10.10.0.2 9996
no ip http server
ip radius source-interface FastEthernet2/0
logging trap debugging
access-list 101 permit ip 10.5.0.0 0.0.255.255 any
access-list 105 permit ip any host 10.10.0.2
access-list 105 dynamic test1 permit ip any any
access-list 106 permit ip host 10.10.0.2 any
access-list 106 dynamic test2 permit ip any any
access-list 108 permit ip any 10.0.0.0 0.255.255.255
route-map LOOPBACK_MAP permit 10
match ip address 108
set interface Loopback0 Virtual-Template1
snmp-server community public RO
snmp-server community rwuser RW
snmp-server enable traps tty
radius-server configure-nas
radius-server host 10.10.0.2 auth-port 1812 acct-port 1813
radius-server timeout 30
radius-server key ХХХХХХХХХХХХХ
dial-peer cor custom
gatekeeper
shutdown
privilege exec level 8 access-template
privilege exec level 8 clear access-template
line con 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
password ХХХХХХХХ
end
Ситуация такая:
При tcp скорость скачивания с сервера нормальная, как только меняем настройки на РРРоЕ скорость значительно падает и постоянные сбои.
Подскажите, что это может быть? С чем связано?
Заранее благодарен!
