Привет!
На маленьких цисках 2940 наблюдаю престраннейшую херню постоянно растет значение ignored ошибок на порту прихода. При этом сыпется IP-TV. Облазил что что только можно не могу найти причину. Если переткнуть приход в Fa порт то проблема пропадает. Я чето не нашел инфы про тюнинг буферов как их правильно надо настроить. Помоги советом как решить эту проблему. Вот данные о свиче.
Прошивка:
192-168-0-2#sh version
Cisco Internetwork Operating System Software
IOS C2940 Software (C2940-I6K2L2Q4-M), Version 12.1(22)EA14, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2010 by cisco Systems, Inc.
Compiled Tue 26-Oct-10 10:17 by nburra
Image text-base: 0x80010000, data-base: 0x8068C000
ROM: Bootstrap program is C2950 boot loader
192-168-0-2 uptime is 9 minutes
System returned to ROM by power-on
System image file is "flash:/c2940-i6k2l2q4-mz.121-22.EA14.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C2940-8TF-S (RC32300) processor (revision G0) with 19867K bytes of memory.
Processor board ID FOC1140Y11C
Last reset from system-reset
Running Standard Image
9 FastEthernet/IEEE 802.3 interface(s)
1 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:71:D3:66:80
Motherboard assembly number: 73-8783-07
Power supply part number: 341-0085-01
Motherboard serial number: FOC11393E76
Power supply serial number: FXD11297N5K
Model revision number: G0
Motherboard revision number: B0
Model number: WS-C2940-8TF-S
System serial number: FOC1140Y11C
Configuration register is 0xF
Буфера:
192-168-0-2#sh buffers
Buffer elements:
500 in free list (500 max allowed)
1182 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 512, permanent 512, peak 547 @ 00:10:28):
512 in free list (20 min, 60 max allowed)
1061 hits, 12 misses, 36 trims, 36 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 256, permanent 256, peak 265 @ 00:10:28):
256 in free list (10 min, 30 max allowed)
83 hits, 3 misses, 9 trims, 9 created
Big buffers, 1524 bytes (total 128, permanent 128):
128 in free list (5 min, 10 max allowed)
43 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 16, permanent 16):
16 in free list (0 min, 10 max allowed)
0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 8, permanent 8):
8 in free list (0 min, 5 max allowed)
Huge buffers, 18024 bytes (total 8, permanent 8):
8 in free list (0 min, 2 max allowed)
Interface buffer pools:
Calhoun Packet Receive Pool buffers, 1560 bytes (total 256, permanent 256):
224 in free list (0 min, 256 max allowed)
7029 hits, 0 misses
Порт прихода:
192-168-0-2#sh int gi0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001d.71d3.668a (bia 001d.71d3.668a)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is LX
input flow-control is off, output flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:01:04
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4607000 bits/sec, 936 packets/sec
5 minute output rate 2080000 bits/sec, 886 packets/sec
115275 packets input, 79722691 bytes, 49 no buffer
Received 20047 broadcasts (18804 multicast)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 49 ignored
0 watchdog, 18792 multicast, 0 pause input
0 input packets with dribble condition detected
97515 packets output, 28678861 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Абонентский интерфейс:
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001d.71d3.6681 (bia 001d.71d3.6681)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 12/255, rxload 5/255
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:01:29
5 minute input rate 2206000 bits/sec, 940 packets/sec
5 minute output rate 4867000 bits/sec, 999 packets/sec
135739 packets input, 39970730 bytes, 0 no buffer
Received 287 broadcasts (278 multicast)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 278 multicast, 0 pause input
154775 packets output, 102081065 bytes, 0 underruns
Конфиг:
192-168-0-2#sh run
Building configuration...
Current configuration : 1827 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname 192-168-0-2
enable secret 5 *******************
username admin privilege 15 secret 5 *******************
no errdisable detect cause gbic-invalid
ip subnet-zero
ip igmp snooping vlan 1 mrouter interface Gi0/1
ip dhcp snooping vlan 1
ip dhcp snooping information option allow-untrusted
ip dhcp snoo
00:3ping
ip domain-name Sky@Net.local
ip ssh time-out 120
ip ssh authentication-retries 3
ip ssh version 2
vtp mode transparent
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
spanning-tree extend system-id
no spanning-tree vlan 1
buffers small permanent 512
buffers middle permanent 256
buffers big permanent 128
buffers verybig permanent 16
buffers large permanent 8
buffers huge permanent 8
interface FastEthernet0/1
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface GigabitEthernet0/1
mls qos trust cos pass-through dscp
ip dhcp snooping trust
interface Vlan1
ip address 192.168.0.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
no ip http server
no cdp run
snmp-server community public RO
line con 0
logging synchronous
login
line vty 0 4
logging synchronous
login local
transport input ssh
line vty 5 15
logging synchronous
login local
transport input ssh
end
