Есть работающий, настроенный на авторизацию по wpa-eap freeradius. д-линк - никаких проблем.
cisco 1131,1231 не поддается пока настройке. Может кто-то объяснить либо дать ссылку на настройку циски для радиуса?
Циска даже не пытается обращаться к радиусу. нету броадкаста ssid, хотя галочка стоит.
Спасибо.
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname ap
enable secret 5 $1$oWt6$yozsHIiIHdgGgXv.VEvOm/
aaa new-model
aaa group server radius rad_eap
server 10.110.0.73 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
resource policy
ip subnet-zero
dot11 ssid wpa
authentication open eap eap_methods1
authentication key-management wpa version 2
mbssid guest-mode
no ids mfp client
dot11 aaa csid ietf
username Cisco password 7 02250D480809
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid wpa
channel 2452
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz...config/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.110.0.73 auth-port 1812 acct-port 1813 key 7 001C0B1E1C
radius-server vsa send accounting
control-plane
bridge 1 route ip
wlccp wds aaa csid ietf
line con 0
line vty 0 4
end
config.txt
config.txt
config.txt
В состоянии точка доступа обслужить 60 клиентов? Требования - одна точка доступа, 19кбит/с на клиента. Одновременно все клиенты не будут использовать трафик. Если в состоянии, то посоветуйте ТД.
