Помогите с настройкой cisco 1721 + VWIC-1MFT-G703
Старая ISO неподдерживат модуль.
Нашли http://www.cisco.com/en/US/products/hw/rou...00800920eb.html
При замене на другую ISO выдает :
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright © 2003 by cisco Systems, Inc.
C1700 platform with 65536 Kbytes of main memory
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
MainBoard 0X00027A80 1721
0X000F3BB0
0X00211000 public particle pools
0X002F 0X0001B800 Card in slot 0
TOTAL: 0X00347E30
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Memory required: 89117779 bytes, Memory available: 67108864 bytes
INSUFFICIENT MEMORY TO LOAD IMAGE!
The difference between Memory required and Memory available is the additional
memory you need to run the router. Alternatel
may cause the memory requirement to decrease, and may allow you to at least
use the router with reduced functionality until you get more memory.
