Биг Найдж
Пользователи-
Posts
11 -
Joined
Last visited
About Биг Найдж
Rank
Абитуриент
Контакты
ICQ
Array
Проблемы с 2940
Биг Найдж replied to Биг Найдж's topic in Активное оборудование Ethernet, IP, MPLS, SDN/NFV...
нет )) если вставить туда sfp, то заводится sfp )) так написано в документации и опробовано нет такой команды на int fa 0/9 -
Проблемы с 2940
там точно ММ, и патчик у меня ММ )) конфиги (софт сменили на последний, который есть): Current configuration : 882 bytes ! version 12.1 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Switch ! ! ip subnet-zero ! ! spanning-tree mode pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id ! ! ! ! interface FastEthernet0/1 mdix auto spanning-tree portfast spanning-tree bpdufilter enable ! interface FastEthernet0/2 ! interface FastEthernet0/3 ! interface FastEthernet0/4 ! interface FastEthernet0/5 ! interface FastEthernet0/6 ! interface FastEthernet0/7 ! interface FastEthernet0/8 ! interface FastEthernet0/9 switchport mode access ! interface GigabitEthernet0/1 switchport mode access speed 100 duplex full ! interface Vlan1 ip address 1.1.5.5 255.255.255.0 no ip route-cache ! ip http server ! line con 0 line vty 0 4 login line vty 5 15 login ! ! end Switch#sh ver Cisco Internetwork Operating System Software IOS C2940 Software (C2940-I6Q4L2-M), Version 12.1(22)EA11, RELEASE SOFTWARE (fc2) Copyright © 1986-2008 by cisco Systems, Inc. Compiled Tue 08-Jan-08 10:54 by amvarma Image text-base: 0x80010000, data-base: 0x8057C000 ROM: Bootstrap program is C2950 boot loader Switch uptime is 10 minutes System returned to ROM by power-on System image file is "flash:/c2940-i6q4l2-mz.121-22.EA11.bin" cisco WS-C2940-8TF-S (RC32300) processor (revision G0) with 20912K bytes of memory. Processor board ID FOC1140X25J Last reset from system-reset Running Standard Image 9 FastEthernet/IEEE 802.3 interface(s) 1 Gigabit Ethernet/IEEE 802.3 interface(s) The password-recovery mechanism is enabled. 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:1D:71:D2:A9:80 Motherboard assembly number: 73-8783-07 Power supply part number: 341-0085-01 Motherboard serial number: FOC11393DWQ Power supply serial number: FXD11297MRT Model revision number: G0 Motherboard revision number: B0 Model number: WS-C2940-8TF-S System serial number: FOC1140X25J Configuration register is 0xF Switch#sh int fa 0/9 FastEthernet0/9 is down, line protocol is down (notconnect) Hardware is Fast Ethernet, address is 001d.71d2.a989 (bia 001d.71d2.a989) MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, media type is 100BaseFX input flow-control is unsupported output flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:10:22, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts (0 multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out -
Проблемы с 2940
их рядом кучка лежит - не могут же все битыми быть )) -
Проблемы с 2940
Биг Найдж posted a topic in Активное оборудование Ethernet, IP, MPLS, SDN/NFV...
Добрый день! Есть 2940-8TF (с оптическим портом) - не могу завести оптический порт. Не загорается ни в связке с конвертером, ни при замыкании сам на себя. софт, дуплексы, скорость, патчи менял - не помогло. что еще можно попробовать ? -
Добрый день! Есть 2811, на которой хочется сделать модемный пул с локальной авторизацией. Не проходит авторизация даже локальных пользователей (deb ppp neg, deb ppp auth): *Jul 30 05:24:29.631: %ISDN-6-CONNECT: Interface Serial1/0:1 is now connected to 555 N/A *Jul 30 05:24:47.683: %LINK-3-UPDOWN: Interface Async0/324, changed state to up *Jul 30 05:24:47.683: As0/324 PPP: Using dialer call direction *Jul 30 05:24:47.683: As0/324 PPP: Treating connection as a callin *Jul 30 05:24:47.683: As0/324 PPP: Session handle[87000007] Session id[3] *Jul 30 05:24:47.683: As0/324 PPP: Phase is ESTABLISHING, Passive Open *Jul 30 05:24:47.683: As0/324 LCP: State is Listen *Jul 30 05:24:49.683: As0/324 LCP: Timeout: State Listen *Jul 30 05:24:49.683: As0/324 PPP: Authorization required *Jul 30 05:24:49.683: As0/324 LCP: O CONFREQ [Listen] id 1 len 28 *Jul 30 05:24:49.683: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:49.683: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:49.683: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:49.683: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:49.683: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:49.683: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:51.699: As0/324 LCP: Timeout: State REQsent *Jul 30 05:24:51.699: As0/324 LCP: O CONFREQ [REQsent] id 2 len 28 *Jul 30 05:24:51.699: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:51.699: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:51.699: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:51.699: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:51.699: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:51.699: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:53.715: As0/324 LCP: Timeout: State REQsent *Jul 30 05:24:53.715: As0/324 LCP: O CONFREQ [REQsent] id 3 len 28 *Jul 30 05:24:53.715: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:53.715: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:53.715: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:53.715: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:53.715: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:53.715: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:55.731: As0/324 LCP: Timeout: State REQsent *Jul 30 05:24:55.731: As0/324 LCP: O CONFREQ [REQsent] id 4 len 28 *Jul 30 05:24:55.731: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:55.731: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:55.731: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:55.731: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:55.731: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:55.731: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:55.823: As0/324 LCP: I CONFREQ [REQsent] id 1 len 23 *Jul 30 05:24:55.823: As0/324 LCP: ACCM 0x00000000 (0x020600000000) *Jul 30 05:24:55.823: As0/324 LCP: MagicNumber 0x44164A0F (0x050644164A0F) *Jul 30 05:24:55.823: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:55.823: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:55.823: As0/324 LCP: Callback 6 (0x0D0306) *Jul 30 05:24:55.823: As0/324 LCP: O CONFREJ [REQsent] id 1 len 7 *Jul 30 05:24:55.823: As0/324 LCP: Callback 6 (0x0D0306) *Jul 30 05:24:57.747: As0/324 LCP: Timeout: State REQsent *Jul 30 05:24:57.747: As0/324 LCP: O CONFREQ [REQsent] id 5 len 28 *Jul 30 05:24:57.747: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:57.747: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:57.747: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:57.747: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:57.747: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:57.747: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:59.023: As0/324 LCP: I CONFACK [REQsent] id 2 len 28 *Jul 30 05:24:59.023: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:59.023: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:59.023: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:59.023: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:59.027: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:59.027: As0/324 LCP: ACFC (0x0802) *Jul 30 05:24:59.027: As0/324 LCP: ID 2 didn't match 5, discarding packet *Jul 30 05:24:59.763: As0/324 LCP: Timeout: State REQsent *Jul 30 05:24:59.763: As0/324 LCP: O CONFREQ [REQsent] id 6 len 28 *Jul 30 05:24:59.763: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:24:59.763: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:24:59.763: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:24:59.763: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:24:59.763: As0/324 LCP: PFC (0x0702) *Jul 30 05:24:59.763: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:01.779: As0/324 LCP: Timeout: State REQsent *Jul 30 05:25:01.779: As0/324 LCP: O CONFREQ [REQsent] id 7 len 28 *Jul 30 05:25:01.779: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:25:01.779: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:25:01.779: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:25:01.779: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:25:01.779: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:01.779: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:02.163: As0/324 LCP: I CONFACK [REQsent] id 3 len 28 *Jul 30 05:25:02.163: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:25:02.163: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:25:02.163: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:25:02.163: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:25:02.163: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:02.163: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:02.163: As0/324 LCP: ID 3 didn't match 7, discarding packet *Jul 30 05:25:03.795: As0/324 LCP: Timeout: State REQsent *Jul 30 05:25:03.795: As0/324 LCP: O CONFREQ [REQsent] id 8 len 28 *Jul 30 05:25:03.795: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:25:03.795: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:25:03.795: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:25:03.795: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:25:03.795: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:03.795: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:05.303: As0/324 LCP: I CONFACK [REQsent] id 4 len 28 *Jul 30 05:25:05.303: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:25:05.303: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:25:05.303: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:25:05.303: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:25:05.303: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:05.303: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:05.303: As0/324 LCP: ID 4 didn't match 8, discarding packet *Jul 30 05:25:05.811: As0/324 LCP: Timeout: State REQsent *Jul 30 05:25:05.811: As0/324 LCP: O CONFREQ [REQsent] id 9 len 28 *Jul 30 05:25:05.811: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:25:05.811: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:25:05.811: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:25:05.811: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:25:05.811: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:05.811: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:07.823: As0/324 LCP: I CONFREQ [REQsent] id 2 len 20 *Jul 30 05:25:07.823: As0/324 LCP: ACCM 0x00000000 (0x020600000000) *Jul 30 05:25:07.823: As0/324 LCP: MagicNumber 0x44164A0F (0x050644164A0F) *Jul 30 05:25:07.823: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:07.823: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:07.823: As0/324 LCP: O CONFACK [REQsent] id 2 len 20 *Jul 30 05:25:07.823: As0/324 LCP: ACCM 0x00000000 (0x020600000000) *Jul 30 05:25:07.823: As0/324 LCP: MagicNumber 0x44164A0F (0x050644164A0F) *Jul 30 05:25:07.823: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:07.823: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:07.827: As0/324 LCP: Timeout: State ACKsent *Jul 30 05:25:07.827: As0/324 LCP: O CONFREQ [ACKsent] id 10 len 28 *Jul 30 05:25:07.827: As0/324 LCP: MRU 492 (0x010401EC) *Jul 30 05:25:07.827: As0/324 LCP: ACCM 0x000A0000 (0x0206000A0000) *Jul 30 05:25:07.827: As0/324 LCP: AuthProto PAP (0x0304C023) *Jul 30 05:25:07.827: As0/324 LCP: MagicNumber 0x1B338AFE (0x05061B338AFE) *Jul 30 05:25:07.827: As0/324 LCP: PFC (0x0702) *Jul 30 05:25:07.827: As0/324 LCP: ACFC (0x0802) *Jul 30 05:25:09.843: As0/324 LCP: Timeout: State ACKsent *Jul 30 05:25:09.843: As0/324 LCP: State is Listen *Jul 30 05:25:09.935: %ISDN-6-DISCONNECT: Interface Serial1/0:1 disconnected from 555 , call lasted 40 seconds *Jul 30 05:25:11.843: %LINK-5-CHANGED: Interface Async0/324, changed state to reset *Jul 30 05:25:11.843: As0/324 PPP: Sending Acct Event[Down] id[7] *Jul 30 05:25:11.843: As0/324 LCP: State is Closed *Jul 30 05:25:11.843: As0/324 PPP: Phase is DOWN Конфиг: Using 1671 out of 245752 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname modem_test ! boot-start-marker boot-end-marker ! card type e1 1 logging buffered 8192 enable secret 5 $1$QaH2$06BULzYfwqhNv0w.rnaMR/ ! no aaa new-model network-clock-participate slot 1 network-clock-select 1 E1 1/0 modem country v12 russia ! ! ip cef ! ! no ip domain lookup multilink bundle-name authenticated isdn switch-type primary-qsig ! ! ! username modem password 0 test archive log config hidekeys ! ! controller E1 1/0 framing NO-CRC4 pri-group timeslots 1-2,16 ! ! ! interface Loopback0 ip address 10.0.0.1 255.255.255.0 ! interface Serial1/0:15 no ip address encapsulation ppp isdn switch-type primary-qsig isdn timer T310 120000 isdn protocol-emulate network isdn incoming-voice modem 64 ! interface Group-Async1 mtu 492 ip unnumbered Loopback0 encapsulation ppp load-interval 30 dialer in-band async mode dedicated peer default ip address pool MODEM ppp authentication pap group-range 0/322 0/357 ! ip local pool MODEM 10.0.0.2 10.0.0.254 ! ! ip http server ! dialer-list 1 protocol ip permit ! ! control-plane ! ! line con 0 line aux 0 line 0/322 0/357 session-timeout 30 exec-timeout 15 0 no flush-at-activation login local modem Dialin modem autoconfigure type v12 terminal-type vt102 transport input all autoselect during-login autoselect ppp line vty 0 4 password 123 login ! scheduler allocate 20000 1000 ! end подскажите куда копать, а ?
Нет ответа от модема
Биг Найдж replied to Биг Найдж's topic in Телефония: классическая, IP-телефония (VoIP), NGN сети
если кому интересно - не хватало команды network-clock-select 1 e1 1/0 -
доку курил уже, не помогло -
t38 - это вроде факсы. пас тру - это что ? у меня модем даже не пищит, если чо )) просто трубку поднимает и все. -
Добрый день. Схема следующая: [FXS][cisco 2811]---ISDN PRI---[cisco 2811] при подключении к FXS порту телефона модем на второй 2811 поднимает трубку, но в трубке тишина ((( конфиги: ! controller E1 0/2/0 framing NO-CRC4 pri-group timeslots 1-2,16 ! ! interface Serial0/2/0:15 no ip address encapsulation hdlc isdn switch-type primary-qsig isdn incoming-voice modem no cdp enable ! ! dial-peer voice 1 pots destination-pattern 555 port 0/3/0 ! ! voice-port 0/3/0 cptone RU ! ! dial-peer voice 888 pots destination-pattern .T port 0/2/0:15 ! циска с модемной платой (36 port PVDMII digital modem PVDM daughter card) ! controller E1 1/0 framing NO-CRC4 pri-group timeslots 1-2,16 ! !interface Serial1/0:15 no ip address encapsulation hdlc isdn switch-type primary-qsig isdn timer T310 120000 isdn not-end-to-end 64 isdn protocol-emulate network isdn incoming-voice modem no cdp enable ! line 0/322 0/357 modem InOut debug isdn q931: *Jul 23 06:27:45.367: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x008B Bearer Capability i = 0x9090A3 Standard = CCITT Transfer Capability = 3.1kHz Audio Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA98382 Exclusive, Channel 2 Progress Ind i = 0x8183 - Origination address is non-ISDN Calling Party Number i = 0x0080, '555' Plan:Unknown, Type:Unknown Called Party Number i = 0x80, '123' Plan:Unknown, Type:Unknown *Jul 23 06:27:45.407: %ISDN-6-CONNECT: Interface Serial1/0:1 is now connected to 555 N/A *Jul 23 06:27:45.407: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x808B Channel ID i = 0xA98382 Exclusive, Channel 2 *Jul 23 06:27:45.411: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x808B *Jul 23 06:27:45.411: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x808B *Jul 23 06:27:45.419: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x008B *Jul 23 06:28:55.551: %ISDN-6-DISCONNECT: Interface Serial1/0:1 disconnected from 555 , call lasted 70 seconds *Jul 23 06:28:55.551: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x808B Cause i = 0x8290 - Normal call clearing *Jul 23 06:28:55.559: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x008 *Jul 23 06:28:55.563: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x808B sh modem log: Modem 0/322 V12: Event Log contains 42 Events: 00:05:05.376 Boot: Download FPGA 00:04:55.376 Boot: Bootstrap Ready 00:04:52.404 Boot: NiOS Download Ack 00:04:52.396 NiOS: Modem Count Ack 00:04:47.384 NiOS: V12 FW Download Ack 00:03:47.352 NiOS: Modem Start Ack 00:03:47.352 00:03:47.196 CSM: event-MODEM_DISCONNECTED New State-BAD_STATE 00:03:47.196 Ntf: CHANSTATUS 00:03:46.812 NiOS: Modem Start Ack 00:03:46.808 Ntf: DTEREQ 00:03:46.808 NiOS: Modem Start Ack 00:03:46.772 Ntf: CMDREQ 00:03:46.772 Cmd: CMDDAT Config Change 04 A0D 384D 3330 7878 4120 796E 6F50 7472 00 00:03:46.772 00:03:46.772 00:03:46.768 Ntf: CONFIGACK 00:03:46.768 Ntf: DCERPT 00:03:46.764 Ntf: CMDDAT Config Acknowledge Pass 00:03:46.764 Ntf: CMDREQ 00:04:05.076 Cmd: CMDDAT Config Change ATS 5B 0D DF 17 00:04:05.608 Ntf: CMDDAT Config Acknowledge ATS Pass Pass 00:04:05.680 Ntf: CMDREQ 00:03:39.560 CSM: Incoming call from 555 to 123 00:03:39.560 CSM: event-ISDN_CALL New State-IC_MODEM_RESERVED CSM: status-1 dchan-1/0 bchan-1 00:03:39.632 Cmd: PCMENCODE 00:03:39.668 Cmd: CMDDAT Config Change ATS 5B 0D DF 17 00:03:39.740 CSM: event-ISDN_CONNECTED New State-WAIT_FOR_CARRIER 00:03:39.728 CSM: event-CSM_EVENT_MODEM_SETUP New State-WAIT_FOR_CARRIER 00:03:39.764 Ntf: PCMENCODE 00:03:39.800 Ntf: CMDDAT Config Acknowledge ATS Pass Pass 00:03:39.864 Ntf: CMDREQ 00:03:39.888 Cmd: LINECON 00:03:40.328 Ntf: ANSDET 00:02:30.488 Ntf: HGUPDET 00:02:31.600 CSM: event-MODEM_DISCONNECTED New State-WAIT_FOR_CARRIER 00:02:41.508 Cmd: CMDDAT Statistic--Call Summary Information 00:02:41.952 Ntf: HGUPDN Disconnect Reason 22 00:02:42.112 CSM: event-QUEUED_DISCONNECT New State-IDLE_STATE 00:02:42.300 Ntf: CMDDAT Statistic--Call Summary Information Disconnect reason 22 No connection established Retrain/rate renegotiate reason 0 None Connection time (hours) 0 Connection time (minutes) 0 Connection time (seconds) 0 Initial receive speed 0 0-300 Initial transmit speed 0 0-300 Maximum receive speed 0 0-300 Maximum transmit speed 0 0-300 Minimum receive speed 0 0-300 Minimum transmit speed 0 0-300 Max retransmit for one frame 0 Total retransmit during connect 0 Minimum EQM 255 Maximum EQM 0 Negative EQMs 0 Minimum SNR 0 429496715 dB Maximum SNR 0 429496715 dB Retrains requested locally 0 Retrains requested remotely 0 Rate renegotiation req locally 0 Rate renegotiation req remotely 0 00:02:56.708 Ntf: CMDREQ 00:02:55.872 CSM: event-ASYNC_DTR_DOWN New State-IDLE_STATE что надо подкрутить, чтобы услышать характерный писк ? :-)
о пасиб )) а q.sig - это альтернатива q931 ?
Добрый день! поднимаю ISDN PRI на циске и очень хочу понять, чо же я делаю :-D Есть интерфейс G.703 - тут все понятно. дальше создаю D-канал и там есть - isdn switch-type primary-net5 - это есть EDSS в терминах телефонистов ? А еще есть q931 - он тут вообще как ? Объясните, пожалуйста.
Продам память для cisco 7206VXR (NPE-G1) - 2 модуля по 128М.
