2 shurick31, у меня стоит 2.200eu-r0449. Ссылка есть выше.
Антенна D-Link <ANT24-1201> направленная (YAGI)/12dBi/50° с грозозащитой.
Расстояние примерно 700 м. На другой стороне D-Link <ANT24-1500> всенаправленная антенна 15dBi.
Если интересуют параметры скорости могу вечером поглядеть. (Я на работе до 18 часов).
Только подскажите чем лучше замерять скорость?
Пока могу дать get config
Atheros Access Point Rev 4.0.0.167
D-Link Access Point wlan1 -> get config
wlan1 revisions: mac 5.8 phy 4.4 analog 4.6
PCI Vendor ID: 0x168c, Device ID: 0x13
Sub Vendor ID: 0x168c, Sub Device ID: 0x13
chip is AR2312
Country Code: GB
Operation Mode: Access Point
Wlan State: Enabled
Radio Frequency: 2472 MHz (IEEE 13)
Wireless LAN Mode: 802.11g
Auto Channel Select: Disabled
Extended Channel Mode: Enabled
Data Rate:18
Antenna: 1
Login Username: admin
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: :))
SSID Suppress Mode: Disabled
System Name: D-Link Access Point
Beacon Interval: 100
DTIM: 1
Fragmentation Threshold: 2346
RTS/CTS Threshold: 2346
Short Preamble: Enabled
11g Only Allowed: Enabled
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
11g Overlapping BSS Protection: Disabled
11g Beacon Rate: 1 Mbps
11g Draft 5.0 compatibility: Disabled
Short Slot Time: Enabled
Basic 11g Rate Set: (1, 2, 5.5, 11, 6, 12, 24)
11g Optimization Level: 1
Burst Time: 2
Burst Sequence Threshold: 3
IP Address: 192.168.1.2
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: 0.0.0.0
SNTP/NTP Server IP Address:
Time Zone: 27
HW Transmit Retry Limit: 4
SW Transmit Retry Limit: 3
TransmitPower: full
Current Transmit Output Power 23.0 dBm
SuperG :Disabled
Encryption: Disabled
Cipher selection: WEP
Authentication Type: Open-System
Default transmit key: 1
Shared Key 1, size 40, 0000000000
Access Check: Strict
Key Entry Method: hexadecimal
Group Key Update Interval: 1800 seconds
Key Source: flash
Aging Interval: 300 seconds
Telnet Access: Enabled
Telnet Timeout: 900 seconds
Minimum rate: 1 Mbps
XR Poll interval: 100 msec
XR Frame Limit: 25
XR Poll Rate String is 0.25 1 1 3 3 6 6 20
XR Fragmentation Threshold: 540
