Ах да. Пашет пока что только L2TP. По PPTP сессия затыкается на этапе согласования параметров сессии. аср-ка принимает соединение, но не посылает ответ клиенту
Короче:
ASR1002 не поддерживает параметры радиуса: Framed-Compression = Van-Jacobson-TCP-IP,
ASR1002 не поддерживает команды rate-limit на любых интерфейсах :(
Софт: asr1000rp1-adventerprisek9.02.04.02.122-33.XND2.bin
r1002#test virtual-Template 1 subinterfaceSubinterfaces may be created using Virtual-Template1
Nov 18 06:15:37.924: SSM SM ID LOCK: [L2TP mgmt daemon:id_lock:4150] locker <SIP>: count 0 --> 1Nov 18 06:15:37.925: SSM SM ID LOCK: [L2TUN Application Manager:id_lock:4150] locker <SSS>: count 0 --> 1
Nov 18 06:15:37.925: SSM SM ID LOCK: [sSS Manager:id_lock:4150] locker <SSS>: count 1 --> 2
Nov 18 06:15:37.926: SSM SM ID LOCK: [sSS Manager:id_unlock:4150] locker <SSS>: count 2 --> 1
Nov 18 06:15:38.211: SSM SM ID LOCK: [sSS Manager:id_lock:4150] locker <SSF>: count 0 --> 1
Nov 18 06:15:38.224: SSM SM ID LOCK: [sSS Manager:id_lock:8247] locker <SIP>: count 0 --> 1
Nov 18 06:15:38.227: %FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb= 0x46464D0C, ifnum= 46
Nov 18 06:15:38.227: %FMANRP_ESS-4-SEGFAIL: ESS Bind Lterm Session: bind failed for Seghandle 0x4AF1C254 of Type 21
-Traceback= 1#1f2564750a9d6b27088662088336171d :10000000+630258 :10000000+62E470 :10000000+62E740 :10000000+242D264 :10000000+1F3F04C :10000000+1632C70 :10000000+2CEA58C :10000000+2CEA628 :10000000+16336AC :10000000+1633904 :10000000+162CF30 :10000000+162D27C :10000000+162D650 :10000000+162D9A0 :10000000+1620A64 :10000000+1622910
Nov 18 06:15:38.231: SSM SM ID LOCK: [sSM connection manager:id_unlock:8247] locker <SIP>: count 1 --> 0
Nov 18 06:15:38.231: %SW_MGR-3-CM_ERROR_CLASS: Connection Manager Error: Class ADJ: - bind all.
-Traceback= 1#1f2564750a9d6b27088662088336171d :10000000+630258 :10000000+62E470 :10000000+62E740 :10000000+162D6C8 :10000000+162D9A0 :10000000+1620A64 :10000000+1622910 :10000000+1622E68
Nov 18 06:15:38.237: SSM SM ID LOCK: [sSS Feature Manager:id_unlock:4150] locker <SSF>: count 1 --> 0
Nov 18 06:15:38.237: SSM SM ID LOCK: [sSS Manager:id_unlock:4150] locker <SSS>: count 1 --> 0
Nov 18 06:15:38.238: SSM SM ID LOCK: [L2TP mgmt daemon:id_unlock:4150] locker <SIP>: count 1 --> 0
CAR и на in и на out нормально на ASR работает.
Вот!interface Virtual-Template1
ip unnumbered Port-channel1.105
ip verify unicast reverse-path
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
no logging event link-status
peer default ip address pool mypool
ppp authentication ms-chap-v2 chap eap ms-chap pap
end
Т.е. ничего примечательного. То же самое прелестно работает на Cisco 7201
