Когда настраиваю в режиме PPPoE модем в логах вот что:
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:12> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:13> default route ioctl(SIOCADDRT): Network is unreachable(128)
Sep 8 12:00:13> WAN IP address 10.64.64.64
Sep 8 12:00:13> PPPoE Connect with IP Address 10.64.64.64
Sep 8 12:00:13> WAN gateway 10.112.112.112
Sep 8 12:00:13> PPPoE Connection Successfully Established
Sep 8 12:00:13> PPPoE Connect with Gateway IP Address: 10.112.112.112
Sep 8 12:00:15> DSL Carrier is down
Sep 8 12:00:25> DSL Carrier is training
Sep 8 12:00:35> DSL Carrier is up
Sep 8 12:00:36> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:36> default route ioctl(SIOCADDRT): Network is unreachable(128)
Sep 8 12:00:36> WAN IP address 10.64.64.64
Sep 8 12:00:36> PPPoE Connect with IP Address 10.64.64.64
Sep 8 12:00:36> WAN gateway 10.112.112.112
Sep 8 12:00:36> PPPoE Connection Successfully Established
Sep 8 12:00:36> PPPoE Connect with Gateway IP Address: 10.112.112.112
Но заходишь в раздел Connection status, там написано Disconected. Нажимаешь кнопку Connect, соединения не происходит, а в логах добавляется следующее:
Sep 8 12:01:29> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:29> default route ioctl(SIOCADDRT): Network is unreachable(128)
Sep 8 12:01:29> WAN IP address 10.64.64.64
Sep 8 12:01:29> PPPoE Connect with IP Address 10.64.64.64
Sep 8 12:01:29> WAN gateway 10.112.112.112
Sep 8 12:01:29> PPPoE Connection Successfully Established
Sep 8 12:01:29> PPPoE Connect with Gateway IP Address: 10.112.112.112
