Anatoliy75
Новичок-
Публикации
4 -
Зарегистрирован
Посещение
О Anatoliy75
Звание
Абитуриент
Посетители профиля
SNR-CPE-ME2 не корректно работает DDNS
тему ответил в Anatoliy75 пользователя Anatoliy75 в Wi-Fi маршрутизаторы SNR-CPE
Вот суточный лог: Jan 14 21:44:02 dnsmasq[1151]: using nameserver 89.236.192.1#53 Jan 14 21:44:02 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jan 14 21:44:03 2nd_stage: Switch to 2nd boot stage and start webui. Jan 14 21:44:03 reconfig: Reload modules. Jan 14 21:44:03 modules: link wifi down first Jan 14 21:44:03 modules: Shutdown all wireless interfaces. Jan 14 21:44:03 kernel: ESW: Link Status Changed - Port0 Link Up Jan 14 21:44:04 modules: Unload wireless modules. Jan 14 21:44:04 modules: Load conntrack helpers modules. Jan 14 21:44:04 modules: Load application depended modules. Jan 14 21:44:04 modules: Prepare wifi config. Jan 14 21:44:04 modules: Load wireless modules. Jan 14 21:44:04 modules: Load wifi AP module. Jan 14 21:44:05 kernel: PCI: Enabling device 0000:01:00.0 (0000 -> 0002) Jan 14 21:44:05 modules: WiFi ra0 interface up with txqueuelen 50. Jan 14 21:44:06 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 21:44:06 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jan 14 21:44:06 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jan 14 21:44:06 kernel: efuse_probe: efuse = 10000212 Jan 14 21:44:08 kernel: ESW: Link Status Changed - Port3 Link Up Jan 14 21:44:14 modules: WiFi rai0 interface up with txqueuelen 50. Jan 14 21:44:15 reconfig: Reconfigure lan. Jan 14 21:44:15 lan: Stop LAN network interfaces. Jan 14 21:44:15 lan: Start LAN network interfaces. Jan 14 21:44:15 lan: Add bridge in the system Jan 14 21:44:15 lan: br0_MACADDR F8:F0:82:29:F6:3F Jan 14 21:44:15 lan: Up bridge interface Jan 14 21:44:15 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 14 21:44:15 kernel: raeth: HW VLAN TX offload enabled Jan 14 21:44:15 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 14 21:44:15 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jan 14 21:44:15 reconfig: Gateway OperationMode: 1 Jan 14 21:44:15 reconfig: Readd eth2 in br0 Jan 14 21:44:15 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 14 21:44:15 kernel: raeth: HW VLAN TX offload enabled Jan 14 21:44:15 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 14 21:44:15 kernel: device eth2 entered promiscuous mode Jan 14 21:44:15 kernel: br0: port 1(eth2) entered forwarding state Jan 14 21:44:15 reconfig: Readd ra0 in br0 Jan 14 21:44:15 kernel: device ra0 entered promiscuous mode Jan 14 21:44:15 kernel: br0: port 2(ra0) entered forwarding state Jan 14 21:44:15 reconfig: Readd rai0 in br0 Jan 14 21:44:16 kernel: device rai0 entered promiscuous mode Jan 14 21:44:16 kernel: br0: port 3(rai0) entered forwarding state Jan 14 21:44:16 wan: Start WAN config Jan 14 21:44:16 wan: Allow forward for eth3 Jan 14 21:44:16 wan: Call zeroconf for get wan ip address. Jan 14 21:44:16 zcip: init eth3 Jan 14 21:44:16 ESW: Restore internal MT7621 switch mode to dumb mode Jan 14 21:44:16 ESW: Reset WAN port phy Jan 14 21:44:16 zcip: start, interface eth3 Jan 14 21:44:16 kernel: ESW: WAN Link Status Changed - Port4 Link Down Jan 14 21:44:16 ESW: Reset LAN ports phys Jan 14 21:44:16 kernel: ESW: Link Status Changed - Port3 Link Down Jan 14 21:44:16 kernel: ESW: Link Status Changed - Port2 Link Down Jan 14 21:44:16 kernel: ESW: Link Status Changed - Port0 Link Down Jan 14 21:44:17 ESW: Config internal MT7621 switch mode WLLLL Jan 14 21:44:17 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jan 14 21:44:17 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 32: : : : :73 Jan 14 21:44:17 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 21:44:17 advanced: Tune wifi advanced parametrs for ra0. Jan 14 21:44:17 advanced: Tune wifi advanced parametrs for rai0. Jan 14 21:44:17 services: Restart needed services and scripts. Mode all Jan 14 21:44:18 iptables: Add netfiler rules Jan 14 21:44:18 iptables: Allow established/related in input Jan 14 21:44:18 iptables: Drop invalid state connections Jan 14 21:44:18 iptables: Service limit set Jan 14 21:44:18 iptables: Set igmp input rules Jan 14 21:44:18 iptables: DHCP server allow Jan 14 21:44:18 iptables: Dnsproxy allow to connect Jan 14 21:44:18 iptables: Remote managment web limit Jan 14 21:44:18 iptables: Remote managment ssh limit Jan 14 21:44:18 iptables: Remote managment telnet limit Jan 14 21:44:18 iptables: Allow rate limited ping from all interfaces. Jan 14 21:44:18 iptables: Set forward rules Jan 14 21:44:18 iptables: Set igmp forward rules Jan 14 21:44:18 iptables: Allow forward from LAN to any Jan 14 21:44:18 iptables: Redirect all DNS requests to local DNS proxy. Jan 14 21:44:18 iptables: Call to add VPN netfilter rules. Jan 14 21:44:18 iptables: DMZ enabled for 192.168.1.150 Jan 14 21:44:18 iptables: Allow established/related in forward Jan 14 21:44:18 ipv6: Deconfigure ipv6 interfaces/route. Jan 14 21:44:18 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jan 14 21:44:18 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 21:44:19 dnsserver: Generate /etc/hosts file. Jan 14 21:44:19 dnsserver: Send HUP to dnsmasq. Jan 14 21:44:19 dnsmasq[1151]: read /etc/hosts - 4 addresses Jan 14 21:44:19 dnsmasq[1151]: using nameserver 77.88.8.7#53 Jan 14 21:44:19 dnsmasq[1151]: using nameserver 77.88.8.3#53 Jan 14 21:44:19 dyndns: Starting DynDNS Jan 14 21:44:19 INADYN[3207]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 14 21:44:19 INADYN[3207]: INADYN:IP: Error '0x80' resolving host name 'ip1.dynupdate.no-ip.com' Jan 14 21:44:19 ntp: Stopping NTPD Jan 14 21:44:19 kernel: ASSOC - Assign AID=2 to 2.4GHz AP 9c: : : : :37 Jan 14 21:44:19 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 21:44:19 kernel: ESW: Link Status Changed - Port0 Link Up Jan 14 21:44:19 ntp: Starting NTPD Jan 14 21:44:20 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 21:44:20 igmpproxy: Wait 15 sec before start. Jan 14 21:44:20 kext: Nat mode Linux Hybrid Jan 14 21:44:20 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths. Jan 14 21:44:20 kext: NAT fastpath enabled. Jan 14 21:44:20 kext: Route fastpath enabled. Jan 14 21:44:20 kext: Netfilter fastpath enabled. Jan 14 21:44:20 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1 Jan 14 21:44:20 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384 Jan 14 21:44:20 kext: hw_nat: set binding threshold to 50. Jan 14 21:44:20 kext: Enable multicast to unicast conversion for ra0 rai0 Jan 14 21:44:20 kernel: ESW: Link Status Changed - Port3 Link Up Jan 14 21:44:21 lld2d: Starting LLD2D Jan 14 21:44:21 inetd: Stopping inetd Jan 14 21:44:22 inetd: Starting inetd Jan 14 21:44:22 transmission: Not any disk connected. Jan 14 21:44:22 dhcpd: Configure dhcpserver Jan 14 21:44:22 dhcpd: Start dhcpserver Jan 14 21:44:22 udhcpd[3876]: started, v1.30.1 Jan 14 21:44:23 vpnhelper: Start vpnhelper Jan 14 21:44:23 vpnhelper: PPPOE calling. Jan 14 21:44:24 irqbalance: Start irqbalance routing/wifi optimize mode Jan 14 21:44:24 irqbalance: Start irqbalance auto mode Jan 14 21:44:24 2nd_stage: Copy web pages to tmpfs. Jan 14 21:44:24 2nd_stage: Start WEB Managment Server. Jan 14 21:44:24 2nd_stage: USB Port power ON. Jan 14 21:44:24 hotplug: Rescan connected devices Jan 14 21:44:25 usbctrl(4351): TYPE=9/0/1 INTERFACE=9/0/0 Jan 14 21:44:25 vpnhelper-pppoe: ==================START-PPPOE-CLIENT======================= Jan 14 21:44:25 vpnhelper-pppoe: PPPOE connect over eth3 to Jan 14 21:44:25 pppd[4401]: Plugin /lib/rp-pppoe.so loaded. Jan 14 21:44:25 pppd[4401]: RP-PPPoE plugin version 3.12 compiled against pppd 2.4.7 Jan 14 21:44:25 pppd[4401]: pppd 2.4.7 started by daemon, uid 0 Jan 14 21:44:25 pppd[4401]: PPP session is 51773 (0xca3d) Jan 14 21:44:25 pppd[4401]: Connected to 70: : : : :d0 via interface eth3 Jan 14 21:44:25 pppd[4401]: Using interface ppp0 Jan 14 21:44:25 pppd[4401]: Connect: ppp0 <--> eth3 Jan 14 21:44:25 pppd[4401]: PAP authentication succeeded Jan 14 21:44:25 pppd[4401]: peer from calling number 70: : : : :D0 authorized Jan 14 21:44:25 pppd[4401]: local IP address 194.55.95.182 Jan 14 21:44:25 pppd[4401]: remote IP address 80.80.220.254 Jan 14 21:44:25 pppd[4401]: primary DNS address 80.80.208.1 Jan 14 21:44:25 pppd[4401]: secondary DNS address 89.236.192.1 Jan 14 21:44:25 pppd: No dgw stored. Jan 14 21:44:25 pppd: Replace default route to ppp0 Jan 14 21:44:25 pppd: Replace DNS from pppd Jan 14 21:44:25 pppd: Flush route cache Jan 14 21:44:25 pppd: Flush conntrack table Jan 14 21:44:25 pppd: Restart dns server, dyndns, ntp sync and rebuild shaper and iptables rules Jan 14 21:44:25 services: Restart needed services and scripts. Mode pppd Jan 14 21:44:26 QoS: Stopping SHAPER Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 usbctrl(4355): TYPE=9/0/3 INTERFACE=9/0/0 Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 QoS: Set default rules. Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 Codel: QoS Add codel for all interfaces. Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 iptables: Add netfiler rules Jan 14 21:44:26 iptables: Allow established/related in input Jan 14 21:44:26 iptables: Drop invalid state connections Jan 14 21:44:26 iptables: Service limit set Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 iptables: Set igmp input rules Jan 14 21:44:26 iptables: DHCP server allow Jan 14 21:44:26 iptables: Dnsproxy allow to connect Jan 14 21:44:26 iptables: Remote managment web limit Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 iptables: Remote managment ssh limit Jan 14 21:44:26 iptables: Remote managment telnet limit Jan 14 21:44:26 iptables: Allow rate limited ping from all interfaces. Jan 14 21:44:26 iptables: Set forward rules Jan 14 21:44:26 iptables: Set igmp forward rules Jan 14 21:44:26 iptables: Allow forward from LAN to any Jan 14 21:44:26 iptables: Redirect all DNS requests to local DNS proxy. Jan 14 21:44:26 udhcpd[3876]: sending OFFER of 192.168.1.36 Jan 14 21:44:26 iptables: Call to add VPN netfilter rules. Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 iptables: DMZ enabled for 192.168.1.150 Jan 14 21:44:26 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:26 iptables: Allow established/related in forward Jan 14 21:44:27 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:27 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 21:44:27 resolv: Add ISP DNS from vpn servers for local resolv Jan 14 21:44:27 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:27 dnsserver: Generate /etc/hosts file. Jan 14 21:44:27 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:27 dnsserver: Send HUP to dnsmasq. Jan 14 21:44:27 dnsmasq[1151]: read /etc/hosts - 6 addresses Jan 14 21:44:27 dnsmasq[1151]: using nameserver 77.88.8.7#53 Jan 14 21:44:27 dnsmasq[1151]: using nameserver 77.88.8.3#53 Jan 14 21:44:27 dnsmasq[1151]: using nameserver 80.80.208.1#53 Jan 14 21:44:27 dnsmasq[1151]: using nameserver 89.236.192.1#53 Jan 14 21:44:27 dyndns: Stopping DynDns Jan 14 21:44:27 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:28 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:28 dyndns: Starting DynDNS Jan 14 21:44:28 INADYN[4989]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 14 21:44:28 ntp: Stopping NTPD Jan 14 21:44:28 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:28 zcip: config eth3 169.254.223.175 Jan 14 21:44:28 zcip: Add ip adress 169.254.223.175/32 to interface eth3 and interface up. Jan 14 21:44:28 zcip: Add route to multicast subnet. Jan 14 21:44:28 ntp: Starting NTPD Jan 14 21:44:28 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:28 udhcpd[3876]: sending OFFER of 192.168.1.227 Jan 14 21:44:28 udhcpd[3876]: sending ACK to 192.168.1.36 Jan 14 21:44:29 udhcpd[3876]: sending OFFER of 192.168.1.227 Jan 14 21:44:29 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:29 udhcpd[3876]: sending ACK to 192.168.1.227 Jan 14 21:44:29 irqbalance: Stopping irqbalance Jan 14 21:44:30 kernel: br0: port 1(eth2) entered forwarding state Jan 14 21:44:30 kernel: br0: port 2(ra0) entered forwarding state Jan 14 21:44:31 irqbalance: Start irqbalance routing/wifi optimize mode Jan 14 21:44:31 kernel: br0: port 3(rai0) entered forwarding state Jan 14 21:44:31 irqbalance: Start irqbalance auto mode Jan 14 21:44:31 pppd: Enable forwarding for ppp0 interface Jan 14 21:44:31 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:44:32 kernel: ASSOC - Assign AID=3 to 5GHz AP 20: : : : :d1 Jan 14 21:44:32 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 21:44:32 kernel: ASSOC - VHT support STA Jan 14 21:44:34 udhcpd[3876]: sending OFFER of 192.168.1.69 Jan 14 21:44:34 udhcpd[3876]: sending ACK to 192.168.1.69 Jan 14 21:44:35 igmpproxy: Replace route to multicast subnet via eth3. Jan 14 21:44:35 igmpproxy: Starting IGMPPROXY Jan 14 21:44:37 fwupdate[5476]: GW is ppp0, skip ICMP check Jan 14 21:44:37 fwupdate[5476]: You are using the latest firmware version. Jan 14 21:44:40 fwupdate[5481]: GW is ppp0, skip ICMP check Jan 14 21:44:40 fwupdate[5481]: You are using the latest firmware version. Jan 14 21:44:41 fwupdate[5481]: New firmware avialable: 1.8.3 (20201230) [Current firmware: 1.8.2 (20201217)] Jan 14 21:44:44 get_ieee_oui: Get OUI lists from Jan 14 21:45:56 pppd[4401]: System time change detected. Jan 14 21:46:00 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:47:26 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-2608) request from 32: : : : :73, reason=8 Jan 14 21:47:48 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 32: : : : :73 Jan 14 21:47:48 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 21:47:48 udhcpd[3876]: sending ACK to 192.168.1.227 Jan 14 21:47:52 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:47:54 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:47:56 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:48:19 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:48:39 dnsmasq[1151]: Insecure DS reply received, do upstream DNS servers support DNSSEC? Jan 14 21:48:45 nginx-wive[4403]: doSystem: (rm -f /etc/dnsmasq.d/ads.conf) > /dev/console 2>&1 (0) Jan 14 21:48:45 dnsserver: Stopping DNSMASQ Jan 14 21:48:45 dnsmasq[1151]: exiting on receipt of SIGTERM Jan 14 21:48:45 dnsserver: Generate /etc/hosts file. Jan 14 21:48:46 dnsserver: Starting DNSMASQ Jan 14 21:48:46 nginx-wive[4403]: doSystem: (service dnsserver restart) > /dev/console 2>&1 (0) Jan 14 21:48:46 dnsmasq[5562]: started, version 2.80 cachesize 1024 Jan 14 21:48:46 dnsmasq[5562]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN no-DHCP no-scripts no-TFTP no-conntrack no-ipset no-auth DNSSEC no-loop-detect inotify no-dumpfile Jan 14 21:48:46 dnsmasq[5562]: read /etc/hosts - 6 addresses Jan 14 21:48:46 dnsmasq[5562]: using nameserver 77.88.8.7#53 Jan 14 21:48:46 dnsmasq[5562]: using nameserver 77.88.8.3#53 Jan 14 21:48:46 dnsmasq[5562]: using nameserver 80.80.208.1#53 Jan 14 21:48:46 dnsmasq[5562]: using nameserver 89.236.192.1#53 Jan 14 21:48:46 nginx-wive[4403]: doSystem: (services_restart.sh misc &) > /dev/console 2>&1 (0) Jan 14 21:48:46 services: Restart needed services and scripts. Mode misc Jan 14 21:48:46 QoS: Stopping SHAPER Jan 14 21:48:47 QoS: Set default rules. Jan 14 21:48:47 Codel: QoS Add codel for all interfaces. Jan 14 21:48:47 iptables: Add netfiler rules Jan 14 21:48:47 iptables: Allow established/related in input Jan 14 21:48:47 iptables: Drop invalid state connections Jan 14 21:48:47 iptables: Service limit set Jan 14 21:48:47 iptables: Set igmp input rules Jan 14 21:48:47 iptables: DHCP server allow Jan 14 21:48:47 iptables: Dnsproxy allow to connect Jan 14 21:48:47 iptables: Remote managment web limit Jan 14 21:48:47 iptables: Remote managment ssh limit Jan 14 21:48:47 iptables: Remote managment telnet limit Jan 14 21:48:47 iptables: Allow rate limited ping from all interfaces. Jan 14 21:48:47 iptables: Set forward rules Jan 14 21:48:47 iptables: Set igmp forward rules Jan 14 21:48:47 iptables: Allow forward from LAN to any Jan 14 21:48:47 iptables: Redirect all DNS requests to local DNS proxy. Jan 14 21:48:47 iptables: Call to add VPN netfilter rules. Jan 14 21:48:47 iptables: DMZ enabled for 192.168.1.150 Jan 14 21:48:47 iptables: Allow established/related in forward Jan 14 21:48:48 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 21:48:48 resolv: Add ISP DNS from vpn servers for local resolv Jan 14 21:48:48 dnsserver: Generate /etc/hosts file. Jan 14 21:48:48 dnsserver: Send HUP to dnsmasq. Jan 14 21:48:48 dnsmasq[5562]: read /etc/hosts - 6 addresses Jan 14 21:48:48 dnsmasq[5562]: using nameserver 77.88.8.7#53 Jan 14 21:48:48 dnsmasq[5562]: using nameserver 77.88.8.3#53 Jan 14 21:48:48 dnsmasq[5562]: using nameserver 80.80.208.1#53 Jan 14 21:48:48 dnsmasq[5562]: using nameserver 89.236.192.1#53 Jan 14 21:48:48 dyndns: Stopping DynDns Jan 14 21:48:49 dyndns: Starting DynDNS Jan 14 21:48:49 INADYN[6094]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 14 21:48:49 ntp: Stopping NTPD Jan 14 21:48:49 ntp: Starting NTPD Jan 14 21:48:50 igmpproxy: Stopping IGMPPROXY Jan 14 21:48:50 igmpproxy: Wait 15 sec before start. Jan 14 21:48:50 kext: Nat mode Linux Hybrid Jan 14 21:48:50 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths. Jan 14 21:48:50 kext: NAT fastpath enabled. Jan 14 21:48:50 kext: Route fastpath enabled. Jan 14 21:48:50 kext: Netfilter fastpath enabled. Jan 14 21:48:50 kernel: Ralink HW NAT v2.52.0 Module Disabled Jan 14 21:48:50 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1 Jan 14 21:48:51 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384 Jan 14 21:48:51 kext: hw_nat: set binding threshold to 50. Jan 14 21:48:51 kext: Enable multicast to unicast conversion for ra0 rai0 Jan 14 21:48:51 lld2d: Stopping LLD2D Jan 14 21:48:52 lld2d: Starting LLD2D Jan 14 21:48:52 inetd: Stopping inetd Jan 14 21:48:52 inetd: Starting inetd Jan 14 21:48:52 transmission: Not any disk connected. Jan 14 21:48:52 dhcpd: Stop dhcpserver Jan 14 21:48:54 dhcpd: Configure dhcpserver Jan 14 21:48:54 dhcpd: Start dhcpserver Jan 14 21:48:54 udhcpd[6729]: started, v1.30.1 Jan 14 21:48:55 irqbalance: Stopping irqbalance Jan 14 21:48:55 irqbalance: Start irqbalance routing/wifi optimize mode Jan 14 21:48:55 irqbalance: Start irqbalance auto mode Jan 14 21:49:05 igmpproxy: Replace route to multicast subnet via eth3. Jan 14 21:49:05 igmpproxy: Starting IGMPPROXY Jan 14 22:02:03 kernel: ASSOC - Assign AID=4 to 2.4GHz AP 94: : : : :41 Jan 14 22:02:03 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 22:02:03 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-498) request from 94: : : : :41, reason=8 Jan 14 22:02:06 kernel: ASSOC - Assign AID=4 to 2.4GHz AP 94: : : : :41 Jan 14 22:02:06 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 22:02:08 udhcpd[6729]: sending OFFER of 192.168.1.138 Jan 14 22:02:08 udhcpd[6729]: sending ACK to 192.168.1.138 Jan 14 22:57:09 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-3069) request from 32: : : : :73, reason=8 Jan 14 23:06:36 kernel: ESW: Link Status Changed - Port2 Link Down Jan 14 23:14:19 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 7c: : : : :56 Jan 14 23:14:19 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 23:14:19 udhcpd[6729]: sending OFFER of 192.168.1.218 Jan 14 23:14:21 udhcpd[6729]: sending ACK to 192.168.1.218 Jan 14 23:17:24 kernel: ASSOC - Assign AID=2 to 2.4GHz AP 32: : : : :73 Jan 14 23:17:24 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 23:17:24 udhcpd[6729]: sending ACK to 192.168.1.227 Jan 14 23:19:43 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 20: : : : :d1 Jan 14 23:19:43 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 23:19:44 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 14 23:19:44 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 14 23:23:12 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 23:23:14 kernel: ESW: Link Status Changed - Port2 Link Down Jan 14 23:23:17 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 23:23:39 kernel: ESW: Link Status Changed - Port2 Link Down Jan 14 23:23:42 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 23:25:35 kernel: ASSOC - Assign AID=3 to 5GHz AP 20: : : : :d1 Jan 14 23:25:35 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 23:25:35 kernel: ASSOC - VHT support STA Jan 14 23:25:36 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 14 23:25:36 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 14 23:41:34 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 04:25:51 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-2161) request from 7c: : : : :56, reason=8 Jan 15 04:37:20 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-802) request from 32: : : : :73, reason=8 Jan 15 07:32:21 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 20: : : : :d1 Jan 15 07:32:21 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 07:32:21 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 07:32:21 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 07:40:54 kernel: 2.4GHz AP ageout 20: : : : :d1 after 480-sec silence Jan 15 07:47:52 kernel: ASSOC - Assign AID=1 to 5GHz AP 20: : : : :d1 Jan 15 07:47:52 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 07:47:52 kernel: ASSOC - VHT support STA Jan 15 07:47:52 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 07:47:52 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 08:35:37 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-3151) request from 94: : : : :41, reason=8 Jan 15 08:35:40 kernel: ASSOC - Assign AID=2 to 5GHz AP 94: : : : :41 Jan 15 08:35:40 kernel: ASSOC - HT support STA. Update AP OperaionMode=0 , fAnyStationIsLegacy=0, fAnyStation20Only=0, fAnyStationNonGF=1 Jan 15 08:35:40 kernel: ASSOC - VHT support STA Jan 15 08:35:41 udhcpd[6729]: sending OFFER of 192.168.1.138 Jan 15 08:35:41 udhcpd[6729]: sending ACK to 192.168.1.138 Jan 15 08:53:43 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 20: : : : :d1 Jan 15 08:53:43 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 08:53:43 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 08:53:43 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 09:05:55 kernel: 5GHz AP ageout 94:76:b7:ec:49:41 after 480-sec silence Jan 15 09:22:55 kernel: ASSOC - Assign AID=2 to 2.4GHz AP 32: : : : :73 Jan 15 09:22:55 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 09:22:56 udhcpd[6729]: sending ACK to 192.168.1.227 Jan 15 09:49:57 kernel: ASSOC - Assign AID=1 to 5GHz AP 20: : : : :d1 Jan 15 09:49:57 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 09:49:57 kernel: ASSOC - VHT support STA Jan 15 09:49:58 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 09:49:58 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 09:51:22 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 20: : : : :d1 Jan 15 09:51:22 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 09:51:22 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 09:51:22 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 10:25:59 kernel: ASSOC - Assign AID=1 to 5GHz AP 20: : : : :d1 Jan 15 10:25:59 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 10:25:59 kernel: ASSOC - VHT support STA Jan 15 10:26:00 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 10:26:00 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 10:57:02 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 20: : : : :d1 Jan 15 10:57:02 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 10:57:02 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 10:57:02 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 11:27:24 kernel: 2.4GHz AP ageout 32: : : : :73 after 480-sec silence Jan 15 11:51:00 kernel: 2.4GHz AP ageout 20: : : : :d1 after 480-sec silence Jan 15 12:11:09 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 20: : : : :d1 Jan 15 12:11:09 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 12:11:09 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 12:11:09 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 12:16:06 kernel: ASSOC - Assign AID=2 to 2.4GHz AP 9c: : : : :37 Jan 15 12:16:06 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 12:16:07 udhcpd[6729]: sending OFFER of 192.168.1.36 Jan 15 12:16:07 udhcpd[6729]: sending ACK to 192.168.1.36 Jan 15 12:52:50 kernel: ASSOC - Assign AID=1 to 5GHz AP 20: : : : :d1 Jan 15 12:52:50 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 12:52:50 kernel: ASSOC - VHT support STA Jan 15 12:52:50 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 12:52:50 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 12:54:33 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 20: : : : :d1 Jan 15 12:54:33 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 12:54:34 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 12:54:34 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 13:20:27 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 32: : : : :73 Jan 15 13:20:27 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 13:20:27 udhcpd[6729]: sending ACK to 192.168.1.227 Jan 15 13:23:25 kernel: ASSOC - Assign AID=4 to 2.4GHz AP d0: : : : :5c Jan 15 13:23:25 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 13:23:27 udhcpd[6729]: sending OFFER of 192.168.1.52 Jan 15 13:23:28 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-812) request from d0: : : : :5c, reason=8 Jan 15 13:30:25 kernel: ASSOC - Assign AID=4 to 2.4GHz AP d0: : : : :5c Jan 15 13:30:25 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 13:30:25 udhcpd[6729]: sending OFFER of 192.168.1.52 Jan 15 13:30:26 udhcpd[6729]: sending ACK to 192.168.1.52 Jan 15 13:30:27 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-939) request from d0: : : : :5c, reason=8 Jan 15 13:31:13 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-1342) request from 32: : : : :73, reason=8 Jan 15 13:31:16 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 32: : : : :73 Jan 15 13:31:16 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 13:31:18 udhcpd[6729]: sending ACK to 192.168.1.227 Jan 15 13:45:22 kernel: ASSOC - Assign AID=4 to 2.4GHz AP d0: : : : :5c Jan 15 13:45:22 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 13:45:24 udhcpd[6729]: sending OFFER of 192.168.1.52 Jan 15 13:45:25 udhcpd[6729]: sending ACK to 192.168.1.52 Jan 15 13:45:25 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-1068) request from d0: : : : :5c, reason=8 Jan 15 14:17:30 kernel: ASSOC - Assign AID=4 to 2.4GHz AP d0: : : : :5c Jan 15 14:17:30 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 14:17:32 udhcpd[6729]: sending OFFER of 192.168.1.52 Jan 15 14:17:33 udhcpd[6729]: sending ACK to 192.168.1.52 Jan 15 14:17:46 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-1439) request from d0: : : : :5c, reason=8 Jan 15 15:52:59 kernel: 2.4GHz AP ageout 32: : : : :73 after 480-sec silence Jan 15 16:00:20 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 32: : : : :73 Jan 15 16:00:20 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 16:00:21 udhcpd[6729]: sending ACK to 192.168.1.227 Jan 15 16:00:47 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-3161) request from 32: : : : :73, reason=8 Jan 15 17:44:49 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 94: : : : :41 Jan 15 17:44:49 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 17:44:50 udhcpd[6729]: sending OFFER of 192.168.1.138 Jan 15 17:44:50 udhcpd[6729]: sending ACK to 192.168.1.138 Jan 15 17:47:51 kernel: ASSOC - Assign AID=4 to 2.4GHz AP 32: : : : :73 Jan 15 17:47:51 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 17:47:52 udhcpd[6729]: sending ACK to 192.168.1.227 Jan 15 17:56:38 kernel: ASSOC - Assign AID=5 to 2.4GHz AP 7c: : : : :56 Jan 15 17:56:38 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 17:56:38 udhcpd[6729]: sending OFFER of 192.168.1.218 Jan 15 17:56:42 udhcpd[6729]: sending ACK to 192.168.1.218 Jan 15 18:13:37 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-903) request from 7c: : : : :56, reason=8 Jan 15 18:19:33 kernel: 2.4GHz AP ASSOC - receive DIS-ASSOC(seq-2506) request from 32: : : : :73, reason=8 Jan 15 18:50:11 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 18:50:13 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 18:50:16 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 18:50:38 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 18:50:41 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 19:00:45 kernel: ASSOC - Assign AID=1 to 5GHz AP 20: : : : :d1 Jan 15 19:00:45 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 19:00:45 kernel: ASSOC - VHT support STA Jan 15 19:00:46 udhcpd[6729]: sending OFFER of 192.168.1.69 Jan 15 19:00:46 udhcpd[6729]: sending ACK to 192.168.1.69 Jan 15 20:04:10 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 20:35:22 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 20:35:23 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 20:35:26 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 20:35:49 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 20:35:51 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 20:38:00 fwupdate[7067]: GW is ppp0, skip ICMP check Jan 15 20:38:00 fwupdate[7067]: You are using the latest firmware version. Вот спустя 20 минут после сегодняшней перезагрузки: Jan 1 05:00:04 syslogd started: BusyBox v1.30.1 Jan 1 05:00:04 kernel: Determined physical RAM map: Jan 1 05:00:04 kernel: memory: 10000000 @ 00000000 (usable) Jan 1 05:00:04 kernel: Detected 3 available secondary CPU(s) Jan 1 05:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Jan 1 05:00:04 kernel: Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes Jan 1 05:00:04 kernel: MIPS secondary cache 256kB, 8-way, linesize 32 bytes. Jan 1 05:00:04 kernel: Zone PFN ranges: Jan 1 05:00:04 kernel: DMA 0x00000000 -> 0x00001000 Jan 1 05:00:04 kernel: Normal 0x00001000 -> 0x00010000 Jan 1 05:00:04 kernel: Movable zone start PFN for each node Jan 1 05:00:04 kernel: Early memory PFN ranges Jan 1 05:00:04 kernel: 0: 0x00000000 -> 0x00010000 Jan 1 05:00:04 kernel: On node 0 totalpages: 65536 Jan 1 05:00:04 kernel: free_area_init_node: node 0, pgdat 813d17a0, node_mem_map 81427000 Jan 1 05:00:04 kernel: DMA zone: 32 pages used for memmap Jan 1 05:00:04 kernel: DMA zone: 0 pages reserved Jan 1 05:00:04 kernel: DMA zone: 4064 pages, LIFO batch:0 Jan 1 05:00:04 kernel: Normal zone: 480 pages used for memmap Jan 1 05:00:04 kernel: Normal zone: 60960 pages, LIFO batch:15 Jan 1 05:00:04 kernel: PERCPU: Embedded 7 pages/cpu @8162a000 s4544 r8192 d15936 u32768 Jan 1 05:00:04 kernel: pcpu-alloc: s4544 r8192 d15936 u32768 alloc=8*4096 Jan 1 05:00:04 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 Jan 1 05:00:04 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024 Jan 1 05:00:04 kernel: Kernel command line: console=ttyS0,57600n8 root=/dev/mtdblock4 rootfstype=squashfs Jan 1 05:00:04 kernel: PID hash table entries: 1024 (order: 0, 4096 bytes) Jan 1 05:00:04 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Jan 1 05:00:04 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Jan 1 05:00:04 kernel: Writing ErrCtl register=00018004 Jan 1 05:00:04 kernel: Readback ErrCtl register=00018004 Jan 1 05:00:04 kernel: Memory: 255488k/262144k available (3212k kernel code, 6656k reserved, 696k data, 244k init, 0k highmem) Jan 1 05:00:04 kernel: start_kernel(): bug: interrupts were enabled *very* early, fixing it Jan 1 05:00:04 kernel: Hierarchical RCU implementation. Jan 1 05:00:04 kernel: NR_IRQS:72 Jan 1 05:00:04 kernel: MIPS GIC RevID: 3.0 Jan 1 05:00:04 kernel: Setting up vectored interrupts Jan 1 05:00:04 kernel: console [ttyS0] enabled Jan 1 05:00:04 kernel: Calibrating delay loop... 577.53 BogoMIPS (lpj=288768) Jan 1 05:00:04 kernel: pid_max: default: 32768 minimum: 301 Jan 1 05:00:04 kernel: Mount-cache hash table entries: 512 Jan 1 05:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Jan 1 05:00:04 kernel: Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes Jan 1 05:00:04 kernel: MIPS secondary cache 256kB, 8-way, linesize 32 bytes. Jan 1 05:00:04 kernel: CPU revision is: 0001992f (MIPS 1004Kc) Jan 1 05:00:04 kernel: Synchronize counters for CPU 1: done. Jan 1 05:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Jan 1 05:00:04 kernel: Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes Jan 1 05:00:04 kernel: MIPS secondary cache 256kB, 8-way, linesize 32 bytes. Jan 1 05:00:04 kernel: CPU revision is: 0001992f (MIPS 1004Kc) Jan 1 05:00:04 kernel: Synchronize counters for CPU 2: done. Jan 1 05:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Jan 1 05:00:04 kernel: Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes Jan 1 05:00:04 kernel: MIPS secondary cache 256kB, 8-way, linesize 32 bytes. Jan 1 05:00:04 kernel: CPU revision is: 0001992f (MIPS 1004Kc) Jan 1 05:00:04 kernel: Synchronize counters for CPU 3: done. Jan 1 05:00:04 kernel: Brought up 4 CPUs Jan 1 05:00:04 kernel: NET: Registered protocol family 16 Jan 1 05:00:04 kernel: FPU Affinity set after 1186 emulations Jan 1 05:00:04 kernel: bio: create slab <bio-0> at 0 Jan 1 05:00:04 kernel: SCSI subsystem initialized Jan 1 05:00:04 kernel: USB led has gpio 13 Jan 1 05:00:04 kernel: usbcore: registered new interface driver usbfs Jan 1 05:00:04 kernel: usbcore: registered new interface driver hub Jan 1 05:00:04 kernel: usbcore: registered new device driver usb Jan 1 05:00:04 kernel: PCI host bridge to bus 0000:00 Jan 1 05:00:04 kernel: pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff] Jan 1 05:00:04 kernel: pci_bus 0000:00: root bus resource [io 0x1e160000-0x1e16ffff] Jan 1 05:00:04 kernel: pci 0000:00:00.0: [0e8d:0801] type 01 class 0x060400 Jan 1 05:00:04 kernel: pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x7fffffff] Jan 1 05:00:04 kernel: pci 0000:00:00.0: supports D1 Jan 1 05:00:04 kernel: pci 0000:00:00.0: PME# supported from D0 D1 D3hot Jan 1 05:00:04 kernel: pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280 Jan 1 05:00:04 kernel: pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit] Jan 1 05:00:04 kernel: pci 0000:00:00.0: BAR 0: can't assign mem (size 0x80000000) Jan 1 05:00:04 kernel: pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff] Jan 1 05:00:04 kernel: pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x600fffff 64bit] Jan 1 05:00:04 kernel: pci 0000:00:00.0: PCI bridge to [bus 01-01] Jan 1 05:00:04 kernel: pci 0000:00:00.0: bridge window [mem 0x60000000-0x600fffff] Jan 1 05:00:04 kernel: Switching to clocksource GIC Jan 1 05:00:04 kernel: FS-Cache: Loaded Jan 1 05:00:04 kernel: CacheFiles: Loaded Jan 1 05:00:04 kernel: NET: Registered protocol family 1 Jan 1 05:00:04 kernel: NET: Registered protocol family 2 Jan 1 05:00:04 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes) Jan 1 05:00:04 kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes) Jan 1 05:00:04 kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes) Jan 1 05:00:04 kernel: TCP: Hash tables configured (established 8192 bind 8192) Jan 1 05:00:04 kernel: TCP: reno registered Jan 1 05:00:04 kernel: UDP hash table entries: 128 (order: 0, 4096 bytes) Jan 1 05:00:04 kernel: PCI: CLS 32 bytes, default 32 Jan 1 05:00:04 kernel: 4 CPUs re-calibrate udelay (lpj = 289792) Jan 1 05:00:04 kernel: Load Ralink WDG Timer Module Jan 1 05:00:04 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher Jan 1 05:00:04 kernel: msgmni has been set to 499 Jan 1 05:00:04 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) Jan 1 05:00:04 kernel: io scheduler noop registered (default) Jan 1 05:00:04 kernel: Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled Jan 1 05:00:04 kernel: serial8250: ttyS0 at MMIO 0x1e000c00 (irq = 34) is a 16550A Jan 1 05:00:04 kernel: USB power down at bootup use inverted gpio 17 Jan 1 05:00:04 kernel: Ralink gpio driver initialized Jan 1 05:00:04 kernel: loop: module loaded Jan 1 05:00:04 kernel: MediaTek SPI flash driver, SPI clock: 44MHz Jan 1 05:00:04 kernel: SPI flash chip: GD25Q128CSIG (c8 4018c840) (16384 Kbytes) Jan 1 05:00:04 kernel: Creating 7 MTD partitions on "raspi": Jan 1 05:00:04 sysctl: Tune kernel with sysctl. Jan 1 05:00:04 kernel: 0x000000000000-0x000000030000 : "Bootloader" Jan 1 05:00:04 kernel: 0x000000030000-0x000000040000 : "Config" Jan 1 05:00:04 kernel: 0x000000040000-0x000000050000 : "Factory" Jan 1 05:00:04 kernel: 0x000000050000-0x0000001ad3ab : "Kernel_stub" Jan 1 05:00:04 kernel: 0x0000001ad3ab-0x000000f00000 : "RootFS_stub" Jan 1 05:00:04 kernel: 0x000000f00000-0x000001000000 : "RW-FS" Jan 1 05:00:04 kernel: 0x000000050000-0x000000f00000 : "Kernel_RootFS" Jan 1 05:00:04 kernel: Ralink APSoC Ethernet Driver v3.2.4 (raeth) Jan 1 05:00:04 kernel: raeth: PDMA RX ring 512, QDMA TX pool 1024. Max packet size 1536 Jan 1 05:00:04 kernel: raeth: NAPI & GRO support, weight 128 Jan 1 05:00:04 kernel: raeth: Byte Queue Limits (BQL) support Jan 1 05:00:04 kernel: PPP generic driver version 2.4.2 Jan 1 05:00:04 kernel: PPP vpn led has gpio 16 Jan 1 05:00:04 kernel: PPP MPPE Compression module registered Jan 1 05:00:04 kernel: NET: Registered protocol family 24 Jan 1 05:00:04 kernel: PPTP driver version 0.8.5 Jan 1 05:00:04 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Jan 1 05:00:04 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver Jan 1 05:00:04 kernel: U2PHY P0 set SRCTRL calibration value: 2 Jan 1 05:00:04 kernel: U2PHY P1 set SRCTRL calibration value: 2 Jan 1 05:00:04 kernel: xhci-hcd xhci-hcd: xHCI Host Controller Jan 1 05:00:04 kernel: xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 1 Jan 1 05:00:04 kernel: xhci-hcd xhci-hcd: irq 30, io mem 0x1e1c0000 Jan 1 05:00:04 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 Jan 1 05:00:04 kernel: usb usb1: Product: xHCI Host Controller Jan 1 05:00:04 kernel: usb usb1: Manufacturer: Linux 3.4.113.185 xhci-hcd Jan 1 05:00:04 kernel: usb usb1: SerialNumber: xhci-hcd Jan 1 05:00:04 kernel: xHCI xhci_add_endpoint called for root hub Jan 1 05:00:04 kernel: xHCI xhci_check_bandwidth called for root hub Jan 1 05:00:04 kernel: hub 1-0:1.0: USB hub found Jan 1 05:00:04 kernel: hub 1-0:1.0: 2 ports detected Jan 1 05:00:04 kernel: xhci-hcd xhci-hcd: xHCI Host Controller Jan 1 05:00:04 kernel: xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 2 Jan 1 05:00:04 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 Jan 1 05:00:04 kernel: usb usb2: Product: xHCI Host Controller Jan 1 05:00:04 kernel: usb usb2: Manufacturer: Linux 3.4.113.185 xhci-hcd Jan 1 05:00:04 kernel: usb usb2: SerialNumber: xhci-hcd Jan 1 05:00:04 kernel: xHCI xhci_add_endpoint called for root hub Jan 1 05:00:04 kernel: xHCI xhci_check_bandwidth called for root hub Jan 1 05:00:04 kernel: hub 2-0:1.0: USB hub found Jan 1 05:00:04 kernel: hub 2-0:1.0: 1 port detected Jan 1 05:00:04 kernel: usbcore: registered new interface driver libusual Jan 1 05:00:04 kernel: 8021q: 802.1Q VLAN Support v1.8 Jan 1 05:00:04 kernel: NET: Registered protocol family 17 Jan 1 05:00:04 kernel: Netfilter messages via NETLINK v0.30. Jan 1 05:00:04 kernel: nf_conntrack version 0.5.0 (16384 buckets, 32768 max) Jan 1 05:00:04 kernel: gre: GRE over IPv4 demultiplexor driver Jan 1 05:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team Jan 1 05:00:04 kernel: TCP: cubic registered Jan 1 05:00:04 kernel: NET: Registered protocol family 10 Jan 1 05:00:04 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team Jan 1 05:00:04 kernel: L2TP core driver, V2.0 Jan 1 05:00:04 kernel: PPPoL2TP kernel driver, V2.0 Jan 1 05:00:04 kernel: L2TP netlink interface Jan 1 05:00:04 kernel: Registering the dns_resolver key type Jan 1 05:00:04 kernel: NVRAM: Kernel NVRAM start init. Jan 1 05:00:04 kernel: NVRAM: Particion 0 CRC 7b3745b0 OK. Jan 1 05:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:4. Jan 1 05:00:04 kernel: mount /proc file system ok! Jan 1 05:00:04 kernel: mount /proc/bus/usb file system ok! Jan 1 05:00:04 kernel: mount /sys file system ok! Jan 1 05:00:04 kernel: mount /dev file system ok! Jan 1 05:00:04 kernel: mount /var file system ok! Jan 1 05:00:04 kernel: Freeing unused kernel memory: 244k freed Jan 1 05:00:04 kernel: Build the /dev/console node. Jan 1 05:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5 Jan 1 05:00:04 pass: Set current password Jan 1 05:00:04 syslog: password for 'admin' changed Jan 15 20:40:00 ntp: Starting NTPD Jan 15 20:40:00 hotplug: Generate config file. Jan 15 20:40:00 hotplug: Set mdev as kernel hotplug helper and enable device autoprobe. Jan 15 20:40:00 hotplug: Refresh dev nodes. Jan 15 20:40:00 hotplug: Rescan connected devices Jan 15 20:40:00 usbctrl(610): TYPE=9/0/1 INTERFACE=9/0/0 Jan 15 20:40:00 lo: Start loopback interface. Jan 15 20:40:00 lan: Start LAN network interfaces. Jan 15 20:40:00 ESW: Double vlan tag disabled. Jan 15 20:40:00 ESW: eth2 MACADDR F8: : : : :3F txqueuelen 160 Jan 15 20:40:00 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 15 20:40:00 kernel: raeth: HW VLAN TX offload enabled Jan 15 20:40:00 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 15 20:40:00 ESW: eth3 MACADDR F8: : : : :14 txqueuelen 160 Jan 15 20:40:00 ESW: Restore internal MT7621 switch mode to dumb mode Jan 15 20:40:00 ESW: Reset WAN port phy Jan 15 20:40:00 ESW: Reset LAN ports phys Jan 15 20:40:01 usbctrl(613): TYPE=9/0/3 INTERFACE=9/0/0 Jan 15 20:40:01 ESW: Config internal MT7621 switch mode WLLLL Jan 15 20:40:01 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jan 15 20:40:01 lan: Add bridge in the system Jan 15 20:40:01 lan: br0_MACADDR F8: : : : :3F Jan 15 20:40:01 lan: Up bridge interface Jan 15 20:40:01 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jan 15 20:40:01 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 15 20:40:01 resolv: Add ISP DNS from vpn servers for local resolv Jan 15 20:40:01 dnsserver: Generate /etc/hosts file. Jan 15 20:40:01 dnsserver: Starting DNSMASQ Jan 15 20:40:02 inetd: Starting inetd Jan 15 20:40:02 dnsmasq[1154]: started, version 2.80 cachesize 1024 Jan 15 20:40:02 dnsmasq[1154]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN no-DHCP no-scripts no-TFTP no-conntrack no-ipset no-auth DNSSEC no-loop-detect inotify no-dumpfile Jan 15 20:40:02 dnsmasq[1154]: read /etc/hosts - 4 addresses Jan 15 20:40:02 dnsmasq[1154]: using nameserver 77.88.8.7#53 Jan 15 20:40:02 dnsmasq[1154]: using nameserver 77.88.8.3#53 Jan 15 20:40:02 dnsmasq[1154]: using nameserver 80.80.208.1#53 Jan 15 20:40:02 dnsmasq[1154]: using nameserver 89.236.192.1#53 Jan 15 20:40:03 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jan 15 20:40:03 2nd_stage: Switch to 2nd boot stage and start webui. Jan 15 20:40:03 reconfig: Reload modules. Jan 15 20:40:03 modules: link wifi down first Jan 15 20:40:03 modules: Shutdown all wireless interfaces. Jan 15 20:40:04 modules: Unload wireless modules. Jan 15 20:40:04 modules: Load conntrack helpers modules. Jan 15 20:40:04 kernel: ESW: Link Status Changed - Port3 Link Up Jan 15 20:40:04 modules: Load application depended modules. Jan 15 20:40:04 modules: Prepare wifi config. Jan 15 20:40:05 modules: Load wireless modules. Jan 15 20:40:05 modules: Load wifi AP module. Jan 15 20:40:05 kernel: ESW: Link Status Changed - Port0 Link Up Jan 15 20:40:05 kernel: PCI: Enabling device 0000:01:00.0 (0000 -> 0002) Jan 15 20:40:05 modules: WiFi ra0 interface up with txqueuelen 50. Jan 15 20:40:05 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 20:40:06 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jan 15 20:40:06 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jan 15 20:40:06 kernel: efuse_probe: efuse = 10000212 Jan 15 20:40:14 modules: WiFi rai0 interface up with txqueuelen 50. Jan 15 20:40:16 reconfig: Reconfigure lan. Jan 15 20:40:16 lan: Stop LAN network interfaces. Jan 15 20:40:16 lan: Start LAN network interfaces. Jan 15 20:40:16 lan: Add bridge in the system Jan 15 20:40:16 lan: br0_MACADDR F8: : : :F 6:3F Jan 15 20:40:16 lan: Up bridge interface Jan 15 20:40:16 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 15 20:40:16 kernel: raeth: HW VLAN TX offload enabled Jan 15 20:40:16 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 15 20:40:16 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jan 15 20:40:17 reconfig: Gateway OperationMode: 1 Jan 15 20:40:17 reconfig: Readd eth2 in br0 Jan 15 20:40:17 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 15 20:40:17 kernel: raeth: HW VLAN TX offload enabled Jan 15 20:40:17 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 15 20:40:17 kernel: device eth2 entered promiscuous mode Jan 15 20:40:17 kernel: br0: port 1(eth2) entered forwarding state Jan 15 20:40:17 reconfig: Readd ra0 in br0 Jan 15 20:40:17 kernel: device ra0 entered promiscuous mode Jan 15 20:40:17 kernel: br0: port 2(ra0) entered forwarding state Jan 15 20:40:17 reconfig: Readd rai0 in br0 Jan 15 20:40:17 kernel: device rai0 entered promiscuous mode Jan 15 20:40:17 kernel: br0: port 3(rai0) entered forwarding state Jan 15 20:40:17 wan: Start WAN config Jan 15 20:40:17 wan: Allow forward for eth3 Jan 15 20:40:17 wan: Call zeroconf for get wan ip address. Jan 15 20:40:17 zcip: init eth3 Jan 15 20:40:17 ESW: Restore internal MT7621 switch mode to dumb mode Jan 15 20:40:17 zcip: start, interface eth3 Jan 15 20:40:17 ESW: Reset WAN port phy Jan 15 20:40:17 kernel: ESW: WAN Link Status Changed - Port4 Link Down Jan 15 20:40:18 ESW: Reset LAN ports phys Jan 15 20:40:18 kernel: ESW: Link Status Changed - Port3 Link Down Jan 15 20:40:18 kernel: ESW: Link Status Changed - Port2 Link Down Jan 15 20:40:18 kernel: ESW: Link Status Changed - Port0 Link Down Jan 15 20:40:18 ESW: Config internal MT7621 switch mode WLLLL Jan 15 20:40:18 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jan 15 20:40:18 advanced: Tune wifi advanced parametrs for ra0. Jan 15 20:40:18 advanced: Tune wifi advanced parametrs for rai0. Jan 15 20:40:19 services: Restart needed services and scripts. Mode all Jan 15 20:40:19 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 9c: : : : :37 Jan 15 20:40:19 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 20:40:19 iptables: Add netfiler rules Jan 15 20:40:19 iptables: Allow established/related in input Jan 15 20:40:19 iptables: Drop invalid state connections Jan 15 20:40:19 iptables: Service limit set Jan 15 20:40:19 iptables: Set igmp input rules Jan 15 20:40:19 iptables: DHCP server allow Jan 15 20:40:19 iptables: Dnsproxy allow to connect Jan 15 20:40:19 iptables: Remote managment web limit Jan 15 20:40:19 iptables: Remote managment ssh limit Jan 15 20:40:19 iptables: Remote managment telnet limit Jan 15 20:40:19 iptables: Allow rate limited ping from all interfaces. Jan 15 20:40:19 iptables: Set forward rules Jan 15 20:40:19 iptables: Set igmp forward rules Jan 15 20:40:19 iptables: Allow forward from LAN to any Jan 15 20:40:19 iptables: Redirect all DNS requests to local DNS proxy. Jan 15 20:40:19 iptables: Call to add VPN netfilter rules. Jan 15 20:40:19 iptables: DMZ enabled for 192.168.1.150 Jan 15 20:40:19 iptables: Allow established/related in forward Jan 15 20:40:19 ipv6: Deconfigure ipv6 interfaces/route. Jan 15 20:40:20 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jan 15 20:40:20 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 15 20:40:20 dnsserver: Generate /etc/hosts file. Jan 15 20:40:20 dnsserver: Send HUP to dnsmasq. Jan 15 20:40:20 dnsmasq[1154]: read /etc/hosts - 4 addresses Jan 15 20:40:20 dnsmasq[1154]: using nameserver 77.88.8.7#53 Jan 15 20:40:20 dnsmasq[1154]: using nameserver 77.88.8.3#53 Jan 15 20:40:20 dyndns: Starting DynDNS Jan 15 20:40:20 INADYN[3219]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 15 20:40:20 INADYN[3219]: INADYN:IP: Error '0x80' resolving host name 'ip1.dynupdate.no-ip.com' Jan 15 20:40:20 ntp: Stopping NTPD Jan 15 20:40:21 kernel: ESW: Link Status Changed - Port0 Link Up Jan 15 20:40:21 ntp: Starting NTPD Jan 15 20:40:21 kernel: ESW: Link Status Changed - Port2 Link Up Jan 15 20:40:21 igmpproxy: Wait 15 sec before start. Jan 15 20:40:21 kernel: ESW: Link Status Changed - Port3 Link Up Jan 15 20:40:22 kext: Nat mode Linux Hybrid Jan 15 20:40:22 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths. Jan 15 20:40:22 kext: NAT fastpath enabled. Jan 15 20:40:22 kext: Route fastpath enabled. Jan 15 20:40:22 kext: Netfilter fastpath enabled. Jan 15 20:40:22 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1 Jan 15 20:40:22 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384 Jan 15 20:40:22 kext: hw_nat: set binding threshold to 50. Jan 15 20:40:22 kext: Enable multicast to unicast conversion for ra0 rai0 Jan 15 20:40:22 lld2d: Starting LLD2D Jan 15 20:40:22 inetd: Stopping inetd Jan 15 20:40:23 kernel: ASSOC - Assign AID=2 to 5GHz AP 20: : : : :d1 Jan 15 20:40:23 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 20:40:23 kernel: ASSOC - VHT support STA Jan 15 20:40:23 inetd: Starting inetd Jan 15 20:40:24 transmission: Not any disk connected. Jan 15 20:40:24 dhcpd: Configure dhcpserver Jan 15 20:40:24 dhcpd: Start dhcpserver Jan 15 20:40:24 udhcpd[3888]: started, v1.30.1 Jan 15 20:40:24 vpnhelper: Start vpnhelper Jan 15 20:40:24 vpnhelper: PPPOE calling. Jan 15 20:40:25 irqbalance: Start irqbalance routing/wifi optimize mode Jan 15 20:40:25 irqbalance: Start irqbalance auto mode Jan 15 20:40:25 2nd_stage: Copy web pages to tmpfs. Jan 15 20:40:26 2nd_stage: Start WEB Managment Server. Jan 15 20:40:26 2nd_stage: USB Port power ON. Jan 15 20:40:26 hotplug: Rescan connected devices Jan 15 20:40:26 usbctrl(4362): TYPE=9/0/1 INTERFACE=9/0/0 Jan 15 20:40:26 udhcpd[3888]: sending OFFER of 192.168.1.36 Jan 15 20:40:26 udhcpd[3888]: sending ACK to 192.168.1.36 Jan 15 20:40:26 vpnhelper-pppoe: ==================START-PPPOE-CLIENT======================= Jan 15 20:40:26 vpnhelper-pppoe: PPPOE connect over eth3 to Jan 15 20:40:27 pppd[4415]: Plugin /lib/rp-pppoe.so loaded. Jan 15 20:40:27 pppd[4415]: RP-PPPoE plugin version 3.12 compiled against pppd 2.4.7 Jan 15 20:40:27 pppd[4415]: pppd 2.4.7 started by daemon, uid 0 Jan 15 20:40:27 pppd[4415]: PPP session is 46681 (0xb659) Jan 15 20:40:27 pppd[4415]: Connected to 70: : : : :d0 via interface eth3 Jan 15 20:40:27 pppd[4415]: Using interface ppp0 Jan 15 20:40:27 pppd[4415]: Connect: ppp0 <--> eth3 Jan 15 20:40:27 pppd[4415]: PAP authentication succeeded Jan 15 20:40:27 pppd[4415]: peer from calling number 70: : : : :D0 authorized Jan 15 20:40:27 pppd[4415]: local IP address 194.55.95.182 Jan 15 20:40:27 pppd[4415]: remote IP address 80.80.220.254 Jan 15 20:40:27 pppd[4415]: primary DNS address 80.80.208.1 Jan 15 20:40:27 pppd[4415]: secondary DNS address 89.236.192.1 Jan 15 20:40:27 pppd: No dgw stored. Jan 15 20:40:27 pppd: Replace default route to ppp0 Jan 15 20:40:27 pppd: Replace DNS from pppd Jan 15 20:40:27 pppd: Flush route cache Jan 15 20:40:27 pppd: Flush conntrack table Jan 15 20:40:27 pppd: Restart dns server, dyndns, ntp sync and rebuild shaper and iptables rules Jan 15 20:40:27 services: Restart needed services and scripts. Mode pppd Jan 15 20:40:27 QoS: Stopping SHAPER Jan 15 20:40:27 usbctrl(4366): TYPE=9/0/3 INTERFACE=9/0/0 Jan 15 20:40:27 QoS: Set default rules. Jan 15 20:40:27 Codel: QoS Add codel for all interfaces. Jan 15 20:40:28 iptables: Add netfiler rules Jan 15 20:40:28 iptables: Allow established/related in input Jan 15 20:40:28 iptables: Drop invalid state connections Jan 15 20:40:28 iptables: Service limit set Jan 15 20:40:28 iptables: Set igmp input rules Jan 15 20:40:28 iptables: DHCP server allow Jan 15 20:40:28 iptables: Dnsproxy allow to connect Jan 15 20:40:28 iptables: Remote managment web limit Jan 15 20:40:28 iptables: Remote managment ssh limit Jan 15 20:40:28 iptables: Remote managment telnet limit Jan 15 20:40:28 iptables: Allow rate limited ping from all interfaces. Jan 15 20:40:28 iptables: Set forward rules Jan 15 20:40:28 iptables: Set igmp forward rules Jan 15 20:40:28 iptables: Allow forward from LAN to any Jan 15 20:40:28 iptables: Redirect all DNS requests to local DNS proxy. Jan 15 20:40:28 iptables: Call to add VPN netfilter rules. Jan 15 20:40:28 iptables: DMZ enabled for 192.168.1.150 Jan 15 20:40:28 iptables: Allow established/related in forward Jan 15 20:40:28 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 15 20:40:28 resolv: Add ISP DNS from vpn servers for local resolv Jan 15 20:40:28 dnsserver: Generate /etc/hosts file. Jan 15 20:40:28 dnsserver: Send HUP to dnsmasq. Jan 15 20:40:28 dnsmasq[1154]: read /etc/hosts - 6 addresses Jan 15 20:40:28 dnsmasq[1154]: using nameserver 77.88.8.7#53 Jan 15 20:40:28 dnsmasq[1154]: using nameserver 77.88.8.3#53 Jan 15 20:40:28 dnsmasq[1154]: using nameserver 80.80.208.1#53 Jan 15 20:40:28 dnsmasq[1154]: using nameserver 89.236.192.1#53 Jan 15 20:40:29 dyndns: Stopping DynDns Jan 15 20:40:29 dyndns: Starting DynDNS Jan 15 20:40:29 INADYN[5001]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 15 20:40:29 ntp: Stopping NTPD Jan 15 20:40:29 zcip: config eth3 169.254.223.175 Jan 15 20:40:29 zcip: Add ip adress 169.254.223.175/32 to interface eth3 and interface up. Jan 15 20:40:29 zcip: Add route to multicast subnet. Jan 15 20:40:30 ntp: Starting NTPD Jan 15 20:40:31 udhcpd[3888]: sending OFFER of 192.168.1.69 Jan 15 20:40:31 udhcpd[3888]: sending ACK to 192.168.1.69 Jan 15 20:40:31 irqbalance: Stopping irqbalance Jan 15 20:41:30 kernel: br0: port 1(eth2) entered forwarding state Jan 15 20:41:30 kernel: br0: port 2(ra0) entered forwarding state Jan 15 20:41:30 kernel: br0: port 3(rai0) entered forwarding state Jan 15 20:41:30 irqbalance: Start irqbalance routing/wifi optimize mode Jan 15 20:41:31 irqbalance: Start irqbalance auto mode Jan 15 20:41:31 pppd: Enable forwarding for ppp0 interface Jan 15 20:41:31 pppd[4415]: System time change detected. Jan 15 20:41:35 igmpproxy: Replace route to multicast subnet via eth3. Jan 15 20:41:35 igmpproxy: Starting IGMPPROXY Jan 15 20:41:44 get_ieee_oui: Get OUI lists from Jan 15 20:41:57 fwupdate[5497]: GW is ppp0, skip ICMP check Jan 15 20:41:57 fwupdate[5497]: You are using the latest firmware version. Jan 15 20:42:01 fwupdate[5503]: GW is ppp0, skip ICMP check Jan 15 20:42:01 fwupdate[5503]: You are using the latest firmware version. Jan 15 20:42:02 fwupdate[5503]: New firmware avialable: 1.8.3 (20201230) [Current firmware: 1.8.2 (20201217)] Jan 15 20:43:02 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 94: : : : :41 Jan 15 20:43:02 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 15 20:43:05 udhcpd[3888]: sending OFFER of 192.168.1.138 Jan 15 20:43:05 udhcpd[3888]: sending ACK to 192.168.1.138 И вот скрин с noip только что сделан, последняя дата обновсления стоит вчерашняя -
ОК вечером сниму как раз в логе будут сутки. А, так no-ip не видит адрес ни через 10минут ни через сутки, работу сервиса запускаю только в режиме ручного ввода ip в свойствах хоста на no-ip -
Перезагрузил несколько раз и почему то ip роутера не меняется. Пошёл другим путём в сервисе ddns прописал другой ip: 194.55.95.150. Реальный ip на роутере: 194.55.95.182. После перезагрузки no-ip всё так же имеет 194.55.95.150. Вот лог, имеется ошибка в разрешении ddns: Jan 14 20:44:00 ntp: Starting NTPD Jan 14 20:44:00 hotplug: Generate config file. Jan 14 20:44:00 hotplug: Set mdev as kernel hotplug helper and enable device autoprobe. Jan 14 20:44:00 hotplug: Refresh dev nodes. Jan 14 20:44:00 hotplug: Rescan connected devices Jan 14 20:44:00 usbctrl(610): TYPE=9/0/1 INTERFACE=9/0/0 Jan 14 20:44:00 lo: Start loopback interface. Jan 14 20:44:00 lan: Start LAN network interfaces. Jan 14 20:44:00 ESW: Double vlan tag disabled. Jan 14 20:44:00 ESW: eth2 MACADDR F8: :82: : : txqueuelen 160 Jan 14 20:44:00 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 14 20:44:00 kernel: raeth: HW VLAN TX offload enabled Jan 14 20:44:00 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 14 20:44:00 ESW: eth3 MACADDR F8: :82: : : txqueuelen 160 Jan 14 20:44:00 ESW: Restore internal MT7621 switch mode to dumb mode Jan 14 20:44:00 ESW: Reset WAN port phy Jan 14 20:44:00 ESW: Reset LAN ports phys Jan 14 20:44:01 usbctrl(616): TYPE=9/0/3 INTERFACE=9/0/0 Jan 14 20:44:01 ESW: Config internal MT7621 switch mode WLLLL Jan 14 20:44:01 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jan 14 20:44:01 lan: Add bridge in the system Jan 14 20:44:01 lan: br0_MACADDR F8: :82: : : Jan 14 20:44:01 lan: Up bridge interface Jan 14 20:44:01 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jan 14 20:44:01 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 20:44:01 resolv: Add ISP DNS from vpn servers for local resolv Jan 14 20:44:01 dnsserver: Generate /etc/hosts file. Jan 14 20:44:01 dnsserver: Starting DNSMASQ Jan 14 20:44:01 inetd: Starting inetd Jan 14 20:44:02 dnsmasq[1154]: started, version 2.80 cachesize 1024 Jan 14 20:44:02 dnsmasq[1154]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN no-DHCP no-scripts no-TFTP no-conntrack no-ipset no-auth DNSSEC no-loop-detect inotify no-dumpfile Jan 14 20:44:02 dnsmasq[1154]: read /etc/hosts - 4 addresses Jan 14 20:44:02 dnsmasq[1154]: using nameserver 77.88.8.7#53 Jan 14 20:44:02 dnsmasq[1154]: using nameserver 77.88.8.3#53 Jan 14 20:44:02 dnsmasq[1154]: using nameserver 80.80.208.1#53 Jan 14 20:44:02 dnsmasq[1154]: using nameserver 89.236.192.1#53 Jan 14 20:44:02 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jan 14 20:44:03 2nd_stage: Switch to 2nd boot stage and start webui. Jan 14 20:44:03 reconfig: Reload modules. Jan 14 20:44:03 modules: link wifi down first Jan 14 20:44:03 modules: Shutdown all wireless interfaces. Jan 14 20:44:03 kernel: ESW: Link Status Changed - Port0 Link Up Jan 14 20:44:04 modules: Unload wireless modules. Jan 14 20:44:04 modules: Load conntrack helpers modules. Jan 14 20:44:04 kernel: ESW: Link Status Changed - Port3 Link Up Jan 14 20:44:04 modules: Load application depended modules. Jan 14 20:44:04 modules: Prepare wifi config. Jan 14 20:44:04 modules: Load wireless modules. Jan 14 20:44:04 modules: Load wifi AP module. Jan 14 20:44:05 kernel: PCI: Enabling device 0000:01:00.0 (0000 -> 0002) Jan 14 20:44:05 modules: WiFi ra0 interface up with txqueuelen 50. Jan 14 20:44:05 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 20:44:06 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jan 14 20:44:06 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jan 14 20:44:06 kernel: efuse_probe: efuse = 10000212 Jan 14 20:44:14 modules: WiFi rai0 interface up with txqueuelen 50. Jan 14 20:44:15 reconfig: Reconfigure lan. Jan 14 20:44:15 lan: Stop LAN network interfaces. Jan 14 20:44:15 lan: Start LAN network interfaces. Jan 14 20:44:15 lan: Add bridge in the system Jan 14 20:44:15 lan: br0_MACADDR F8:F0: : : : Jan 14 20:44:15 lan: Up bridge interface Jan 14 20:44:15 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 14 20:44:15 kernel: raeth: HW VLAN TX offload enabled Jan 14 20:44:15 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 14 20:44:15 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jan 14 20:44:15 reconfig: Gateway OperationMode: 1 Jan 14 20:44:15 reconfig: Readd eth2 in br0 Jan 14 20:44:15 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jan 14 20:44:15 kernel: raeth: HW VLAN TX offload enabled Jan 14 20:44:15 kernel: raeth: HW Scatter/Gather TX offload enabled Jan 14 20:44:15 kernel: device eth2 entered promiscuous mode Jan 14 20:44:15 kernel: br0: port 1(eth2) entered forwarding state Jan 14 20:44:15 reconfig: Readd ra0 in br0 Jan 14 20:44:15 kernel: device ra0 entered promiscuous mode Jan 14 20:44:15 kernel: br0: port 2(ra0) entered forwarding state Jan 14 20:44:15 reconfig: Readd rai0 in br0 Jan 14 20:44:16 kernel: device rai0 entered promiscuous mode Jan 14 20:44:16 kernel: br0: port 3(rai0) entered forwarding state Jan 14 20:44:16 wan: Start WAN config Jan 14 20:44:16 wan: Allow forward for eth3 Jan 14 20:44:16 wan: Call zeroconf for get wan ip address. Jan 14 20:44:16 zcip: init eth3 Jan 14 20:44:16 ESW: Restore internal MT7621 switch mode to dumb mode Jan 14 20:44:16 ESW: Reset WAN port phy Jan 14 20:44:16 zcip: start, interface eth3 Jan 14 20:44:16 kernel: ESW: WAN Link Status Changed - Port4 Link Down Jan 14 20:44:16 ESW: Reset LAN ports phys Jan 14 20:44:16 kernel: ESW: Link Status Changed - Port3 Link Down Jan 14 20:44:16 kernel: ESW: Link Status Changed - Port2 Link Down Jan 14 20:44:16 kernel: ESW: Link Status Changed - Port0 Link Down Jan 14 20:44:17 ESW: Config internal MT7621 switch mode WLLLL Jan 14 20:44:17 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jan 14 20:44:17 advanced: Tune wifi advanced parametrs for ra0. Jan 14 20:44:17 advanced: Tune wifi advanced parametrs for rai0. Jan 14 20:44:17 services: Restart needed services and scripts. Mode all Jan 14 20:44:18 iptables: Add netfiler rules Jan 14 20:44:18 iptables: Allow established/related in input Jan 14 20:44:18 iptables: Drop invalid state connections Jan 14 20:44:18 iptables: Service limit set Jan 14 20:44:18 iptables: Set igmp input rules Jan 14 20:44:18 iptables: DHCP server allow Jan 14 20:44:18 iptables: Dnsproxy allow to connect Jan 14 20:44:18 iptables: Remote managment web limit Jan 14 20:44:18 iptables: Remote managment ssh limit Jan 14 20:44:18 iptables: Remote managment telnet limit Jan 14 20:44:18 iptables: Allow rate limited ping from all interfaces. Jan 14 20:44:18 iptables: Set forward rules Jan 14 20:44:18 iptables: Set igmp forward rules Jan 14 20:44:18 iptables: Allow forward from LAN to any Jan 14 20:44:18 iptables: Redirect all DNS requests to local DNS proxy. Jan 14 20:44:18 iptables: Call to add VPN netfilter rules. Jan 14 20:44:18 iptables: DMZ enabled for 192.168.1.150 Jan 14 20:44:18 iptables: Allow established/related in forward Jan 14 20:44:18 ipv6: Deconfigure ipv6 interfaces/route. Jan 14 20:44:18 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 20:44:19 dnsserver: Generate /etc/hosts file. Jan 14 20:44:19 dnsserver: Send HUP to dnsmasq. Jan 14 20:44:19 dnsmasq[1154]: read /etc/hosts - 4 addresses Jan 14 20:44:19 dnsmasq[1154]: using nameserver 77.88.8.7#53 Jan 14 20:44:19 dnsmasq[1154]: using nameserver 77.88.8.3#53 Jan 14 20:44:19 dyndns: Starting DynDNS Jan 14 20:44:19 INADYN[3214]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 14 20:44:19 INADYN[3214]: INADYN:IP: Error '0x80' resolving host name 'ip1.dynupdate.no-ip.com' Jan 14 20:44:19 ntp: Stopping NTPD Jan 14 20:44:19 kernel: ESW: Link Status Changed - Port0 Link Up Jan 14 20:44:19 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 94:76: : : : Jan 14 20:44:19 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 20:44:19 ntp: Starting NTPD Jan 14 20:44:20 kernel: ESW: Link Status Changed - Port2 Link Up Jan 14 20:44:20 igmpproxy: Wait 15 sec before start. Jan 14 20:44:20 kernel: ESW: Link Status Changed - Port3 Link Up Jan 14 20:44:20 kext: Nat mode Linux Hybrid Jan 14 20:44:20 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths. Jan 14 20:44:20 kext: NAT fastpath enabled. Jan 14 20:44:20 kext: Route fastpath enabled. Jan 14 20:44:20 kext: Netfilter fastpath enabled. Jan 14 20:44:20 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1 Jan 14 20:44:20 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384 Jan 14 20:44:20 kext: hw_nat: set binding threshold to 50. Jan 14 20:44:20 kext: Enable multicast to unicast conversion for ra0 rai0 Jan 14 20:44:21 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jan 14 20:44:21 lld2d: Starting LLD2D Jan 14 20:44:21 inetd: Stopping inetd Jan 14 20:44:21 kernel: ASSOC - Assign AID=2 to 5GHz AP :f4:78: : :d1 Jan 14 20:44:21 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 20:44:21 kernel: ASSOC - VHT support STA Jan 14 20:44:22 inetd: Starting inetd Jan 14 20:44:22 transmission: Not any disk connected. Jan 14 20:44:22 dhcpd: Configure dhcpserver Jan 14 20:44:22 dhcpd: Start dhcpserver Jan 14 20:44:22 udhcpd[3883]: started, v1.30.1 Jan 14 20:44:23 vpnhelper: Start vpnhelper Jan 14 20:44:23 vpnhelper: PPPOE calling. Jan 14 20:44:23 irqbalance: Start irqbalance routing/wifi optimize mode Jan 14 20:44:24 irqbalance: Start irqbalance auto mode Jan 14 20:44:24 2nd_stage: Copy web pages to tmpfs. Jan 14 20:44:24 2nd_stage: Start WEB Managment Server. Jan 14 20:44:24 2nd_stage: USB Port power ON. Jan 14 20:44:24 hotplug: Rescan connected devices Jan 14 20:44:25 usbctrl(4357): TYPE=9/0/1 INTERFACE=9/0/0 Jan 14 20:44:25 vpnhelper-pppoe: ==================START-PPPOE-CLIENT======================= Jan 14 20:44:25 vpnhelper-pppoe: PPPOE connect over eth3 to Jan 14 20:44:25 pppd[4408]: Plugin /lib/rp-pppoe.so loaded. Jan 14 20:44:25 pppd[4408]: RP-PPPoE plugin version 3.12 compiled against pppd 2.4.7 Jan 14 20:44:25 udhcpd[3883]: sending OFFER of 192.168.1.138 Jan 14 20:44:25 pppd[4408]: pppd 2.4.7 started by daemon, uid 0 Jan 14 20:44:25 pppd[4408]: PPP session is 52517 (0xcd25) Jan 14 20:44:25 pppd[4408]: Connected to 70:0f:6a:46:ce:d0 via interface eth3 Jan 14 20:44:25 pppd[4408]: Using interface ppp0 Jan 14 20:44:25 pppd[4408]: Connect: ppp0 <--> eth3 Jan 14 20:44:25 pppd[4408]: PAP authentication succeeded Jan 14 20:44:25 pppd[4408]: peer from calling number 70: :6A: : :D0 authorized Jan 14 20:44:25 pppd[4408]: local IP address 194.55.95.182 Jan 14 20:44:25 pppd[4408]: remote IP address 80.80.220.254 Jan 14 20:44:25 pppd[4408]: primary DNS address 80.80.208.1 Jan 14 20:44:25 pppd[4408]: secondary DNS address 89.236.192.1 Jan 14 20:44:25 udhcpd[3883]: sending ACK to 192.168.1.138 Jan 14 20:44:25 pppd: No dgw stored. Jan 14 20:44:25 pppd: Replace default route to ppp0 Jan 14 20:44:25 pppd: Replace DNS from pppd Jan 14 20:44:25 pppd: Flush route cache Jan 14 20:44:25 pppd: Flush conntrack table Jan 14 20:44:25 pppd: Restart dns server, dyndns, ntp sync and rebuild shaper and iptables rules Jan 14 20:44:25 services: Restart needed services and scripts. Mode pppd Jan 14 20:44:26 QoS: Stopping SHAPER Jan 14 20:44:26 usbctrl(4364): TYPE=9/0/3 INTERFACE=9/0/0 Jan 14 20:44:26 QoS: Set default rules. Jan 14 20:44:26 Codel: QoS Add codel for all interfaces. Jan 14 20:44:26 iptables: Add netfiler rules Jan 14 20:44:26 iptables: Allow established/related in input Jan 14 20:44:26 iptables: Drop invalid state connections Jan 14 20:44:26 iptables: Service limit set Jan 14 20:44:26 iptables: Set igmp input rules Jan 14 20:44:26 iptables: DHCP server allow Jan 14 20:44:26 iptables: Dnsproxy allow to connect Jan 14 20:44:26 iptables: Remote managment web limit Jan 14 20:44:26 iptables: Remote managment ssh limit Jan 14 20:44:26 iptables: Remote managment telnet limit Jan 14 20:44:26 iptables: Allow rate limited ping from all interfaces. Jan 14 20:44:26 iptables: Set forward rules Jan 14 20:44:26 iptables: Set igmp forward rules Jan 14 20:44:26 iptables: Allow forward from LAN to any Jan 14 20:44:26 iptables: Redirect all DNS requests to local DNS proxy. Jan 14 20:44:26 iptables: Call to add VPN netfilter rules. Jan 14 20:44:26 iptables: DMZ enabled for 192.168.1.150 Jan 14 20:44:26 iptables: Allow established/related in forward Jan 14 20:44:27 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 20:44:27 resolv: Add ISP DNS from vpn servers for local resolv Jan 14 20:44:27 dnsserver: Generate /etc/hosts file. Jan 14 20:44:27 dnsserver: Send HUP to dnsmasq. Jan 14 20:44:27 dnsmasq[1154]: read /etc/hosts - 6 addresses Jan 14 20:44:27 dnsmasq[1154]: using nameserver 77.88.8.7#53 Jan 14 20:44:27 dnsmasq[1154]: using nameserver 77.88.8.3#53 Jan 14 20:44:27 dnsmasq[1154]: using nameserver 80.80.208.1#53 Jan 14 20:44:27 dnsmasq[1154]: using nameserver 89.236.192.1#53 Jan 14 20:44:27 dyndns: Stopping DynDns Jan 14 20:44:28 dyndns: Starting DynDNS Jan 14 20:44:28 INADYN[4996]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 14 20:44:28 ntp: Stopping NTPD Jan 14 20:44:28 zcip: config eth3 169.254.223.175 Jan 14 20:44:28 zcip: Add ip adress 169.254.223.175/32 to interface eth3 and interface up. Jan 14 20:44:28 zcip: Add route to multicast subnet. Jan 14 20:44:28 ntp: Starting NTPD Jan 14 20:44:29 udhcpd[3883]: sending OFFER of 192.168.1.69 Jan 14 20:44:29 udhcpd[3883]: sending ACK to 192.168.1.69 Jan 14 20:44:29 irqbalance: Stopping irqbalance Jan 14 20:45:39 kernel: br0: port 1(eth2) entered forwarding state Jan 14 20:45:39 irqbalance: Start irqbalance routing/wifi optimize mode Jan 14 20:45:39 kernel: br0: port 2(ra0) entered forwarding state Jan 14 20:45:40 irqbalance: Start irqbalance auto mode Jan 14 20:45:40 kernel: br0: port 3(rai0) entered forwarding state Jan 14 20:45:40 pppd: Enable forwarding for ppp0 interface Jan 14 20:45:40 pppd[4408]: System time change detected. Jan 14 20:45:41 kernel: ASSOC - Assign AID=3 to 2.4GHz AP 9c: : : :bf:37 Jan 14 20:45:41 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 20:45:43 udhcpd[3883]: sending OFFER of 192.168.1.36 Jan 14 20:45:43 udhcpd[3883]: sending ACK to 192.168.1.36 Jan 14 20:45:44 igmpproxy: Replace route to multicast subnet via eth3. Jan 14 20:45:44 igmpproxy: Starting IGMPPROXY Jan 14 20:45:53 get_ieee_oui: Get OUI lists from Jan 14 20:46:33 kernel: ASSOC - Assign AID=4 to 2.4GHz AP : : :45: :73 Jan 14 20:46:33 kernel: ASSOC - HT support STA. Update AP OperaionMode=2 , fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jan 14 20:46:35 udhcpd[3883]: sending OFFER of 192.168.1.227 Jan 14 20:46:36 udhcpd[3883]: sending ACK to 192.168.1.227 Jan 14 20:46:48 fwupdate[5494]: GW is ppp0, skip ICMP check Jan 14 20:46:48 fwupdate[5494]: You are using the latest firmware version. Jan 14 20:46:49 fwupdate[5494]: New firmware avialable: 1.8.3 (20201230) [Current firmware: 1.8.2 (20201217)] Вот лог после этих действий Jan 14 20:56:08 nginx-wive[4410]: doSystem: (rm -f /etc/dnsmasq.d/ads.conf) > /dev/console 2>&1 (0) Jan 14 20:56:08 dnsserver: Stopping DNSMASQ Jan 14 20:56:08 dnsmasq[1154]: exiting on receipt of SIGTERM Jan 14 20:56:09 dnsserver: Generate /etc/hosts file. Jan 14 20:56:09 dnsserver: Starting DNSMASQ Jan 14 20:56:09 nginx-wive[4410]: doSystem: (service dnsserver restart) > /dev/console 2>&1 (0) Jan 14 20:56:09 dnsmasq[5563]: started, version 2.80 cachesize 1024 Jan 14 20:56:09 dnsmasq[5563]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN no-DHCP no-scripts no-TFTP no-conntrack no-ipset no-auth DNSSEC no-loop-detect inotify no-dumpfile Jan 14 20:56:09 dnsmasq[5563]: read /etc/hosts - 6 addresses Jan 14 20:56:09 dnsmasq[5563]: using nameserver 77.88.8.7#53 Jan 14 20:56:09 dnsmasq[5563]: using nameserver 77.88.8.3#53 Jan 14 20:56:09 dnsmasq[5563]: using nameserver 80.80.208.1#53 Jan 14 20:56:09 dnsmasq[5563]: using nameserver 89.236.192.1#53 Jan 14 20:56:09 nginx-wive[4410]: doSystem: (services_restart.sh misc &) > /dev/console 2>&1 (0) Jan 14 20:56:10 services: Restart needed services and scripts. Mode misc Jan 14 20:56:10 QoS: Stopping SHAPER Jan 14 20:56:10 QoS: Set default rules. Jan 14 20:56:10 Codel: QoS Add codel for all interfaces. Jan 14 20:56:10 iptables: Add netfiler rules Jan 14 20:56:10 iptables: Allow established/related in input Jan 14 20:56:10 iptables: Drop invalid state connections Jan 14 20:56:10 iptables: Service limit set Jan 14 20:56:10 iptables: Set igmp input rules Jan 14 20:56:10 iptables: DHCP server allow Jan 14 20:56:10 iptables: Dnsproxy allow to connect Jan 14 20:56:10 iptables: Remote managment web limit Jan 14 20:56:10 iptables: Remote managment ssh limit Jan 14 20:56:10 iptables: Remote managment telnet limit Jan 14 20:56:10 iptables: Allow rate limited ping from all interfaces. Jan 14 20:56:10 iptables: Set forward rules Jan 14 20:56:10 iptables: Set igmp forward rules Jan 14 20:56:10 iptables: Allow forward from LAN to any Jan 14 20:56:10 iptables: Redirect all DNS requests to local DNS proxy. Jan 14 20:56:10 iptables: Call to add VPN netfilter rules. Jan 14 20:56:10 iptables: DMZ enabled for 192.168.1.150 Jan 14 20:56:11 iptables: Allow established/related in forward Jan 14 20:56:11 resolv: Generate resolv DNS1: 77.88.8.7 DNS2: 77.88.8.3 Jan 14 20:56:11 resolv: Add ISP DNS from vpn servers for local resolv Jan 14 20:56:11 dnsserver: Generate /etc/hosts file. Jan 14 20:56:11 dnsserver: Send HUP to dnsmasq. Jan 14 20:56:11 dnsmasq[5563]: read /etc/hosts - 6 addresses Jan 14 20:56:11 dnsmasq[5563]: using nameserver 77.88.8.7#53 Jan 14 20:56:11 dnsmasq[5563]: using nameserver 77.88.8.3#53 Jan 14 20:56:11 dnsmasq[5563]: using nameserver 80.80.208.1#53 Jan 14 20:56:11 dnsmasq[5563]: using nameserver 89.236.192.1#53 Jan 14 20:56:11 dyndns: Stopping DynDns Jan 14 20:56:12 dyndns: Starting DynDNS Jan 14 20:56:12 INADYN[6095]: INADYN: Started 'INADYN version 1.96.2' - dynamic DNS updater. Jan 14 20:56:12 ntp: Stopping NTPD Jan 14 20:56:12 ntp: Starting NTPD Jan 14 20:56:13 igmpproxy: Stopping IGMPPROXY Jan 14 20:56:13 igmpproxy: Wait 15 sec before start. Jan 14 20:56:14 kext: Nat mode Linux Hybrid Jan 14 20:56:14 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths. Jan 14 20:56:14 kext: NAT fastpath enabled. Jan 14 20:56:14 kext: Route fastpath enabled. Jan 14 20:56:14 kext: Netfilter fastpath enabled. Jan 14 20:56:14 kernel: Ralink HW NAT v2.52.0 Module Disabled Jan 14 20:56:14 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1 Jan 14 20:56:14 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384 Jan 14 20:56:14 kext: hw_nat: set binding threshold to 50. Jan 14 20:56:14 kext: Enable multicast to unicast conversion for ra0 rai0 Jan 14 20:56:14 lld2d: Stopping LLD2D Jan 14 20:56:15 lld2d: Starting LLD2D Jan 14 20:56:15 inetd: Stopping inetd Jan 14 20:56:16 inetd: Starting inetd Jan 14 20:56:16 transmission: Not any disk connected. Jan 14 20:56:16 dhcpd: Stop dhcpserver Jan 14 20:56:17 dhcpd: Configure dhcpserver Jan 14 20:56:17 dhcpd: Start dhcpserver Jan 14 20:56:17 udhcpd[6730]: started, v1.30.1 Jan 14 20:56:18 irqbalance: Stopping irqbalance Jan 14 20:56:18 irqbalance: Start irqbalance routing/wifi optimize mode Jan 14 20:56:19 irqbalance: Start irqbalance auto mode Jan 14 20:56:28 igmpproxy: Replace route to multicast subnet via eth3. Jan 14 20:56:28 igmpproxy: Starting IGMPPROXY -
Всем доброго времени суток. Имеется SNR-CPE-ME2 прошивка 1.8.2.1712201613. Имеется подписка на сервисе noip.com В настройках роутера включен DDNS с именем и паролем и статус горит "работает". В сетевом экране влючена проброска портов на локальный сервер. Проблема в том что сервис noip.com не определяет текущий внешний айпи роутера. При вводе в личном кабинете в сервисе noip.com текущего айпи роутера всё работает нормально. Но при перезагрузке роутера соответственно меняется его внешний айпи и сервис noip.com этот айпи не видит! При очередном ручном вводе нового айпи в кабинете сервиса всё начинает работать до очередной перезагрузки роутера. И такая ситуация только с этим роутером, кроме него имеем tp-link и d-link так с этими роутерами такой проблемы нет они работают с noip.com уже в течении двух лет без проблем. Решил я себе взять аппаратик покруче и в месте с ним приобрёл вот такую проблемку. Вот фото с текущим айпи роутера и айпи который видит сервис, эти айпи совершенно разные. Кто сталкивался с такой проблемой?
