Публикации
5
Зарегистрирован
6 августа, 2020
Посещение
30 сентября, 2020
trew911 изменил свою фотографию 11 августа, 2021
какой бан вы что я серьёзно я учу только
вот конфиг
# aug/13/2020 00:27:40 by RouterOS 6.46.5
# software id = DDNN-M8MS
# model = 951Ui-2HnD
# serial number = 8D0008D5117B
/interface ethernet
set [ find default-name=ether5 ] name=Local
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip pool
add name=dhcp_pool0 ranges=192.168.0.2-192.168.0.254
/ip dhcp-server
add address-pool=dhcp_pool0 disabled=no interface=Local name=dhcp1
/ip address
add address=192.168.0.1/24 interface=Local network=192.168.0.0
add address=192.168.1.2/24 interface=WAN1 network=192.168.1.0
add address=192.168.2.2/24 interface=WAN2 network=192.168.2.0
/ip dhcp-server network
add address=192.168.0.0/24 dns-server=8.8.8.8 gateway=192.168.0.1
/ip dns
set servers=192.168.1.1,192.168.2.1,8.8.8.8
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=\
WAN2_conn
add action=mark-routing chain=output connection-mark=WAN1_conn \
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
new-routing-mark=to_WAN2
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=\
Local
add action=accept chain=prerouting dst-address=192.168.2.0/24 in-interface=\
Local
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local in-interface=Local new-connection-mark=WAN1_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0
dst-address-type=!local in-interface=Local new-connection-mark=WAN2_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=Local new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting new-routing-mark=mixed src-address=\
192.168.0.0/24
/ip firewall nat
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
/ip route
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=192.168.2.1
/system clock
set time-zone-name=Asia/Yekaterinburg
вы мне сломали голову картинкой я только учусь осваиваю а тут пару сопротивлений на схеме
моя схема изначально кривая((( надо с нуля делать , опять гугл те же самые ссылки и форумы
нужно с нуля
192.168.0.1 my LANether1 - WAN1 - 192.168.1.1ether2 - WAN2 - 192.168.2.1
как суммировать 2 входящих канала 40 и 30 мбит и получить 70
С нуля а то везде по гайдам начинается с мангл, а как настроен-сброшен микротик ?? по дефаулту или пустая конфигурация ничего нет
ECMP да на вики вроде всё просто ,но какие прежде настройки должны быть?
ну тема 3 вхоящих ван ,, два ван работают а по 3 не идут пакеты 10 раз перепроверил -переделал уже
совет нужен уже всякую чушь гуглю
# jan/02/1970 02:05:17 by RouterOS 6.46.5
/interface ethernet
set [ find default-name=ether3 ] name=WAN3
/interface wireless
/ip pool
/ip dhcp-server
/ip neighbor discovery-settings
set discover-interface-list=all
/ip address
add address=192.168.3.2/24 interface=WAN2 network=192.168.3.0
add address=192.168.2.2/24 interface=WAN3 network=192.168.2.0
/ip firewall mangle
WAN1_conn
WAN2_conn
Local
add action=accept chain=prerouting dst-address=192.168.3.0/24 in-interface=\
Local
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=Local new-connection-mark=WAN1_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:3/0
in-interface=Local new-connection-mark=WAN2_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=input in-interface=WAN3 new-connection-mark=\
WAN3_conn
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
in-interface=Local new-routing-mark=to_WAN3
Local
add action=mark-connection chain=prerouting in-interface=Local \
new-connection-mark=WAN3_conn passthrough=yes per-connection-classifier=\
both-addresses-and-ports:3/2
add action=mark-routing chain=output connection-mark=WAN3_conn \
new-routing-mark=to_WAN3 passthrough=yes
/ip firewall nat
add action=masquerade chain=srcnat out-interface=WAN3
/ip route
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN3
