я прописал команду no debug ip igmp-proxy
помогло
теперь логи выглядят так...
Feb 7 11:44:55 %EPON-ONUDEREG: ONU f8f0.8216.0b08 is deregistered on EPON0/1:8.
Feb 7 11:41:19 /ifindex-config is wrote, TID:7563600
Feb 7 11:41:13 config.db is wrote, TID:7563600
Feb 7 11:41:09 /startup-config is wrote, TID:7563600
Feb 7 11:31:40 ONU-4-PRECFG: Parsing "epon onu port 4 ctc mcst mc-vlan add 111"
error. Please check "cmd-sequence 16" in preconfig template "t5". (ifindex: 42)
Feb 7 11:31:40 ONU-4-PRECFG: Parsing "epon onu port 4 ctc mcst tag-stripe enabl
e" error. Please check "cmd-sequence 15" in preconfig template "t5". (ifindex: 4
2)
Feb 7 11:31:40 olt_ctc_onu_mc_tagstripe_setONU-MCST-CFGERR: get port error
Feb 7 11:31:40 ONU-4-PRECFG: Parsing "epon onu port 4 ctc vlan loopback detect"
error. Please check "cmd-sequence 14" in preconfig template "t5". (ifindex: 42)
Feb 7 11:31:40 ONU-4-PRECFG: Parsing "epon onu port 4 ctc vlan mode trunk 1752
444" error. Please check "cmd-sequence 13" in preconfig template "t5". (ifindex:
42)
Feb 7 11:31:40 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Feb 7 11:31:40 ONU-4-PRECFG: Parsing "epon onu port 3 ctc mcst mc-vlan add 111"
error. Please check "cmd-sequence 12" in preconfig template "t5". (ifindex: 42)
Feb 7 11:31:40 ONU-4-PRECFG: Parsing "epon onu port 3 ctc mcst tag-stripe enabl
e" error. Please check "cmd-sequence 11" in preconfig template "t5". (ifindex: 4
2)
подскажите как правильно написать шаблон для однапортовых ону с catv
Сейчас шаблон выглядит так...
epon onu-config-template t5
cmd-sequence 001 epon onu port 1 ctc vlan mode trunk 1752 444
cmd-sequence 002 epon onu port 1 ctc vlan loopback detect
cmd-sequence 003 epon onu port 1 ctc mcst tag-stripe enable
cmd-sequence 004 epon onu port 1 ctc mcst mc-vlan add 111
cmd-sequence 005 epon onu port 2 ctc vlan mode trunk 1752 444
cmd-sequence 006 epon onu port 2 ctc vlan loopback detect
cmd-sequence 007 epon onu port 2 ctc mcst tag-stripe enable
cmd-sequence 008 epon onu port 2 ctc mcst mc-vlan add 111
cmd-sequence 009 epon onu port 3 ctc vlan mode trunk 1752 444
cmd-sequence 010 epon onu port 3 ctc vlan loopback detect
cmd-sequence 011 epon onu port 3 ctc mcst tag-stripe enable
cmd-sequence 012 epon onu port 3 ctc mcst mc-vlan add 111
cmd-sequence 013 epon onu port 4 ctc vlan mode trunk 1752 444
cmd-sequence 014 epon onu port 4 ctc vlan loopback detect
cmd-sequence 015 epon onu port 4 ctc mcst tag-stripe enable
cmd-sequence 016 epon onu port 4 ctc mcst mc-vlan add 111
