На узле агрегации(snr2995) и на l2 свичах за ним настроен mstp. На одном из свичей(SNR-S2985G-24T-UPS), судя по логам постоянно перестаивается топология, в логах имеем:
2231 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2230 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 5
2229 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2228 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 4
2227 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2226 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 3
2225 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2224 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 1
2223 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:CistRoot = 24576.f8:f0:82:78:72:80, CistRegRoot = 24576.f8:f0:82:78:72:80
2222 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE=0
2221 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2220 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 5
2219 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2218 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 4
2217 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2216 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 3
2215 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2214 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 1
2213 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:CistRoot = 32768.f8:f0:82:78:08:b7, CistRegRoot = 32768.f8:f0:82:78:08:b7
2212 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE=0
За свичем на котором постоянно происходит изменение рута включено еще несколько свичей каскадом, соответственно на них также по логам идет перестроение.
Схема следующая:
L3 (3порт)----(8порт)snr2985-8(10порт)----(28порт)SNR-S2985G-24T-UPS -- с этого свича c 23 по 27 порт идут еще свичи друг за другом.
На L3 специально понижен приоритет до 24576 для всех интансов.
Настройки mstp на всех свичах одинаковые, при перестроение порт между snr2985-8 и SNR-S2985G-24T-UPS не падает.
В чем может быть проблема, почему каждые 20-40 секунд SNR-S2985G-24T-UPS делает себя рутом и сразу же перестраивает что рут за 28 портом?
Конфигурация stp:
spanning-tree mst configuration
name ru.fcomm
revision-level 1
instance 1 vlan 1-79
instance 2 vlan 80-95;130-150
instance 3 vlan 96-110;112;114;151-199
instance 4 vlan 200-699
instance 5 vlan 700-799
instance 6 vlan 800-4094
instance 7 vlan 111;113;115;117-121;124-129
instance 8 vlan 116
instance 9 vlan 122
instance 10 vlan 123
exit
spanning-tree
Свич:
SNR-S2985G-24T-UPS Device, Compiled on Nov 28 13:19:04 2018
CPU Mac f8:f0:82:78:08:b7
Vlan MAC f8:f0:82:78:08:b6
SoftWare Version 7.0.3.5(R0241.0283)
BootRom Version 7.2.40
HardWare Version 1.0.1
CPLD Version N/A
Serial No.:SW071010H923001066
Copyright (C) 2018 NAG LLC
All rights reserved
Last reboot is cold reset.
Uptime is 0 weeks, 1 days, 20 hours, 52 minutes
