Здравствуйте! установил на тп голову BDCOM 3310. конфиг стандартный, стыренный) всё работает стабильно, вот только голова всё время пишет одни и те же логи. нигде не смог найти расшифровки.
May 10 21:32:51 User user1 enter privilege mode from vty 3, level = 15
May 10 18:23:41 %MBLK-4-OVERTIME: datab (0x87c765b8, size 0) alloc at pc 0x803a1d88 tick 0x08eda20a, hold for 30 minutes, maybe leak
May 10 18:23:41 %MBLK-4-OVERTIME: mblk (0x87c0fd24) alloc at pc 0x803a1d88 tick 0x08eda20a, hold for 30 minutes, maybe leak
May 10 17:07:01 %MBLK-4-OVERTIME: datab (0x87c76928, size 0) alloc at pc 0x803a1d88 tick 0x08e3c913, hold for 61 minutes, maybe leak
May 10 17:07:01 %MBLK-4-OVERTIME: mblk (0x87c12c8c) alloc at pc 0x803a1d88 tick 0x08e3c913, hold for 61 minutes, maybe leak
May 10 04:58:37 %MBLK-4-OVERTIME: datab (0x87c76f84, size 0) alloc at pc 0x803a1d88 tick 0x08a0a394, hold for 66 minutes, maybe leak
May 10 04:58:37 %MBLK-4-OVERTIME: mblk (0x87c1ec7c) alloc at pc 0x803a1d88 tick 0x08a0a394, hold for 66 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: datab (0x87c78aac, size 0) alloc at pc 0x803a1d88 tick 0x0889d0e4, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: datab (0x87c78660, size 0) alloc at pc 0x803a1d88 tick 0x0889d415, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: datab (0x87c77454, size 0) alloc at pc 0x803a1d88 tick 0x0889d225, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: datab (0x87c768fc, size 0) alloc at pc 0x803a1d88 tick 0x0889dcdf, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: datab (0x87c76878, size 0) alloc at pc 0x803a1d88 tick 0x0889d71f, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: mblk (0x87c1a96c) alloc at pc 0x803a1d88 tick 0x0889d415, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: mblk (0x87c19ddc) alloc at pc 0x803a1d88 tick 0x0889d71f, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: mblk (0x87c162e4) alloc at pc 0x803a1d88 tick 0x0889d225, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: mblk (0x87c13b94) alloc at pc 0x803a1d88 tick 0x0889dcdf, hold for 47 minutes, maybe leak
May 10 00:30:16 %MBLK-4-OVERTIME: mblk (0x87c134a4) alloc at pc 0x803a1d88 tick 0x0889d0e4, hold for 47 minutes, maybe leak
May 10 00:25:00 User user1 logouted from 10.92.92.23 on vty 3
May 9 23:13:36 %MBLK-4-OVERTIME: datab (0x87c784a8, size 0) alloc at pc 0x803a1d88 tick 0x088360a3, hold for 41 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: datab (0x87c775b4, size 0) alloc at pc 0x803a1d88 tick 0x0883842d, hold for 39 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: datab (0x87c76744, size 0) alloc at pc 0x803a1d88 tick 0x08834489, hold for 42 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: datab (0x87c7658c, size 0) alloc at pc 0x803a1d88 tick 0x0883a6ec, hold for 38 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: mblk (0x87c2014c) alloc at pc 0x803a1d88 tick 0x088360a3, hold for 41 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: mblk (0x87c1dd74) alloc at pc 0x803a1d88 tick 0x0883842d, hold for 39 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: mblk (0x87c1a154) alloc at pc 0x803a1d88 tick 0x08834489, hold for 42 minutes, maybe leak
May 9 23:13:36 %MBLK-4-OVERTIME: mblk (0x87c13254) alloc at pc 0x803a1d88 tick 0x0883a6ec, hold for 38 minutes, maybe leak
May 9 18:43:19 User default logouted from XXXX on vty 4
May 9 18:43:19 %VTY-3-AUTHEN: [INFO] Vty waits for user's input timeout.
May 9 18:06:55 %MBLK-4-OVERTIME: datab (0x87c77530, size 0) alloc at pc 0x803a1d88 tick 0x0865a294, hold for 59 minutes, maybe leak
May 9 18:06:55 %MBLK-4-OVERTIME: mblk (0x87c18594) alloc at pc 0x803a1d88 tick 0x0865a294, hold for 59 minutes, maybe leak
May 9 17:28:34 %MBLK-4-OVERTIME: datab (0x87c7729c, size 0) alloc at pc 0x803a1d88 tick 0x0861cdf5, hold for 63 minutes, maybe leak
May 9 17:28:34 %MBLK-4-OVERTIME: datab (0x87c73120, size
сам конфиг:
Current configuration:
!version 10.1.0E build 46085
service timestamps log date
service timestamps debug date
service password-encryption
logging buffered 4096
error-disable-recovery 10800
hostname Golova
port-protected 1
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
epon oam-version 1 0x30
epon oam-version 2 0x21
epon oam-version 3 0x20
epon onu-config-template Aboni1
cmd-sequence 001 epon onu port 1 ctc vlan mode tag 172
cmd-sequence 002 epon onu port 1 ctc loopback detect
cmd-sequence 003 epon onu port 2 ctc vlan mode tag 172
cmd-sequence 004 epon onu port 2 ctc loopback detect
cmd-sequence 005 epon onu port 3 ctc vlan mode tag 172
cmd-sequence 006 epon onu port 3 ctc loopback detect
cmd-sequence 007 epon onu port 4 ctc vlan mode tag 172
cmd-sequence 008 epon onu port 4 ctc loopback detect
cmd-sequence 009 loopback-detection recovery-time 7200
!!slot 0 89
interface GigaEthernet0/1
description XXXX
switchport trunk vlan-allowed 24,94,170,172,4090,4094
switchport trunk vlan-untagged none
switchport mode trunk
interface GigaEthernet0/2
interface GigaEthernet0/3
interface GigaEthernet0/4
interface GigaEthernet0/5
interface GigaEthernet0/6
description Manage-Local
switchport trunk vlan-allowed 1,173,4094
switchport trunk vlan-untagged 1
switchport protected 1
interface EPON0/1
description 1eye
epon pre-config-template Aboni1 binded-onu-llid 1-64
epon bind-onu mac xxxxxxxxxxxx 1
epon bind-onu mac xxxxxxxxxxxx 2
epon bind-onu mac xxxxxxxxxxxx 3
epon bind-onu mac xxxxxxxxxxxx 4
epon bind-onu mac xxxxxxxxxxxx 5
epon bind-onu mac xxxxxxxxxxxx 6
epon bind-onu mac xxxxxxxxxxxx 7
filter bpdu
filter dhcp
interface EPON0/1:1
epon onu description XXXX
epon onu port 1 ctc vlan mode trunk 172 24,170,4090,4094
epon sla upstream pir 500000 cir 10000
epon sla downstream pir 500000 cir 10000
interface EPON0/1:2
interface EPON0/1:3
epon onu port 1 ctc vlan mode tag 172 priority 0
interface EPON0/1:4
interface EPON0/1:5
interface EPON0/1:6
epon onu port 1 ctc vlan mode tag 170 priority 0
interface EPON0/1:7
interface EPON0/2
shutdown
interface EPON0/3
shutdown
interface EPON0/4
shutdown
!!slot end
interface VLAN1
description local manage test
ip address 10.94.94.2 255.255.255.0
interface VLAN24
no ip address
interface VLAN170
no ip address
interface VLAN172
no ip address
interface VLAN173
ip address 192.168.173.2 255.255.255.0
interface VLAN4094
description core MANAGE
ip address dhcp
vlan 24
name VLAN024
vlan XXXX
ip telnet source-interface VLANXXXX
ip telnet max-user 5
ip http server
line vty 0
exec-timeout 0
line vty 1
exec-timeout 0
line vty 2
exec-timeout 0
line vty 3
exec-timeout 0
line vty 4
exec-timeout 0
line vty 5
exec-timeout 0
line vty 6
exec-timeout 0
line vty 7
exec-timeout 0
line vty 8
exec-timeout 0
line vty 9
exec-timeout 0
line vty 10
exec-timeout 0
line vty 11
exec-timeout 0
line vty 12
exec-timeout 0
line vty 13
exec-timeout 0
line vty 14
exec-timeout 0
line vty 15
exec-timeout 0
line vty 16
exec-timeout 0
line vty 17
exec-timeout 0
line vty 18
exec-timeout 0
line vty 19
exec-timeout 0
line vty 20
exec-timeout 0
line vty 21
exec-timeout 0
line vty 22
exec-timeout 0
line vty 23
exec-timeout 0
line vty 24
exec-timeout 0
line vty 25
exec-timeout 0
line vty 26
exec-timeout 0
line vty 27
exec-timeout 0
line vty 28
exec-timeout 0
line vty 29
exec-timeout 0
line vty 30
exec-timeout 0
line vty 31
exec-timeout 0
ip sshd enable
Надеюсь кто-нибудь прольет мне свет на эти логи)
Спасибо!
