Добрый день!
Прошу помощи.
Не могу настроить работу Интернета и мультикаста на ону.
У нас 1 Uplink
interface GigaEthernet0/1
description UpLink
switchport trunk vlan-allowed 303,331-332,400
switchport trunk vlan-untagged none
switchport mode dot1q-tunnel-uplink
switchport pvid 400
dhcp snooping trust
keepalive
vlan 331 Инет
vlan 400 Мультикаст
на interface GigaEthernet0/1
вижу адреса:
BDCOM_178#sh mac address-table vlan 400
Mac Address Table (Total 27)
Vlan Mac Address Type Ports
400 0006.f41f.413c DYNAMIC g0/1
400 0006.f431.eb64 DYNAMIC g0/1
400 0006.f431.eb88 DYNAMIC g0/1
400 a8f9.4bee.96c3 DYNAMIC g0/1
Интернет через vlan 331 есить.
А мультикаст не проходит.
Дальше не могу разобраться в конфиге где проблема:
BDCOM_178#sh ru
Building configuration...
Current configuration:
!version 10.3.0C build 53126
service timestamps log date
service timestamps debug date
logging source-interface VLAN303
logging 172.17.0.1
logging buffered 16386
logging buffered informational
logging console critical
logging facility local0
logging trap debugging
logging command
hostname BDCOM_178
port-protected 1
no spanning-tree
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 0 admin
gpon profile onu-tcont tcont-default id 1
gpon-profile tcont-type 3 pir 1024000 cir 512
gpon profile onu-tcont inter id 2
gpon-profile tcont-type 3 pir 9984 cir 1024
gpon profile onu-tcont video id 3
gpon-profile tcont-type 2 cir 4032
gpon profile onu-rate-limit ratelimit-default id 1
gpon-profile pir 1024000 cir 6000
gpon profile onu-rate-limit def id 2
gpon profile onu-rate-limit virtuaex id 3
gpon profile onu-virtual-port virtual-port-default id 1
gpon-profile encryption disable
gpon-profile upstream queue 8
gpon-profile upstream rate-limit-profile ratelimit-default
gpon-profile downstream queue 8
gpon profile onu-tcont-virtual-port-bind tvbind-default id 1
gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default
gpon profile onu-tcont-virtual-port-bind video id 2
gpon-profile virtual-port 2 profile virtual-port-default tcont 3 profile video
gpon-profile virtual-port 1 profile virtual-port-default tcont 2 profile inter
gpon profile onu-flow-mapping flow-mapping-default id 1
gpon-profile entry 1 uni type eth-uni all
gpon-profile entry 1 virtual-port 1
gpon profile onu-flow-mapping flow-mapping-default-hgu id 2
gpon-profile entry 1 uni type veip all
gpon profile onu-flow-mapping test id 3
gpon-profile entry 1 uni type eth-uni 1
gpon-profile entry 1 vlan 331
gpon-profile entry 2 uni type eth-uni 1
gpon-profile entry 2 vlan 400
gpon-profile entry 2 virtual-port 2
gpon profile onu-flow-mapping CONF_ONU_2 id 4
gpon profile onu-vlan test id 3
gpon-profile vlan mode trunk
gpon-profile vlan pvid 300 0
gpon-profile vlan trunk vlan-allowed 300,331,400
gpon profile onu-vlan CONF_ONU_2 id 4
gpon-profile vlan pvid 331 0
gpon-profile vlan trunk vlan-allowed 331,400
gpon profile onu-mcst-oper mcst id 2
gpon-profile fast-leave-mode enable
gpon-profile upstream-igmp-tag add 400 4
gpon-profile downstream-mcst-tag strip
gpon profile onu-mcst-dynamic-group mcst id 2
gpon-profile entry 1 multicast-gemport 4093
gpon-profile entry 1 multicast-vlan-id 2
gpon-profile entry 1 multicast-group-address-range 239.......... to 239............
gpon onutype-template onutype-default-hgu
gpon-onutype match ctc-onu-type HGU
gpon-onutype config tcont-virtual-port-bind-profile tvbind-default
gpon-onutype config flow-mapping-profile flow-mapping-default-hgu
gpon onu-config-template test
cmd-sequence 001 gpon onu uni 1 vlan-profile test
cmd-sequence 002 gpon onu tcont-virtual-port-bind-profile tvbind-default
cmd-sequence 003 gpon onu flow-mapping-profile test
gpon onu-config-template CONF_ONU_2
cmd-sequence 001 gpon onu flow-mapping-profile CONF_ONU_2
cmd-sequence 003 gpon onu uni 1 vlan-profile CONF_ONU_2
cmd-sequence 004 gpon onu uni 1 onu-mcst-oper mcst
cmd-sequence 005 gpon onu uni 1 onu-mcst-dynamic-group mcst
interface Null0
interface GigaEthernet0/0
no ip address
no ip directed-broadcast
!!slot 0 1
description UpLink
dhcp snooping trust
keepalive
interface GPON0/2
gpon pre-config-template CONF_ONU_2 bind-onuid 1-128
gpon bind-onutype onutype-default-hgu precedence 127
gpon bind-onutype onutype-default precedence 128
gpon bind-onu sn 4244434D621208D5 1
filter dhcp
switchport trunk vlan-allowed 331,400
switchport mode trunk
switchport pvid 400
storm-control broadcast threshold 1000
storm-control multicast threshold 1000
switchport protected 1
interface GPON0/2:1
gpon onu equipment-id 1111
gpon onu virtual-port 1 gem-port 256
gpon onu uni 1 mcst-dynamic-group-profile mcst
!!slot end
interface VLAN1
no ip address
interface VLAN300
ip address 10.100.77.178 255.255.0.0
interface VLAN303
interface VLAN400
no ip address
filter enable
vlan 332
name BRAS_2
vlan 1,300,303,331-332,400,3400
loopback-detection
ip mcst enable
ip mcst proxy-vlan 400
ip mcst querier enable
ip mcst mrouter interface GigaEthernet0/1
ip dhcpd enable
ip dhcp-relay snooping
ip dhcp-relay snooping vlan 331-332
ip dhcp-relay snooping information option format hn-type host
ip dhcp-relay snooping log
ip exf
ipv6 exf
ip http language english
ip http server
