Добрый день. Помогите настроить 10Г sfp MIKROTIK CCR1036-12G-4S-EM
RouterOS v6.43.12 версия прошивки.
Порт стоит на автосогласование. Sfp+ FIBERTRADE 2КМ.
В состоянии порта пишет 1г.
Может что то ещё надо настроить.
В
console#sh fi op de int te0/1
Port Temp Voltage Current Output Input LOS Transceiver
[C] [V] [mA] Power Power Type
[mW / dBm] [mW / dBm]
te1/0/1 35 3.26 20.53 0.33 / -4.74 0.02 / -16.30 No Fiber
Temp - Internally measured transceiver temperature
Voltage - Internally measured supply voltage
Current - Measured TX bias current
Output Power - Measured TX output power in milliWatts/dBm
Input Power - Measured RX received power in milliWatts/dBm
LOS - Loss of signal
N/A - Not Available, N/S - Not Supported, W - Warning, E - Error
Transceiver information:
Vendor name: Fibertrade
Serial number: FT1604210683
Part number: FT-SFP+SR-2-D
Vendor revision: A
Connector type: LC
Type: SFP/SFP+
Compliance code: 10GBASE-LR
Laser wavelength: 1310 nm
Transfer distance: 2000 m
Diagnostic: supported
Threshold parameters:
Temperature [C]
Low Warning: 0 High Warning: 85
Low Alarm: -5 High Alarm: 90
Voltage [V]
Low Warning: 2.80 High Warning: 3.70
Low Alarm: 2.70 High Alarm: 3.80
Current [mA]
Low Warning: 0.10 High Warning: 90.00
Low Alarm: 0.00 High Alarm: 100.00
Output Power [mW / dBm]
Low Warning: 0.25 / -6.00 High Warning: 1.00 / 0.00
Low Alarm: 0.19 / -7.00 High Alarm: 1.25 / 0.99
Input Power [mW / dBm]
Low Warning: 0.03 / -15.00 High Warning: 1.00 / 0.00
Low Alarm: 0.02 / -16.00 High Alarm: 1.25 / 0.99
