# mar/21/2018 03:38:13 by RouterOS 6.18
# software id = MAL2-H0QP
/interface bridge
add admin-mac=4C:5E:0C:E9:BB:C0 auto-mac=no l2mtu=1598 name=bridge-local
/interface ethernet
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=\
ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=\
ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=\
ether9-slave-local
set [ find default-name=ether10 ] name=ethernet10_Backup
/ip neighbor discovery
set ether1-wan discover=no
/interface vlan
add interface=bridge-local l2mtu=1594 name=vlan2 vlan-id=2
/ip hotspot profile
add hotspot-address=10.5.50.1 name=hsprof1
/ip hotspot user profile
add name=uprof1 shared-users=unlimited transparent-proxy=yes
/ip pool
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=10.10.10.1-10.10.10.254
add name=hs-pool-16 ranges=10.5.50.2-10.5.50.254
/ip dhcp-server
add address-pool=dhcp disabled=no interface=bridge-local lease-time=10m name=\
default
add address-pool=hs-pool-16 disabled=no interface=vlan2 lease-time=1h name=\
dhcp1
/ip hotspot
add address-pool=hs-pool-16 disabled=no interface=vlan2 name=hotspot1 \
profile=hsprof1
/ppp profile
add change-tcp-mss=yes local-address=192.168.88.1 name=RemoteUser \
remote-address=vpn
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 \
default-route-distance=1 dial-on-demand=no disabled=no interface=\
ether1-wan keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=disabled \
name=pppoe-wan password=52781 profile=default service-name="" \
use-peer-dns=yes user=OBLBOL_52781@unlim
/interface bridge port
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
/interface l2tp-server server
set default-profile=default enabled=yes max-mru=1430 max-mtu=1430
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
ether1-wan
/ip dhcp-server lease
add address=192.168.88.250 client-id=1:76:34:8f:d8:b0:51 mac-address=\
76:34:8F:D8:B0:51 server=default
/ip dhcp-server network
add address=10.5.50.0/24 comment="hotspot network" dns-server=10.5.50.1 \
gateway=10.5.50.1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=192.168.8.0/24 list=vpn_dns
add address=192.168.88.0/24 list=vpn_dns
/ip firewall filter
add chain=input dst-port=1723 protocol=tcp
add chain=input dst-port=12333 protocol=udp
add chain=input comment=L2TP dst-port=1701 protocol=udp
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add chain=input protocol=icmp
add chain=input disabled=yes dst-port=1540,1541,1560-1591 protocol=tcp
/ip firewall nat
add action=netmap chain=dstnat dst-port=12333 protocol=udp to-addresses=\
192.168.88.1 to-ports=161
add action=netmap chain=dstnat dst-port=10050 protocol=tcp to-addresses=\
192.168.88.13 to-ports=10050
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=pppoe-wan
add action=netmap chain=dstnat comment=\
"service ports 23654_80 to SERVER 192.168.88.13" dst-port=23654 \
in-interface=pppoe-wan protocol=tcp to-addresses=192.168.88.13 to-ports=\
3389
add action=netmap chain=srcnat out-interface=pppoe-wan src-address=\
192.168.88.253 to-addresses=85.113.182.**
add action=netmap chain=dstnat dst-address=85.113.182.** in-interface=\
pppoe-wan to-addresses=192.168.88.253
add action=netmap chain=dstnat disabled=yes dst-address=85.113.18.** \
dst-port=88 in-interface=pppoe-wan protocol=tcp to-addresses=\
192.168.88.13 to-ports=80
add action=masquerade chain=srcnat out-interface=all-ppp
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=10.5.50.0/24
add action=netmap chain=dstnat dst-port=9099 protocol=udp to-addresses=\
/ip hotspot user
add name=admin password=sala666 profile=uprof1
/ip route
add distance=1 dst-address=192.168.0.0/24 gateway=10.10.10.252 pref-src=\
192.168.88.1
add distance=1 dst-address=192.168.8.0/24 gateway=10.10.10.254 pref-src=\
192.168.88.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=no
/ppp secret
add local-address=192.168.88.1 name=RemoteUser1 password="*********" \
remote-address=10.10.10.254 service=l2tp
add local-address=192.168.88.1 name=Remote password=********* remote-address=\
10.10.10.252 service=l2tp
/snmp
set enabled=yes trap-community=public trap-version=2
/system watchdog
set automatic-supout=no watchdog-timer=no
/tool mac-server
set [ find default=yes ] disabled=yes
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ethernet10_Backup
/tool mac-server mac-winbox
Вот эта конфигигурация Микротика, к которому подключаються двое остальных!
Также потребляемость ресурсов.
