Здравствуйте.
Проблема с последней прошивкой nos-0310.
Коммутатор S2995-24FX.
Обновил rom до 7.5.25, обновил nos до 0310. Перезагрузился и LAG перестал работать.
Физика есть, линки рабочие. Чуть-чуть конфига:
port-group 1
Interface Ethernet1/0/9
port-group 1 mode active
Interface Ethernet1/0/21
Interface Port-Channel1
switchport hybrid native vlan 1
#sh int eth st
Interface Link/Protocol Speed Duplex Type
1/0/9 UP/UP a-1G a-FULL SFP
1/0/21 UP/UP a-1G a-FULL SFP
#sh int port-channel 1
Interface brief:
Port-Channel1 is down, line protocol is down
Port-Channel1 is layer 2 port, alias name is 1, index is 1025
Port-Channel1 is LAG port, member is :
Hardware is EtherChannel, address is f8-f0-82-78-85-37
PVID is 405
MTU 9000 bytes, BW 10000 Kbit
Time since last status change:0w-0d-5h-38m-23s (20303 seconds)
Encapsulation ARPA, Loopback not set
Auto-duplex, Auto-speed
FlowControl is off, MDI type is auto
Statistics:
5 minute input rate 213247 bits/sec, 71 packets/sec
5 minute output rate 101 bits/sec, 0 packets/sec
The last 5 second input rate 139738 bits/sec, 51 packets/sec
The last 5 second output rate 0 bits/sec, 0 packets/sec
Input packets statistics:
1557279 input packets, 511491417 bytes, 0 no buffer
77300 unicast packets, 92499 multicast packets, 1387480 broadcast packets
0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
0 abort, 0 length error, 0 undersize 0 jabber, 0 fragments, 0 pause frame
Output packets statistics:
2723 output packets, 262464 bytes, 0 underruns
0 unicast packets, 2723 multicast packets, 0 broadcast packets
0 output errors, 0 collisions, 0 late collisions, 0 pause frame
Откатился назад на nos-0195. Проблем нет, LAG работает.
Только у меня такая беда случилась?
