chebotenko
Новичок
  • Публикации
  • Зарегистрирован
  • Посещение
О chebotenko
  • Звание
    Абитуриент
    Абитуриент
  1. Проблема с DGS3100-24, прыгнуло напряжение в сети. БП остался живой, напряжения все в норме. Скрин телнета. ------ Performing the Power-On Self Test (POST) ------ UART Channel Loopback Test........................PASS Testing the System SDRAM..........................PASS Boot1 Checksum Test...............................PASS Boot2 Checksum Test...............................PASS Flash Image Validation Test.......................PASS Restoring system configuration defaults BOOT Software Version 1.0.1.05 Built 13-Oct-2009 15:37:32 MAC Address : f0:7d:68:af:5e:ca. Preparing to decompress... 100% Decompressing SW from image-1 100% OK Running from RAM... About to erase CDB. Terminal baud rate will now be set to default! ******************************************************************** *** Running SW Ver. 3.60.30 Date 12-Aug-2010 Time 08:50:35 *** ******************************************************************** Serial Number : F3DR2A7000304. HW version is: a2 Base Mac address is: f0:7d:68:af:5e:ca Dram size is: 64M bytes Flash size is: 16M bytes 01-Jan-2000 01:01:10 %CDB-I-LOADCONFIG: Loading running configuration. 01-Jan-2000 01:01:10 %CDB-I-LOADCONFIG: Loading startup configuration. Device configuration: Slot 1 - DGS-3100-24 ST ------------------------------------ -- Unit Number 1 -- ------------------------------------ На команды с клавы не реагирует.
