Azizbek
Пользователи
  • Content Count
    16
  • Joined
  • Last visited
1 Follower
About Azizbek
  • Rank
    Абитуриент
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
  1. думаю вы были правы! MA5680T(config)#interface eth 0/1 MA5680T(config-if-eth-0/1)#display ? --------------------------------------------- Command of eth Mode: --------------------------------------------- board Display information of board car-port CAR of port and CoS eth Eth profile mac-address Mac-address command group mirror Display mirror information network-role Network role offline-tx-off-time Display disable time of optical port of tx port <Group> port command group stack-port Stack port statistics Display statistics of ethernet port tag-transform Display the state of the tag transformation traffic-suppress Display information of port traffic suppression MA5680T(config)#interface eth 0/2 MA5680T(config-if-eth-0/2)#? --------------------------------------------- Command of eth Mode: --------------------------------------------- alarm-config Bind alarm profile to ethernet port auto-neg Enable/Disable port negotiation car-port CAR of port and CoS display Display information duplex Set duplex eth Eth profile flow-control Support flow control jumbo-frame Set jumbo frame enable/disable loopback Set loopback mac-address Mac-address command group mdi Line-adaptive function mirror Add mirror native-vlan Set defaulted VLAN ID network-role Network role offline-tx-off-time Set the disable time of optical port of tx port Set port quit Exit from current mode and enter prior mode reset Clear port statistics return Enter the privileged mode shutdown Deactivate port speed Rate switch Switch language mode tag-transform Set the state of tag transformation traffic-suppress Set port traffic suppression tx-auto-off Auto disable tx of optical port undo Negate a command or set its defaults
  2. MA5680T(config)#display board 0 ------------------------------------------------------------------------- SlotID BoardName Status SubType0 SubType1 Online/Offline ------------------------------------------------------------------------- 0 1 H801ETHB Normal X1HA 2 H801ETHB Normal X1HA MA5680T(config)#display board 0/1 --------------------------------------- Board Name : H801ETHB Board Status : Normal --------------------------------------- ------------------------------------------------------------------------------ Power Status Power-off cause Power-off Time ------------------------------------------------------------------------------ POWER-ON - - ------------------------------------------------------------------------------ Subboard[0]: H801X1HA Status: Normal ------------------------------------------------------------------------------ Port Port Optic Native MDI Speed Duplex Flow- Active Link Type Status VLAN (Mbps) Ctrl State ------------------------------------------------------------------------------ 0 GE absence 1 - auto auto off active offline 1 GE absence 1 - auto auto off active offline 2 GE absence 1 - auto auto off active offline 3 GE absence 1 - auto auto off active offline 4 GE absence 1 - auto auto off active offline 5 GE absence 1 - auto auto off active offline 6 GE absence 1 - auto auto off active offline 7 GE absence 1 - auto auto off active offline ------------------------------------------------------------------------------ ------------------------------------------------------------------------------ Port 15Min 15Min 24Hour 24Hour AlmProf WarnProf AlmProf WarnProf ------------------------------------------------------------------------------ 0 - - - - 1 - - - - 2 - - - - 3 - - - - 4 - - - - 5 - - - - 6 - - - - 7 - - - - ------------------------------------------------------------------------------ Note: For any port, setting MDI to auto-negotiation is invalid, For a 1000 M Electrical port in the full-duplex mode, setting MDI to any value is invalid
  3. Здравствуйте уважаемые коллеги, впервые встретился с платой ETHB (Ethernet optical port) на OLT Huawei MA5680T SmartMAX, те кто раньше работал с подобными платами, огромная просьба скиньте пример их использования, мне сказали что это плата аплинка, но также она может отдавать vlan, перечитал кучу статей на китайском языке, но результата это не дало, примера конфига просто нету. Заранее благодарен за ответ Кстати, display patch all Software Version:MA5600V800R011C00 SPC100 SPH109 HP1109 ------------------------------------------------------------------------ Current Patch State: ------------------------------------------------------------------------ Patch Name Patch State Delivery Attribute Dependency ------------------------------------------------------------------------ SPC100 running common cold patch NO SPH109 running common hot patch NO HP1109 running common hot patch NO ------------------------------------------------------------------------ Total:3 Patches in the system cannot be rolled back
  4. не знаете где можно эти прошивки найти? Было бы замечательно не знаете где можно эти прошивки найти? Было бы замечательно Или специалиста, который бы прошил его за деньги, был неудачный опыт с прошивкой дорогостоящего оборудования, не хочется чтоб подобная картина повторилась.
  5. Здравствуйте уважаемые коллеги, столкнулся впервые с этой проблемой, буквально на днях подключили igmp proxy на OLT Huawei MA5680T, возникла проблема с памятью, OLT начал расходовать 75% памяти, а на портах оптических терминалов не больше 40, может кто сталкивался с подобной проблемой. Command: Плата Scun (Основная) display mem 0/8 Memory occupancy: 72% MA5680T(config)#display mem 0/7 (Резервная SCUN) Memory occupancy: 72% display mem 0/4 (плата GPON) Memory occupancy: 22% Ниже мой текущий конфиг Command: display current-configuration [MA5600V800R011: 5800] # [sysmode] <sysmode> switch adsl mode to rfc2662 vdsl mode to tr129 xpon mode switch-to profile-mode protocol support h248 system ex-mode backup # [global-config] <global-config> traffic table ip index 8 name "FTTH-IPTV" cir off priority 4 priority-policy local-setting alarm output all event output eventid 0x023000f1 event eventlevel 0x023000f1 minor syslog enable alarm-event cpu-overload-control parameter adjustfactor 20 dba-profile add profile-id 10 profile-name "dba-profile_10" type4 max 1024000 ont-srvprofile gpon profile-id 1 profile-name "8245H" ont-port pots 2 eth 4 commit ont-lineprofile gpon profile-id 2 profile-name "vsevlany" tr069-management ip-index 0 tcont 1 dba-profile-id 10 tcont 2 dba-profile-id 10 gem add 1 eth tcont 1 gem add 2 eth tcont 2 gem mapping 1 0 vlan 1100 gem mapping 2 0 vlan 10 commit # [device-config] <device-config> board add 0/1 H801ETHB sub0 X1HA board add 0/2 H801ETHB sub0 X1HA board add 0/4 H806GPBD board add standby rack info 0 description "RACK-300" name "RACK-300" manufactured-name "Huawei" [public-config] <public-config> snmp-agent local-engineid 800007DB0 # [vlan-config] <vlan-config> vlan 10 smart vlan 1000 smart vlan desc 10 description "NurTVMULTICAST" vlan desc 1100 description "Billing" port vlan 1100 0/8 0 port vlan 10 0/8 0 [emu-config] <emu-config> emu add 0 fan 0 1 "H801FCBC" service-port 36 vlan 10 gpon 0/4/1 ont 5 gemport 2 multi-service user-vlan 10 tag-transform translate # [abs-config] <abs-config> ring check enable ring check resume-interval 30 # [btv-config] <btv-config> btv igmp multicast-tag single tag-transform translate 10 btv igmp user add service-port 29 no-auth igmp user add service-port 35 no-auth igmp user add service-port 30 no-auth igmp user add service-port 32 no-auth igmp user add service-port 33 no-auth igmp user add service-port 20 no-auth igmp user add service-port 34 no-auth igmp user add service-port 21 no-auth igmp user add service-port 36 no-auth max-bandwidth 20000 multicast-vlan 10 igmp match mode disable igmp match group ip 239.1.1.1 to-ip 239.1.1.250 igmp multicast-vlan member service-port-list 20-21,29-30,32-36 igmp mode proxy igmp uplink-port 0/8/0 btv igmp profile add profile-index 0 profile-name IPVT igmp profile add profile-index 1000 # [config] <config> security anti-ipattack enable security anti-icmpattack enable mpls label start 8192 # [prevlanif] <prevlanif> interface vlanif1000 # [vlanif] <vlanif1000> interface vlanif1000 ip address # [meth] <meth0> interface meth0 ip address # [null] <null0> interface null0 Патчи которые я использую на данный момент времени Command: display patch all Software Version:MA5600V800R011C00 SPC100 SPH109 HP1109 ------------------------------------------------------------------------ Current Patch State: ------------------------------------------------------------------------ Patch Name Patch State Delivery Attribute Dependency ------------------------------------------------------------------------ SPC100 running common cold patch NO SPH109 running common hot patch NO HP1109 running common hot patch NO ------------------------------------------------------------------------ Total:3 Patches in the system cannot be rolled back Command: display board 0 ------------------------------------------------------------------------- SlotID BoardName Status SubType0 SubType1 Online/Offline ------------------------------------------------------------------------- 0 1 H801ETHB Normal X1HA 2 H801ETHB Normal X1HA 3 4 H806GPBD Normal 5 6 7 H802SCUN Standby_normal 8 H802SCUN Active_normal 9 10 11 12 13 14 15 16 17 18 19 20 ------------------------------------------------------------------------- Может кто сталкивался с подобной проблемой, буду благодарен каждому.
  6. Помогите пожалуйста подружить OLT Huawei MA5680T и ZTE F-660.
  7. Не могли бы вы пожалуйста, скинуть пример конфига, добавление карты и привязки vlana к определенному порту!) Спасибо большое, а то уже совсем каша в голове, карт ETHB 2 на каждой по 8 портов, а то я подумывал что это ethernet порты)) Не подскажите а вот http://www.thunder-link.com/ETHB_p674.html#tab-techspecs на этой картинке, сверху плоский квадратный разъем для чего предназначен?)
  8. Здравствуйте, имеется Huawei MA5680T, на ней стоят две карты ETHB, в просторах интернета ничего конкретного не нашел про эти карты, скажите пожалуйста, для чего они? Заранее благодарен за ответ!
  9. Здравствуйте, столкнулся с проблемой, которую я пока не в силах решить, и я надеюсь что меня направят на правильный путь, просьба сильно не ругать, система Gpon только начала использоваться в нашей стране. Ситуация такова, чтобы легче понять как решить данную задачу, я объясню структуру сети. Через одну жилу к нам приходить инет+тв статический ip, поступает прямо на медиаконвентор, от него на гигабитный роутер, от роутера на Huawei s5300 switch, на Huawei прописан следующий конфиг display current-configuration !Software Version V200R009C00SPC500 (если хотите могу поделиться) # vlan batch 1000 1100 # vlan 1000 description Management vlan 1100 description Users # interface Vlanif1 # interface Vlanif1000 ip address 10.0.0.2 255.255.255.0 # interface GigabitEthernet0/0/1 port link-type trunk undo port trunk allow-pass vlan 1 port trunk allow-pass vlan 1000 1100 loopback-detect enable multicast-suppression 40 broadcast-suppression 40 # interface GigabitEthernet0/0/21 port hybrid pvid vlan 1100 undo port hybrid vlan 1 port hybrid untagged vlan 1100 loopback-detect packet vlan 1100 loopback-detect enable multicast-suppression 40 broadcast-suppression 40 #dot1x-access-profile name dot1x_access_profile # mac-access-profile name mac_access_profile # В конфиге Huawei основные vlan 1000/1100, поступают на порт ge/fe(аплинк) ZTE ZXA C320, вот тут начинается проблема, я не знаю как разделить тв и инет отдельно друг от друга на логическом уровне, некоторым клиентам нужен только инет, но без доступа к тв , другим только тв без доступа в инет, у нас имеются модели ONT ZTE-F660(4 lan,2 pots, wifi), Huawei 8310(1 lan)/8245(4 lan,2 pots, wifi)/8245T(4 lan, 2 pots, wifi). То есть если клиент например хочет тв без инета, он может приобрести Huawei8310, через lan порт подключить к тюнеру который работает на платформе Android 4.2.2, клиент просто скачивать с Play Market "Youtube", и смотрит через инет видео, необходимо просто разделить тв и инет отдельные vlan, чтоб можно было привязывать на порты отдельные vlan. C320#show patch-running Loc FileName PatchTag OperateTime PatchState ------------------------------------------------------------------------------- 1/1/1 gtgogv125p2t6_r1.pat 2.0 2017-02-14 08:42:34 ACTIVE 1/1/1 gtgogv125p2t6_r3.pat 2.0 2017-02-14 08:42:36 ACTIVE 1/1/1 gtgogv125p2t6_r4.pat 2.0 2017-02-14 08:42:38 ACTIVE 1/1/1 gtgogv125p2t6_r5.pat 2.0 2017-02-14 08:42:42 ACTIVE 1/1/1 gtgogv125p2t6_r9.pat 2.0 2017-02-14 08:42:44 ACTIVE 1/1/4 smxav125p2t6_r1.pat 2.0 2017-02-14 08:41:59 ACTIVE 1/1/4 smxav125p2t6_r2.pat 2.0 2017-02-14 08:41:59 ACTIVE 1/1/4 smxav125p2t6_r3.pat 2.0 2017-02-14 08:41:59 ACTIVE 1/1/4 smxav125p2t6_r4.pat 2.0 2017-02-14 08:41:59 ACTIVE 1/1/4 smxav125p2t6_r5.pat 2.0 2017-02-14 08:41:59 ACTIVE 1/1/4 smxav125p2t6_r9.pat 2.0 2017-02-14 08:41:59 ACTIVE (могу поделиться) C320#show version-running PhyLoc FileType VerType VerTag BuildTime VerLength -------------------------------------------------------------------------------- 1/1/1 GTGOG MVR V1.2.5P2 2013-09-23 02:11:57 5193224 1/1/1 PM FW V1.2.5P2 2013-09-22 22:22:22 934 1/1/1 GTGOG BT V4.0.0 2013-03-05 14:11:46 524288 1/1/4 SMXA MVR V1.2.5P2 2013-09-23 07:34:16 13989282 1/1/4 SMXA BT V4.0.11 2016-05-11 12:07:39 524288 Версии и патчи Olt. пример привязки vlan на OLT. ONT ZTE-F660 vlan database vlan 1,1000,1100 ! vlan 1000 name Management ! ! vlan 1100 name Users ip dhcp snooping pon onu-profile gpon remote 1/5mb/4 service Inet type internet gemport 2 cos 0 vlan 1100 service MNG type internet gemport 3 cos 0 vlan 1000 interface pots pots_0/1 state lock interface pots pots_0/2 state lock switchport-bind switch_0/1 iphost 1 switchport-bind switch_0/1 iphost 2 vlan-filter-mode iphost 1 tag-filter vid-filter untag-filter discard vlan-filter iphost 1 priority 0 vid 1100 broadcast-limit ethuni eth_0/1 30 broadcast-limit ethuni eth_0/2 30 broadcast-limit ethuni eth_0/3 30 broadcast-limit ethuni eth_0/4 30 dhcp-ip ethuni eth_0/1 from-onu dhcp-ip ethuni eth_0/2 from-onu dhcp-ip ethuni eth_0/3 from-onu dhcp-ip ethuni eth_0/4 from-onu wan 1 ethuni 1 service internet host 1 wan 2 ethuni 2 service internet host 2 interface gpon-onu_1/1/1:3 switchport mode hybrid vport 2 switchport mode hybrid vport 3 service-port 2 vport 2 user-vlan 1100 vlan 1100 ip dhcp snooping enable vport 2 ip access-group 300 in vport 2 pon-onu-mng gpon-onu_1/1/1:2 ip-host 1 dhcp-enable true ping-response true traceroute-response true Мой ACL C320#show acl acl hybrid number 300 rule 1 deny udp any eq 135 any any ingress any egress any rule 2 deny udp any eq 136 any any ingress any egress any rule 3 deny udp any eq 137 any any ingress any egress any rule 4 deny udp any eq 138 any any ingress any egress any rule 5 deny udp any eq 139 any any ingress any egress any rule 6 deny udp any eq 445 any any ingress any egress any rule 7 deny udp any eq 1900 any any ingress any egress any rule 8 deny tcp any eq 135 any any ingress any egress any rule 9 deny tcp any eq 136 any any ingress any egress any rule 10 deny tcp any eq 137 any any ingress any egress any rule 11 deny tcp any eq 138 any any ingress any egress any rule 12 deny tcp any eq 139 any any ingress any egress any rule 13 deny tcp any eq 445 any any ingress any egress any rule 14 deny tcp any eq 2869 any any ingress any egress any rule 15 deny udp any eq bootps any any ingress any egress any rule 100 permit any any any any ingress any egress any Конфиг аплинк порта ZTE interface gei_1/4/1 hybrid-attribute fiber negotiation auto flowcontrol disable port-protect disable uplink-isolate disable switchport mode trunk switchport vlan 1000,1100 tag Скажите пожалуйста, как решить эту задачу
  10. Здравствуйте , мне нужна помощь, дело в том что процессе прошивки opx-350 перестал загружаться, появилась заставка VeEX с ползунком загрузки внизу экрана, реагирует только на команды включения на панели управления, и кнопки выключения на боковой части OPX-350, что мне с ним делать? Есть ли какие-то способы или методы восстановления системы? В сервисный цент поехать не могу, он находиться в другой стране. Финансово отблагодарю того кто поможет мне с перепрошивка/откат системы opx-350.
  11. А что вы забыли в Телекоме с такими вопросами? Форум предназначен для решения технических вопросов, я новичок в этом деле, и хочу получить совет от гуру, чтобы понять куда смотреть.
  12. Вопрос ГУРУ ZTE C320, приходить инет и tv по одному волокну,поступает он на гиговый роутер с поддержкой nat (скоро мы его уберем, поднимем nix), дальше от роутера поступает на switch huawei s5300, от него идет vlan 1100 internet-tv,vlan 1000 mng,первый оптический порт huawei подключен на порт olt ge/fe, можно ли разделить inet и tv ? Суть такова, на некоторых онушках надо выключать tv по требования клиента, или предоставить клиенту только tv без инета, подскажите пожалуйста методы или способы решения данной проблемы. Есть вариант подать на Huawei две жилы, inet и tv отдельно , прописать разные vlan, и оба на zte, но тут встревает вопрос для того чтобы раздавать tv серые ip нужны? или tv можно раздавать без сервера nix?
  13. Нужен совет от саппорта Huawei MA5680T, что это за предупреждение при входе через Telnet? Reenter times have reached the upper limit.
  14. Люди добрые, скажите пожалуйста, а от ZTE C300/C320 есть config manual на русском языке?
