Добрый день! Прошу помощи!
Имеется Cisco 7206VXR, модуль PC-MA-8TE1+.Пытаюсь настроить подключение к провайдеру по Е1. Физическая линия поднимается, сериальные интерфейсы создаются. Но команды voice-port просто нет. И show voice port summary ничего не показывает. Может не хватает каких-то модулей? Или версия IOS не та? Или что-то не дописал в конфиг?
Router#sh version
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 26-Feb-09 00:31 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(12b), RELEASE SOFTWARE (fc2)
Router uptime is 13 hours, 12 minutes
System returned to ROM by reload at 21:23:28 MSK Wed Oct 19 2016
System restarted at 21:26:33 MSK Wed Oct 19 2016
System image file is "disk2:c7200-adventerprisek9-mz.124-24.T.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G1) processor (revision C) with 983040K/65536K bytes of memory.
Processor board ID 34188278
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.9
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
3 Gigabit Ethernet interfaces
66 Serial interfaces
8 Channelized/Clear E1/PRI ports
509K bytes of NVRAM.
127488K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
Router#show inventory
NAME: "Chassis", DESCR: "Cisco 7206VXR, 6-slot chassis"
PID: CISCO7206VXR , VID: , SN: 34188278
NAME: "NPE-G1 0", DESCR: "Cisco 7200 Series Network Processing Engine NPE-G1"
PID: NPE-G1 , VID: V03 , SN: 36338871
NAME: "disk2", DESCR: "128MB Compact Flash Disk for NPE-G1"
PID: MEM-NPE-G1-FLD128 , VID: , SN:
NAME: "module 1", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: , SN: JAE09044MKR
NAME: "Power Supply 2", DESCR: "Cisco 7200 AC Power Supply"
PID: PWR-7200-AC , VID: , SN:
Router#show controllers e1
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Linestate Debounce is disabled
Data in current interval (749 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 50 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 1/1 is up.
No alarms detected.
Data in current interval (750 seconds elapsed):
Total Data (last 52 15 minute intervals):
0 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
E1 1/2 is administratively down.
E1 1/3 is administratively down.
E1 1/4 is administratively down.
E1 1/5 is administratively down.
E1 1/6 is administratively down.
E1 1/7 is administratively down.
Router#show interfaces serial 1/0:15
Serial1/0:15 is up, line protocol is up (spoofing)
Hardware is PA-MC-8TE1 Plus
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation HDLC, crc 16, loopback not set
Last input 00:00:06, output 00:00:06, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
8835 packets input, 35235 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
8830 packets output, 35199 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 output buffer failures, 0 output buffers swapped out
1 carrier transitions no alarm present
Timeslot(s) Used:16, subrate: 64Kb/s, transmit delay is 0 flags
Router#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
PWR FAILOVER PORT PSTN FAILOVER PORT
