Здравствуйте! Несколько дней возился с VPN. Ситуация такова:
Рабочая сеть(офис). Локальная сеть(192.168.0.xxx) =>=>=> свитч => Mikrotik(192.168.0.1 + постоянный внешний IP) => WAN.
Домашняя сеть(по сути один комп мне нужен)(192.168.1.2) => Роутер HG532e => WAN
Поднял в Mikrotik L2TP-сервер(PPTP не получается, подозреваю, что из-за провайдера GRE не проходит).
[admin@MikroTik] /interface l2tp-server server> print
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: mschap1,mschap2
keepalive-timeout: 30
default-profile: default
use-ipsec: yes
ipsec-secret: ********
[admin@MikroTik] > /ppp profile print
Flags: * - default
0 * name="default" use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=yes address-list=""
1 name="l2tp" local-address=192.168.0.1 remote-address=vpn-pool use-mpls=default use-compression=default use-encryption=yes
2 * name="default-encryption" use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=yes
address-list=""
В vpn-pool 192.168.0.100/105
[admin@MikroTik] > /ppp secret print
Flags: X - disabled
# NAME SERVICE CALLER-ID PASSWORD PROFILE REMOTE-ADDRESS
0 ***** l2tp **** l2tp
[admin@MikroTik] > /ip firewall filter print
Flags: X - disabled, I - invalid, D - dynamic
0 chain=forward action=jump jump-target=block-ddos connection-state=new log=no log-prefix=""
1 chain=input action=accept protocol=udp port=1701,500,4500 log=no log-prefix=""
2 chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
3 chain=forward action=drop connection-state=new src-address-list=ddoser dst-address-list=ddosed log=no log-prefix=""
4 chain=block-ddos action=return dst-limit=50,50,src-and-dst-addresses/10s log=no log-prefix=""
5 chain=block-ddos action=add-dst-to-address-list address-list=ddosed address-list-timeout=10m log=no log-prefix=""
6 chain=block-ddos action=add-src-to-address-list address-list=ddoser address-list-timeout=10m log=no log-prefix=""
7 chain=input action=reject reject-with=icmp-admin-prohibited src-address=37.46.80.226 log=no log-prefix=""
8 chain=input action=reject reject-with=icmp-admin-prohibited src-address=37.247.102.226 log=no log-prefix=""
9 chain=input action=reject reject-with=icmp-admin-prohibited src-address=95.142.160.189 log=no log-prefix=""
10 chain=input action=reject reject-with=icmp-admin-prohibited src-address=91.250.83.205 log=no log-prefix=""
[admin@MikroTik] > /ip firewall nat print
0 chain=srcnat action=masquerade src-address=192.168.0.0/24 log=no log-prefix=""
1 chain=dstnat action=dst-nat to-addresses=192.168.0.9 protocol=tcp dst-address=91.193.xxx.xxx dst-port=80 log=no log-prefix=""
2 chain=dstnat action=dst-nat to-addresses=192.168.0.200 protocol=tcp dst-address=91.193.xxx.xxx dst-port=90 log=no log-prefix=""
3 chain=dstnat action=dst-nat to-addresses=192.168.0.9 protocol=tcp dst-address=91.193.xxx.xxx dst-port=7776 log=no log-prefix=""
4 chain=dstnat action=dst-nat to-addresses=192.168.0.243 to-ports=81 protocol=tcp dst-address=91.193.xxx.xxx dst-port=81 log=no log-prefix=""
5 chain=dstnat action=dst-nat to-addresses=192.168.0.9 to-ports=82 protocol=tcp dst-address=91.193.xxx.xxx dst-port=82 log=no log-prefix=""
6 chain=dstnat action=dst-nat to-addresses=192.168.0.9 protocol=tcp dst-address=91.193.xxx.xxx dst-port=100 log=no log-prefix=""
7 chain=dstnat action=dst-nat to-addresses=192.168.0.9 to-ports=25 protocol=tcp dst-address=91.193.xxx.xxx dst-port=25 log=no log-prefix=""
8 chain=dstnat action=dst-nat to-addresses=192.168.0.9 to-ports=110 protocol=tcp dst-address=91.193.xxx.xxx dst-port=110 log=no log-prefix=""
9 chain=dstnat action=dst-nat to-addresses=192.168.0.202 protocol=tcp dst-address=91.193.xxx.xxx dst-port=91 log=no log-prefix=""
10 chain=dstnat action=dst-nat to-addresses=192.168.0.232 protocol=tcp dst-address=91.193.xxx.xxx dst-port=95 log=no log-prefix=""
11 chain=dstnat action=dst-nat to-addresses=192.168.0.233 to-ports=7775 protocol=tcp dst-address=91.193.xxx.xxx dst-port=7775 log=no log-prefix=""
12 chain=dstnat action=dst-nat to-addresses=192.168.0.15 to-ports=92 protocol=tcp dst-address=91.193.xxx.xxx dst-port=92 log=no log-prefix=""
13 chain=dstnat action=dst-nat to-addresses=192.168.0.15 to-ports=34567 protocol=tcp dst-address=91.193.xxx.xxx dst-port=34567 log=no log-prefix=""
14 chain=dstnat action=dst-nat to-addresses=192.168.0.9 protocol=tcp dst-address=91.193.xxx.xxx dst-port=5650-5670,5690 log=no log-prefix=""
15 chain=dstnat action=dst-nat to-addresses=192.168.0.9 to-ports=9987 protocol=udp dst-address=91.193.xxx.xxx dst-port=9987 log=no log-prefix=""
16 chain=dstnat action=dst-nat to-addresses=192.168.0.226 to-ports=4555 protocol=tcp dst-address=91.193.xxx.xxx dst-port=4555 log=no log-prefix=""
17 X chain=dstnat action=dst-nat to-addresses=192.168.0.9 to-ports=3306 protocol=tcp dst-address=91.193.xxx.xxx dst-port=3306 log=no log-prefix=""
18 chain=dstnat action=dst-nat to-addresses=192.168.0.9 to-ports=21 protocol=tcp dst-address=91.193.xxx.xxx dst-port=21 log=no log-prefix=""
[admin@MikroTik] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1 1500 00:0C:42:82:4C:13 enabled none
1 S ether4 1500 00:0C:42:82:4C:16 enabled none switch1
2 S ether5 1500 00:0C:42:82:4C:17 enabled none switch1
3 RS localToPM 1500 00:0C:42:82:4C:14 enabled none switch1
4 RS localToPT 1500 00:0C:42:82:4C:15 proxy-arp none switch1
Дома, просто на компе создал VPN-подключение.
Проблема собственно в описании темы. Я могу подключаться к компьютерам в локальной сети предприятия, только обращаясь по ip-адресу. В сетевом окружении домашнего компа нет ни одного компьютера. Попытки обращения по имени компьютера, заканчиваются ошибкой - не найден путь.
Понимаю, что чего то недонастроил... но уже что только не перепробовал, ничего не получается((((
Может кто нибудь подскажет, что нужно?
