colonel1770
Новичок
  • Публикации
    5
  • Зарегистрирован
  • Посещение
О colonel1770
  • Звание
    Абитуриент
    Абитуриент
  1. SNR#sh interface ethernet 1/0/27 Interface brief: Ethernet1/0/27 is up, line protocol is up Ethernet1/0/27 is layer 2 port, alias name is V-5, index is 27 Hardware is SFP+, address is f8-f0-82-78-7b-8f PVID is 105 MTU 1500 bytes, BW 10000000 Kbit Time since last status change:0w-0d-0h-52m-26s (3146 seconds) Encapsulation ARPA, Loopback not set Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 10G bits FlowControl is off, MDI type is auto Statistics: 5 minute input rate 34881390 bits/sec, 20672 packets/sec 5 minute output rate 518807293 bits/sec, 49166 packets/sec The last 5 second input rate 25095106 bits/sec, 18127 packets/sec The last 5 second output rate 490181909 bits/sec, 46260 packets/sec Input packets statistics: 55095425 input packets, 9284376185 bytes, 0 no buffer 55059758 unicast packets, 27518 multicast packets, 7892 broadcast packets 257 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored, 257 abort, 0 length error, 0 undersize 0 jabber, 0 fragments, 0 pause frame Output packets statistics: 132481909 output packets, 175629042977 bytes, 0 underruns 132478648 unicast packets, 2106 multicast packets, 1155 broadcast packets 0 output errors, 0 collisions, 0 late collisions, 0 pause frame SNR#show version SNR-S2995G-24FX Device, Compiled on Apr 09 15:12:27 2021 sysLocation SNR CPU Mac f8:f0:82:78:7b:8f Vlan MAC f8:f0:82:78:7b:8e SoftWare Package Version 7.5.3.2(R0004.0332) BootRom Version 7.5.25 HardWare Version 1.0.1 CPLD Version 1.03 Serial No.:SW075010I325000933 Copyright (C) 2021 NAG LLC All rights reserved Last reboot is cold reset. Uptime is 0 weeks, 0 days, 0 hours, 54 minutes Обновили прошивку, но ничего не помогло. Из-за этих ошибок начинает ругаться система мониторинга Подобная тема уже встречалась
  2. Доброго времени суток, хотел узнать как можно получить имя порта Description по SNMP. Стандартные OID не выводят этих данных.
  3. Брасов порядка 6 штук, на каждом lagg из 2х гигабит. Получается около 12 портов нужно зеркалировать. Коммутатор в который смотрят БРАСЫ такое не умеет.
  4. Имеется небольшой провайдер. Несколько БРАСов, авторизация ПППОЕ на mpd5 Машрутизируется все через Cisco4948E через ibgp В данный момент стоит вопрос для отдачи на СОРМ межабонентского трафика. для этого нужно каким то образом чтобы трафик абонентов находящихся на одном БРАСе не ходил между ними напрямую на БРАСе, а уходил выше до общей маршрутизации и попадал в канал отдачи на СОРМ. Кто что может посоветовать?
