RioDezz
Новичок
  • Публикации
    4
  • Зарегистрирован
  • Посещение
О RioDezz
  • Звание
    Абитуриент
  1. IP 25 раз еще поменяется, а звонить и так некуда, атс никуда не подключена. сейчас только с сип разобраться надо
  2. CONF { PROFIL = 1 NAME ="" MODULE [127] { TYPE = MODULE_MP NAME = "" PROFIL = 2 PCM [1-16] { PROFIL = 3 // TYPE PCM = PCM_NONE } PCM [17-20] { PROFIL = 4 // TYPE PCM = PCM_IP } PCM [21-64] { PROFIL = 3 // TYPE PCM = PCM_NONE } AIR [1] { PROFIL = 5 // AIR TYPE = AIR_IP PORT [1] { PROFIL = 6 // SIG = SIG_EXT_SIP GROUP = 1 NUMBERA = "100" } PORT [2] { PROFIL = 7 // SIG = SIG_EXT_SIP GROUP = 1 NUMBERA = "101" } PORT [3] { PROFIL = 8 // SIG = SIG_EXT_SIP GROUP = 1 NUMBERA = "102" } PORT [4] { PROFIL = 9 // SIG = SIG_EXT_SIP GROUP = 1 NUMBERA = "103" } PORT [5-7] { PROFIL = 10 // SIG = SIG_SIP GROUP = 1 } } AIR [2] { PROFIL = 11 // AIR TYPE = AIR_INT_IP } } PROFIL [1] { TYPE = AIR_COMMON sModulePlaces = "ScyyBMzd5offTiR0RkhBVHhcH7k=+5w+++" } PROFIL [2] { TYPE = AIR_MODULE wide = 64 } PROFIL [3] { TYPE = PCM_NONE } PROFIL [4] { TYPE = PCM_IP } PROFIL [5] { TYPE = AIR_IP } PROFIL [6] { TYPE = SIG_EXT_SIP IPPcmNo = 17 codec_0 = 8 codec_1 = 18 domain = "83.69.203.37" nLocalUDPPort = 5060 nRemoteUDPPort = 5060 password = "123456" username = "100" } PROFIL [7] { TYPE = SIG_EXT_SIP IPPcmNo = 17 codec_0 = 8 codec_1 = 18 domain = "83.69.203.37" nLocalUDPPort = 5060 nRemoteUDPPort = 5060 password = "123456" username = "101" } PROFIL [8] { TYPE = SIG_EXT_SIP IPPcmNo = 17 codec_0 = 8 codec_1 = 18 domain = "83.69.203.37" nLocalUDPPort = 5060 nRemoteUDPPort = 5060 password = "123456" username = "102" } PROFIL [9] { TYPE = SIG_EXT_SIP IPPcmNo = 17 codec_0 = 8 codec_1 = 18 domain = "83.69.203.37" nLocalUDPPort = 5060 nRemoteUDPPort = 5060 password = "123456" username = "103" } PROFIL [10] { TYPE = SIG_SIP IPPcmNo = 17 codec_0 = 8 codec_1 = 18 fRegisterInProxy = NO fRequireProxyAuth = NO nLocalUDPPort = 5060 nRemoteUDPPort = 5060 remoteIP = "194.149.90.25" type = 1 } PROFIL [11] { TYPE = AIR_INT_IP IPPcmNo = 17 codec = 8 nAmountPort = 31 nLocalUDPPort = 5060 nRemoteUDPPort = 5060 remoteIP = "194.149.90.25" } GROUP [1] { ROUTE = 1 } DIR [1] { NAME = "sip" } ROUTE [1] { NAME = "" RECORD "1**" LOCAL RECORD "2**" 1 } ROUTE [2] { NAME = "" }}
  3. Здравствуйте! Недавно начал разбираться с АТС М-200. Образовалась така проблема... На АТС зарегистрированы телефоны. Есть некий прокси-сервер (Repro Proxy), на котором тоже зарегистрировано несколько телефонов. Маршрутизация на прокси настроил, на телефоны АТС дозваниваюсь, но в обратном направлении не работает. Не могу разобраться с маршрутизацией.. Может кто-нибудь помочь?
  4. Доброго времени суток! Может кто-нибудь из вас работал с системой Repro Proxy? Нужна помощь с настройкой маршрутов..
