Спасибо, с этой прошивкой действительно прокатило.
ar7240> tftpboot
*** Warning: no boot file name; using '1401A8C0.img'
Using eth0 device
TFTP from server 192.168.1.254; our IP address is 192.168.1.20
Filename '1401A8C0.img'.
Load address: 0x81000000
Loading: checksum bad
checksum bad
checksum bad
done
Bytes transferred = 5351251 (51a753 hex)
Грузимся
ar7240> boot
Board: Ubiquiti Networks AR7241 board (e502-18.0101.002e)
UBNT application initialized
Firmware Version: BZ.ar7240.v3.2.12.2920.150531.1645
Will not overwrite u-boot partition! Skipped.
Copying partition 'kernel' to flash memory:
First 0x5 last 0x14 sector size 0x10000
................ done
write addr: 9f050000
Copying partition 'rootfs' to flash memory:
First 0x15 last 0x7a sector size 0x10000
...................................................................................................... done
write addr: 9f150000
Firmware update complete.
Resetting...
U-Boot unifi-v1.5.2.206-g44e4c8bc (Aug 29 2014 - 18:01:57)
DRAM: 64 MB
Flash: 8 MB
PCIe WLAN Module found (tries: 1).
Net: eth0, eth1
Board: Copyright Ubiquiti Networks Inc. 2014
Hit any key to stop autoboot: 0
## Booting image at 9f050000 ...
Image Name: MIPS Ubiquiti Linux-2.6.32.33
Created: 2015-05-31 23:49:15 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 918694 Bytes = 897.2 kB
Load Address: 80002000
Entry Point: 80002000
Verifying Checksum at 0x9f050040 ...OK
Uncompressing Kernel Image ... OK
Starting kernel ...
Booting...
Через минуту пошел пинг на 192.168.1.20, воткнули в общую сеть чтобы найти через контроллер - нашёл, все нормально.
Перед tftpboot попробываели загрузиться с зажатым резетом - да, действительно точка загрузилась с поднятым tftp сервером:
DRAM: 64 MB
Flash: 8 MB
Net: eth0, eth1
reset button pressed: clearing cfg partition!
First 0x7b last 0x7e sector size 0x10000
.... done
reset button pressed: clearing u-boot-env partition!
First 0x4 last 0x4 sector size 0x10000
. done
u-boot-env is invalid, overiding with default.
. done
write addr: 9f040000
eth0 link down
eth1 link down
Setting default IP 192.168.1.20
Starting TFTP server...
Using eth0 (192.168.1.20), address: 0x81000000
Waiting for connection: /
Пытались закинуть туже прошивку от контроллера - но tftp клиент не конектился (Time Out).
Где скачать точно подходящую прошивку для standalone режима и как лучше прошиваться?
