Mikrotik RB951G-2Hnd
MikroTik RouterOS 6.28
Неожиданно на некоторых компах пропал интернет, выяснилось что микротик не освобождает ип если комп выключен
1)Как сделать так чтобы ип освобождались если комп выключен ?
2)Как сделать сейчас чтобы неиспользуемые ип освободились, нажимаю remove на ип но он опять появляеться со статусом busy
сыпяться такие ошибки
22:02:26 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:02:27 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:02:44 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:02:50 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:02:57 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:03:14 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:03:45 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:03:51 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:03:57 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:04:14 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:04:45 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:04:49 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:04:58 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
22:05:14 dhcp,error dhcp1: failed to give out IP address: pool <dhcp> is empty
